Syncing engine
Discussion in 'XJ Technical Chat' started by Jayduncs, May 11, 2017.
Tags:
  1. Jayduncs
    Jayduncs New Member
    Massachusetts
    Good morning all. Just joined the forum, and first time posting so I hope it's in the right section.
    I just bought am 85 maxim xj700. It wouldn't hold an idle when I bought it. The guy said he had cleaned the carbs but with no luck getting her going.
    After ready multiple posts, and skimming through the church of clean, I simply adjusted the idle mixture screws and she was good to go.
    Now it's no where near ideal riding condition, I plan to take it apart and follow the church of clean to make sure everything is up to snuff.
    I'm pretty sure I understand everything I need to do, bench sync, color plugs, valve clearance and all that but I have one question. Before I start.
    I keep seeing the term engine sync, or syncing the carbs with the engine, but haven't seen anything that goes into more detail about that. Is that the same thing as a bench Sync? Or something totally different?
    Thanks for the help. I'm sure I'll be posting more questions in the future lol
    Stumplifter likes this.
  2. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    The bench sync gets you to a starting point before you do the running sync, being able to start and be somewhat close to in sync. I use a Morgan Carbtune for syncing my carbs, syncing one to two, four to three, then two to three (if memory serves correctly - there are threads on here for it). In the end all carbs are synced to number three and all four will work together. Hope that helps. I'll post a link to the engine (running) sync if I can find it in the next few minutes.
    From the Information Overload: http://www.xjbikes.com/forums/threads/the-information-overload-hour.27544/ Information on doing a running sync is about a third of the way down.
  3. XJ550H
  4. Jetfixer
    The Church of clean is a FULL tear down butterfly plates removed and shaft to replace the seals , to do this correctly you have to "break" the rack . Remove all seals gaskets , jets etc soak in carb cleaner ( 1 gallon Berrymans my favorite) for 1 hr per carb . (means 1 carb body at a time) wash carb with hot water and Dawn dry completely. Reassemble with all NEW seals do not reuse ANY of old seals, once carbs are back on rack , do a bench synch ( I use a business card cut in 2 (2 cards) , slide one each under the butterflys, adjust synch screws till you get a slight drag on the card. When I say synch screws do not mistake these for the mixture screws , the synch screws are between the carb bodies there are 3 but your idle adjustment under neigh will also come into play.
    Lightcs1776 likes this.
