Removal of main carburetor jet
Discussion in 'XJ Technical Chat' started by GARY V O, Jun 23, 2017.
  1. GARY V O
    GARY V O New Member
    Cherry Valley IL 61016
    I am trying to remove the main jet from a Hitachi hsc33 off of a 1985 xj700n, this jet doesn't have a slot for a screwdriver to fit in. I think it looks pressed in and has threads on the inside. I have tried making a puller to pull it out but to no avail. Does any one have suggestion's on how to remove?
  2. Jetfixer
    Welcome , I'm stumped the jet should have a slot ? Pictures might help us to understand , pulling is not good idea the jets are threaded in and if there is no slot someone might have hacked in an incorrect jet.
  3. XJ550H
    are you talking about the Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube"). ?
    if you are it pushes up through the top of the carb. you remove carb hat and diaphram/slide setup
    see this thread page 9 shows passage
    Something New, Something Naked
    http://www.xj4ever.com/inside your carbs.pdf
  4. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Are you sure that it's not the needle jet? It's threaded for the main jet to thread into. You should be able to screw one of the diaphragm cover screws into it and tap on it gently to remove from it's seat.
    EDIT, beat me to it there mate.
  5. hogfiddles
    You're talking about the needle jet, also called the emulsion tube. The main jet screws into it from the bottom. Your main jet is already removed if you can see the threads on the inside. The tube slides out through the main bore for the slide, not pulled out from the bottom. It is not a press fit. If it is stuck, you will need to carefully drive it out. They do get stuck with varnish, etc.... but when clean will drop neatly into the bore from inside the body. If you damage the threads inside you will need to get a replacement emulsion tube.
    Dave
    LeClairerog likes this.
  6. XJ550H
    etube.JPG emulsion tube
    main jjet.JPG main jets
    you can use a wooden dowel to tap it out large enough to fit the flat surface
    spray or pour carb cleaner down main air jet to help clean and loosen gunk up
    again page 9 of naked carb pdf will show how thw passages connect
  7. k-moe
  8. mlew
    You must be referring to the jets that are on the inlet of the carbs, they are air jets I believe and are pressed in. The only way to remove is to drill them out and replace. Leave them in , there is no reason to remove them.
  9. k-moe
    The air jets at the inlet all have slots for removal. The only pressed-in jet is the enrichment jet in the float bowl.
    I agree that the OP is describing the emulsion tube/ needle jet.
    OP, it comes out from the top, after the slide has been removed from the carb body.
  10. hogfiddles
    Incorrect
  11. mlew
    Yes guys, I see now. I was thinking of Mikuni carbs that have a pressed in air jet on the carb inlet
  12. GARY V O
    GARY V O New Member
    Thanks for all the help, I am looking at the emulsion tube there was no jet in it when float bowl was removed. I will continue to soak and try and drive out. Again what a great site thanks for all your help
  13. hogfiddles
    No jet there to begin with!?! I bet I know how well that one was running then....
  14. GARY V O
    GARY V O New Member
    This bike has been sitting in a unheated garage for the last twenty years. Mice had a field day with it the owner said it was running fine when she parked it. I believe her, she is a old freind it will be interesting to see if jets are in remaining carbs.
