Need help getting my bike just to start.
Discussion in 'XJ Technical Chat' started by tdoerr1989, Aug 9, 2017.
  1. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    I bought a 1985 Yamaha xj700. The bike had no keys, no battery, no main wiring harness, no main fuse.
    Since then, I've bought a main wiring harness, replaced the plugs, bought a new main fuse. The only thing I haven't bought is a the battery. I've currently been trying to jump the bike from my truck and have had no luck. I doesn't seem the be getting power to the proper place. I've also wired the ignition to bypass the key that I don't have. The temp gauge needle will move a hair when I get jumpers on the bike but I get nothing else. The fuses in the he instrument cluster appear fine. I've also tried to jump the bike directly from the starter but that won't get it started I've figured out because I'm just sending power directly to the starter and no where else. I JUST want to get the bike to run. Can someone please help? Feeling totally lost.
  2. k-moe
    Since you mention a temp gauge, you must have a Maxim X (there are two models of XJ 700).
    How are you bypassing the ignition switch? What jumped to what?
  3. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    My apology, I'm new to the motorcycle game. It's a maxim m. When I say bypass, I mean connected a jumper to it (hotwire) to try and get it to start, in place of having the ignition key. Severely lost on what to do right now. I just took the main wiring harness out to start back from square one and see if I am not hooking something up right. Like I said though I'm really lost. Also this bike.has no head light, brake light or turn signals. So I have extra wires just hanging about which complicates things further.
  4. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    I'm not sure if I'm even doing the attempted hot wiring right either ugh. .
  5. hogfiddles
    There's no such thing as a Maxim m.
    Are you trying to start it with no battery in it? That's a problem
  6. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    Hmm well I thought there was such a thing...but ya, I'm trying to start it without the battery. How exactly is that a problem?
  7. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    I figured trying to jump it from my truck would be fine.
  8. XJ550H
    where did you try to hot wire it to and from?
  9. XJ550H
    remove the ignition key and on the bottom should be a number . with number you can buy a key cut to numbers ebay has 2 people who do it.or local locksmith may be able to do it for you
  10. hogfiddles
    If it is the one in your avatar, it is an XJ700XN.
    If you don't have a battery hooked up in the bike, there is no sink for the ground. You're gonna fry stuff.
    Just putting juice to the starter won't make the engine run. All that would do is turn the engine over if the starter turns.
    You need: power through the RUN circuit. If things are disconnected in the bucket, the diode block may be missing.
    You said fused in the cluster look good.....did you check the main fuse under the seat?
    If you don't have a key in the main switch and have it turned on, I'm not surprised it won't run......
  11. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    I tried to hot wire it through the plug that connects to the ignition. So basically what you guys are saying is just buy a battery for it and it should run? Also, the main fuse is good as well. What does the diode block look like? And yes, my avatar pic is my bike.
  12. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    And like I said, I have no key and no ignition.
  13. XJ550H
  14. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    What is the purpose of the diode block? Just wondering.
  15. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    Never mind I looked it up. My bike needs this to run though?
  16. XJ550H
    it controls all the relays, oil light things like that
    some relays have 2 ways to activate them doide block makes it happen correctly
    I would have to look at the wiring diagram to give a bettr answer
  17. XJ550H
    with the oil light it is tested when you press the starter button with no diode in circuit if you went low on oil your starter would activate
  18. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    I think I follow
  19. Grape Ape
    Grape Ape New Member
    Mississauga, Ontario
    Reading the wiring schematic would probably help you quite a bit and understand what you're powering up and what needs power to run the bike. Just running power to wires until you find something that works is not a good way to go.
    Make sure you have a continuity tester as well because if somebody has ripped all the wiring off of the bike there is a good chance they weren't an electrician to start with and you will be chasing wires.
    Don't put led turn signals on until you do some research on how to do it because the stock flasher won't work.
    A fully charged battery also really helps.
  20. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    I'll work on getting a battery and just go from there.
  21. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    I have a question, does my kick stand need to be up in order to start the bike
  22. k-moe
    Only if you're attempting to start while in gear.
    The kickstand swichees do tend get a bit grimy though, which can cause them to stick and not deploy. Cleaning the switch plunger and lubricating it with a dry-film lubricant is recommended.
  23. hogfiddles
    No. Basically we're saying you ought to have a battery (alive or near dead) connected before trying to jump the bike. If it happens to start running without a battery connected to the grounds, you're running the risk of overloading things with out a ground connection.
    Now, if it doesn't start or turn over with a good battery, then you can start narrowing things down.
  24. tdoerr1989
    tdoerr1989 Member
    Southern Illinois
    Gotcha man
