I have a ploblem with new 750 carbs mystery tube.
Discussion in 'XJ Technical Chat' started by thanh, Sep 10, 2017.
  1. thanh
    thanh New Member
    Im Thai people apologize for my english.I purchased new engine it come with carbs as you seen in the picture i found 4 brass tube on the top of carbs . I dont know what is this tube and where to connect them ? It look differnce from the other xj bikes in my country no one know about these
  2. thanh
    thanh New Member
    It look like this.
  3. Toomanybikes
    Tsawwassen bc
    Welcome Thanh
    Those tubes are vents . A short length of hose goes down past float bowls
    Here is a picture of carbs from my Xj750rl That are the same
  4. thanh
    thanh New Member
    Thank a lot Toomanybikes for all i know from your picture all of hose go to air filter am i right?
  5. k-moe
    Incorrect. Those hoses just hang down freely as pictured.
  6. thanh
    thanh New Member
    Appreciate k-moe i have a question about this carbs i recently purchased carbs kit they said
    YAMAHA XJ750 Carb Repair Kits
    New Reproduction
    Fit Hitachi HSC32 Carbs
    Qty: 4 repair kits include
    Each kit includes:
    Main Jet #112,#122,#43
    Needle #Y403S
    I am not sure is its fit for my carburetor and why they give me 2 sized of main jet which one is suit for that.
  7. thanh
    thanh New Member
    Look like this picture.
  8. thanh
    thanh New Member
    Last time i read the article call In the church of clean im curious the type of this carb is that HSC32 or HSC33 ?
    Is its right ?
    #102: XJ750E-II models (cylinders #2 & #3)
    #105: XJ750E-II models (cylinders #1 & #4)
    Hitachi HSC33 series (XJ750E-II model)
    -Fuel level measured via the clear-tube gauge: 5.0mm +/- 1mm (.197" +/- .039")
    Hitachi HSC33 series (XJ750RL models)
    -Fuel level measured via the clear-tube gauge: 1.0mm +/- 1mm (.039" +/- .039")
    And how many turn for idle mixture screw?
  9. Toomanybikes
    Tsawwassen bc
    2-1/2 from lightly seated
  10. thanh
    thanh New Member
    Thanx Toomanybikes i will try.
