COPS
Discussion in 'XJ Technical Chat' started by jj harris, Jan 29, 2018.
Thread Status:
Not open for further replies.
  1. jj harris
    jj harris New Member
    So Cal
    Just joined and i build coil over plugs kits for yamaha vmax and ventures---anyone have any info on building sets for 1100 maxims? tia
    whats a coil over plug kit?
  3. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    One coil per spark plug. Usually mounted directly on/over, or very very close proximity to the spark plug itself
  4. XJ550H
    like my ford explorer
  5. Chitwood
    Precisely.
  6. jj harris
    So Cal
    Gsxr coil over plugs with compatible harnesses to take the place of your old coils and wires.
  7. Polock
    why ?
  8. jj harris
    So Cal
    Yamaha never upgraded their coils from 1985-2007-all others did-these are Coil On Plug meaning the coil is directly on top of the spark plug so it does not have to travel down a wire that will corrode. You will get instant fire meaning quicker throttle response, easier starts (usually 1/2 turn of the starter) quicker hot starts-(this will save on your starter life and also preventing the dreaded starter clutch these are known for)-They cannot crack like your stock coils do.
  9. XJ550H
    the 1100 is a narrow market for this why not the 750 and 650 ?
  10. Polock
    so lets say i believe all that. am i right thinking i need four coils now? of course these work with my stock TCI ? there's some bracket to support them i hope. and they don't hit my leg, do they?
  11. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    My earlier coils and wires are functioning fine, only thing I have done is snip 1/4" off the boot end, not even sure if it was needed but all the cool kids here are doing it. :cool:
    - perhaps the 1981 version are superior?
    JJ - sorry about being a smart ass (Matti is a role model for me)! I wish you luck with you entrepreneurial endeavor. I am sure there may be a market for these, a lot of people here prefer the original stock configuration.
  12. jj harris
    So Cal
    Actually someone with a vmax i built a set for was requesting another set for his maxim 1100. I am looking for the ohms rating on a stock 1982 maxim 1100 to help him out.I have made cops for vmaxs' since 2001 and have been quite successful at it for years. Find it interesting that you yourself speak for so many without every trying them. If there is someone else besides Stump that could help i would appreciate it as would help others.
  13. jj harris
    So Cal
    Answer above.
  14. XJ550H
    XJ1100 models:
    Pick-up coils:
    120 ohms +/- 20% = 96 ohms to 144 ohms acceptable range
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
  15. jj harris
    So Cal
    Very much appreciated XJ550H =I'll build him a set and if you are interested in one yours are on the house.
  16. k-moe
    Stumplifter is speaking about the prefrences of people that he knows. He made no claims about the efficacy of a different set of ignition coils.
    Stumplifter likes this.
  17. Chitwood
    Heck, depending on price, I may be interested in a set of they will fit/work on a 650
  18. jj harris
    So Cal
    Right now the ones i build for Yamaha Vmaxs' cost about the same one stock coil.
  19. jj harris
    So Cal
    Jeremiah55 and Dave in Ireland like this.
  20. Chitwood
    Sweet! I may have to give that some thought
  21. XJ550H
    just remember your coil specs are different than the xj1100
  22. Chitwood
    Agreed
  23. Stumplifter
    near Irma, WI
    Lighten up Francis.
    I stated I was was being a wise guy.
    If you spent anytime here (instead of popping in and trying to only swing your wares like an old west snake oil salesman) you would understand that 'lectricty is completely foreign to me and my comment was meant to be humorous with a bit of a snarky edge. I know NOTHING about what a coil should or shouldn't do, but I do know that my bike performs well with what it has.
    With that being said why should I kowtow to a newbie who shows up here and only tries to sell his stuff when this community already has a source for XJ parts? Have you @jj harris tried to help others in this community in any other threads? Share you vast knowledge with others instead of just peddling goods before you think you can earn any stripes with me.
    In the meantime this 'person who is so overjoyed' with your work HAS a Maxim 1100. So educate me, why can't you get the ohm reading off of their coils?
    Plug likes this.
  24. jj harris
    So Cal
    Well then Wise Guy to answer your questions-I joined to ask the question of what the ohms were and looking for help (Just joined and i build coil over plugs kits for yamaha vmax and ventures---anyone have any info on building sets for 1100 maxims? tia) is exactly what i wrote on my first post. Wasn't trying to sell anything if you are capable of comprehending that sentence.
    Read back through the thread carefully and you will read inquiring members wanting to know why and what they did. Still not trying to sell anything on this site-right?
    Then i get a pm for one of the vendors here with another inquiry---------------
    Mod Edit: Private messages are to remain private. Posting them publicly is a violation of forum rules.
  25. jj harris
    So Cal
    Now go and explain to your vendor Chacal why i will not be coming back to this site because of trolls like yourself-maybe you can find another "Stripes" video to speak for you.
  26. XJ550H
    sorry to see you go, I was hoping Len would get into this part with background if it passes his muster it is good to go.
  27. jj harris
    So Cal
  28. k-moe
    Gentelmen,
    Keep it civil. We will not become another one of "those" sorts of forums.
    chacal likes this.
  29. Stumplifter
    near Irma, WI
    Yes boss, sorry about that.
  30. Stumplifter
    near Irma, WI
    I did! :D
    Len please foregive me... I have been off my meds for about 35 years.
  31. chacal
    Me too. And with the stock market performance today.............wow did I pick the wrong week to stop sniffing glue!
  32. jj harris
    So Cal
    Seems there has been quite an interest-Nothing personal. Hope you mind being proved wrong.
  33. jj harris
    So Cal
    I've had a few more pm's.
  34. k-moe
    If the antoginistic banter contunues this thread will be locked.
    Plug likes this.
  35. Chitwood
    Any pics of a finished product? Pics of installed product? Curious how they look when installed.
  36. jj harris
    So Cal
  37. Chitwood
    Very cool
  38. Stumplifter
    near Irma, WI
    You are correct for calling me out and I would like to publicly apologize to the XJ Community and @jj harris for my behavior.
    JJ came here asking for help and that IS what we do here - my snarky comment(s) and ill attempt(s) at humor have not gone over well.
    I will strive to do better in the future. I believe those who know me here understand that I am far from being a mean-spirited person.
    Not an excuse but a disclosure:
    I am currently facing multiple life challenges outside of this community and feel as if I am being tested - pretty much a legitimate FML scenario. Being right or being wrong has no influence on my personal happiness, the safety of my loved ones and the security of my family. What I need is to get out of my frog mind state of being and find focus on the present.
    Nuch, Timbox, Rooster53 and 1 other person like this.
  39. jj harris
    So Cal
  40. Timbox
    Timbox Well-Known Member
    I like the COPS, changed them on one of my older Bandits, worked really well. My thought is if you add (and want to add) newer tech to your bike why not? Some will always want to keep the stock look and that is fine. Others (like myself) like to update some of the systems for safety, ease of maintenance or rider comfort.. There was no question in how the Bandit ran differently and better.
    Hope that this works out for those that want to have the COPS and for those that don't that is fine too. Good luck to all the wrenchers out there with their choice.
    Chitwood and jj harris like this.
  41. Polock
    if i found the right info
    "Ignition Coil Resistance Primary/ Secondary 0.12 Ohm � 10%/ 4.0 Kohm +/-20%"
    vmax coils are not the same as 550-750 xj coils, our tci boxes won't like them at all.
    and really, used coils, come on now
  42. jj harris
    So Cal
    Not all COPS are the same. Nor do they all have the same resistance. I measure the resistance on all the gsxr,cbr,R1,R6,zx12 & zx10 coils and add resistors to make them compatible--I also build and sell harnesses w/resistors for Dynatek ignition boxes. Ignitech ignitions are designed to adust to any ohm cop.
    Used coil over plug rarely go bad and i have have only heard of a few. Stock coils are prone to crack because of heat.
    I guarantee every coil i sell for life and have only had to replace 2 in over 6 years. The cost of one COP is usually less than $20 unlike your stock coil. You can also carry it in your pocket and pick up a replacement at any parts supply store. You would have to order your stock replacement coil and it would cost more than 4 COPS.
  43. jj harris
    So Cal
    They cop is placed on top of your spark plug--How would that hit your leg?
  44. jj harris
    So Cal
    e\
    Because they are more dependable, throttle response is quicker, more easier to obtain, the fire does not have to travel down a wire that can corrode, they cannot crack and lose fire like your stock coil, cost a fraction of the price of your stock coils, quicker starts so easier on the starter and starter clutch & quicker hot starts.
  45. Polock
    that's kind of redneck but if that's what you want to do, more power to ya
    used, don't forget that part.
    yea right
    angles, it's all about angles
    have they been around at least 50 years?
    maybe on something with a ecu
    yep, travels a foot at the speed of light, and anything can corrode
    why do they make replacement ones then
    especially used ones
    tune your carbs
  46. jj harris
    So Cal
    Kind of Redneck? It's is the correct way to make them compatible-
    Anyway you look at it one cop cost less than a stock coil and it is an upgrade-go into your local parts store and get your price.
    You Can't carry one in your pocket?
    Angles? Same size as your spark plug boot.
    Have they been around 50 years? New and improved.
    Try running without the ecu.
    Still quicker than a spark plug wire.
    I have only heard of 2 replacement and that was because end that goes on the top of the plug came loose-it was repaired and not an electrical problem.
    Even new they cost less and they work better.
    I am one of few in this country that rebuild Vmax carbs and take your Vmax carbs to a Yamaha shop and see what happens.
    Tune your carbs-----https://www.youtube.com/watch?v=EmsBXXEXyTs&index=9&list=UU3hkC5FHbEK7juSuWAw36Lg
  47. Polock
    round and round we go, this is going nowhere, v-max, venture, carbs, carrying coils in your pocket, same size as a sparkplug boot........
    i hope you sell a million of those things but sir you are now officially on my ignore list
  48. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    This just in:
    Study Shows More Flies Caught With Honey Than Vinegar
  49. jj harris
    So Cal
    Good.
  50. k-moe
    Annnnd.. Locked.
    We can argue the merits of a thing without being insulting.
    Plug and Timbox like this.
Thread Status:
