So what's the difference between XJ and XS?
Discussion in 'Hangout Lounge' started by jtricer1973, Feb 9, 2018.
  1. jtricer1973
    jtricer1973 Member
    Mississippi
    What;s the difference between an XJ and an XS? Just curious because to me they look almost like the same bike.
  2. k-moe
    Yamaha was inconsistent in applying model designations. There is a wide varity of engine types within both the XJ and XS lines, and a mix of methods for driving the rear wheel as well. For the most part, the XS series preceeded the XJ series in development (though there are, you guessed it, exceptions).
    The skinny is that the XS line are all triples (barring the exceptions), and the XJ line are all inline fours. The list of exceptions is almost as long as the list of the "true to definition" models, and the XJ1100 is really an XS1100 wearing different clothes (for the most part). Then there are the non-XJ models that use a mix of XJ parts.
    In conclusion; Yamaha was inconsistent in applying model designations.
  3. XJ550H
    an extra cylinder or two
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    XS=extra sylinder?
    I thought the xs650 was a twin... I guess that's one more than a single!
    Modern equivalent... XSR 700 is a twin, XSR 900 is a triple. Therefore,
  5. k-moe
    The XS 650 is the twin. The XS750 and XS850 are triples, and the XS400 and XS1100 are inline fours.
  6. XJ550H
    :Blackalien
  7. Polock
    and a sx is a ktm
  8. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    I thought xs400 was twin also?
  9. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    You are right the XS400 was a twin, but the XJ400 came in 2 and 4 cylinder versions. Also there was the Diversion XJ400 and the earlier Seca XJ400, which is where the confusion lies.
    The XJ series had been developed with the alternator behind the engine cylinders running via a chain whereas the XS bikes had the alternator running on the end of the crankshaft via a flywheel spinning inside the static windings bolted to the engine cases.
    Chitwood and k-moe like this.
  10. DarthBob
    DarthBob Member
    Massachusetts
    XS models also have kickstarters.
  11. FJ111200
    Not all the 1100's have kickstarters. My Midnight Special doesn't.
  12. cruiserlover
    cruiserlover Active Member
    denton texas
    my xs 1100, or xj 1100 or xs11, or 1100 maxim has the kickstarter blocked off by the factory. it was made 2 of 81. I dont think there is any difference no matter what you call it.All the xj4s are alike exept the turbo I believe. I know a guy that restored several 3s,850s. I find it interesting that when yamaha came out with new 9, fz? They went back to the 40 year old idea of a triple.I know they are scary fast. I rode and owned 5 v4s in the touring and cruiser lineup. Now that engine is gone. The ujms I have always had a love for. The first cb750 is one i always wanted, till I owned 3 cb650s. Their headbolt design sucks.Down at the bottom of a tube. The xj bikes use the long studs and acorn nuts.Way better.
