  1. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Colortune performed on my 82 650. Holy cow what a difference! Now all that's left is to re-synch and I'm good to go for our ride to Dubuque end of the week!
    Stumplifter likes this.
  2. Jetfixer
    Just great first 80 degree day and drum roll 35 mile an hour wind gusts actually feel like 50 so cleaned up left muffler had some scuff marks from my shoe putting bike on center stand . Getting late got to go to bed soon maybe tomorrow I can ride .
  3. Chitwood
    Rode to work this morning and was still amazed at the difference the colortune made. Needed/wanted very little enrichment to start cold and was idling happy in just a short time. This thing is a rocket ship just like it was designed to be!
  4. Toomanybikes
    Tsawwassen bc
    image.jpg Broken intake manifold stud on my Xj750rl....&;$;&/&:&.
    Right tool for the job!
    Success
    Paul Howells likes this.
  5. Andyhw
    Andyhw New Member
    Shropshire
    Today is a frustrating day, the more I'm going through the bike, the more problems I'm finding. It looks like I'm going to have to change to a round headlight, the stock one is destroyed. IMG_20180501_113413397_HDR.jpg The cost of a replacement is just too expensive.
    Is this with the stock airbox?
  6. Chitwood
    Yes, I left that in place. Depending on how things go next winter I may be removing the stock airbox for one of my own design since the plan is to (at some point) further modify the rear of the frame but I'll cross that bridge when I get there. I need to do a final synch on it but that likely won't happen until the weekend
  7. Andyhw
    Andyhw New Member
    Shropshire
    I'll have to get myself a colourtune.
  8. Chitwood
    Some have reported troubles with them, arcing, not being able to see the flame real well, etc. I did find it easier to use it in a less than well lit area. I'd recommend it. Hit up Len at XJ4ever, that's where I got mine.
  9. Toomanybikes
    Tsawwassen bc
    There should be plenty of extra stock buckets around I have a couple here and have seen many swapped for round ones
  10. Andyhw
    Andyhw New Member
    Shropshire
    There are a few used damaged ones on eBay UK and nos buckets in Germany however they are from £80-£100.... I'm not paying that for a piece of plastic. My partner has offered to get one 3d printed for me.
    I'll most likely find a round headlight though, something big enough to hide the wiring loom. If anyone knows of a direct replacement I'd be grateful. From what I've seen the maxim will swap over, however, UK availability is limited.
  11. fastenova
    fastenova Member Premium Member
    Portland, OR
    Yesterday I removed the carbs, exhaust, cams, head, and cylinder jugs and inspected everything. Measured what I could with digital calipers, but I don't really consider them accurate enough for engine stuff, and I don't have the proper micrometers to measure the pistons and the cylinder bores. I did measure end gap on a couple of the rings just out of curiosity, it was a little high but still within the service limit. These will all get remeasured and replaced as needed later.
    Today I am dropping my cylinder jugs and head at the machine shop to have the bores properly measured, get it all hot tanked, and a valve job done. Pretty sure the cylinders are not too far worn, though there is practically no cross-hatch left in the bores. So it will need a hone at the least. I know the valve stem seal on one cylinder is completely shot, and it's neighbor is starting to go - lots of carbon and residue in those two cylinders' valve area and exhaust port. Thinking this may be one of the causes of my low compression on that cylinder, I'm guessing the valve seat is in poor shape, but I'll be the first to admit I'm no expert. We'll see what the shop says...
    Tonight I plan to clean up the piston rings and the crankcase gasket surface, as well as remove the corrosion on the head studs. I also need to see about dropping the oil pan, and flushing out the crankcase directly below the pistons, as I'm positive some debris from the studs fell into the crankcase and I don't really want any of that in there when I'm putting it all back together (I am not separating the crankcase halves). Any input on the best fluid to use to spray through the crank/conrod area is appreciated.
    Aaron
  12. Toomanybikes
    Tsawwassen bc
    Have you looked into a spare engine
    Jetfixer likes this.
  13. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    I observed "Take your XJ to Work" Day. It's a not-so-well-known holiday. It happens from time to time throughout the year, weather permitting. Truth be told, I celebrated it yesterday as well.
  14. fastenova
    Portland, OR
    I don't have room for a second motor in my garage, and I'm afraid that I'll get one with sub-par compression and still have to go through an overhaul, be out a few hundred bucks, and it may still leak oil if the gaskets are old... I'd rather just fix this motor the right way even if it costs a little more.
    I did find out that XJ4EVER has aftermarket oversize piston and ring kits (I only saw super expensive OEM ones in the catalog previously) so that will make this whole project much easier, and just a plain vanilla bore and oversize piston job which is quicker and will cost less in machine shop labor. So, valve job, bore, and fitting oversize pistons, and all new gaskets. Should run like a top when I'm done with it.
  15. XJ550H
    maybe the po drilled them out or just lost one and put what he had in it
  16. XJ550H
    every day is take your xj to work day rain or shine
  17. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    You could do a leak down test on the engine before you bought it to ensure the compression was good.
  18. Paul Howells
    Victoria, BC
    I'm going to ride home in bumper to bumper traffic for 20 minutes and then if my wife hasn't made any plans for me I am going to try and finish pulling the carbs from my Virago.
  19. Jetfixer
    Had a good day rode 40 miles bike ran great , looked at some new bikes not impressed . Cut yard , looked at ice maker on fridge , bless You Tube lol . Took a break fell asleep for an hour after grilling some steaks , went out in garage and worked on bike cleaned up some parts and painted some parts . Did a plug chop number 2 cylinder was lean turned mixture screw out a half turn going to check it after I ride a ways . A colortune would be nice BUT been abusing paypal so got to get it paid down first. The other thing I did started cleaning up spare engine so far it looks okay .
    Oldmansin and Andyhw like this.
  20. Leora
    Leora New Member
    Texas
    Well I am a newbie at doing stuff on my bike but I am doing it none the less. Lots of pics with the phone as I take things apart so I can remember how it goes back together and put all the screws and bolts in their spots so I do not lose them. Took off the master brake cylinder and replaced it. I am learning lots about my bike rebuilding it. Had to take the Rifle fairing off to find out where the wire attached to the assembly went (can tell I have never done this before LOL). Discovered it vanished into the back of the headlight along with 8 million other wires.
  21. Franz
    Franz Well-Known Member
    Scotland UK.
    My sister is making a Tank Cover for me out of an old coat, it's going to look great once it is finished. XJ 900f Tank Cover being made .jpg
    Stumplifter and Jetfixer like this.
  22. Plug
    Plug Active Member
    Missouri
    Added almost 500 miles to the odometer in the last 3 days
    Chitwood likes this.
  23. granitize
    granitize Member
    Canada - East Coast - Prince Edward Island
    Pulled the wire out of the coil for cylinder 4 while changing a plug!
    Doofus!
  24. nablats
    nablats Member
    whitby
    not much today - degreased barrels for painting, wheels ready from powder coat on Friday! - must get forks rebuilt and buy some tyres
  25. dkavanagh
    Rochester, NY
    Smushed a lot of bugs with it.
    Andyhw and Chitwood like this.
  26. Chitwood
    Put a couple miles on running around town, may or may not have left some rubber in the parking lot at work. Second set of clutch plates are soaking in oil, should hopefully start on that later this week as they're calling for rain, hopefully this set lasts much, much longer. People sure look at you funny when you have a gas can for the lawn mower strapped on going one way in town and then have a 12 pack strapped on going back home...
  27. fastenova
    Portland, OR
    Dropped off pistons and valve stem seals at the machine shop yesterday. They'll be getting my cylinders bored out to match the 63.50mm pistons (THANK YOU XJ4EVER!) and doing a valve job.
    Removed, fully cleaned, and reinstalled the oil pan with a new gasket, cleaned the oil level sensor, replaced the tach drive oil seal, and installed a voltmeter/USB charger on the handlebars.
    dowski68, Plug, Franz and 2 others like this.
  28. Nuch
    Suffolk County, NY
    Man, that's clean!
    fastenova likes this.
  29. fastenova
    Portland, OR
    I sorta wanted to fry an egg in the center of it just to prove to myself that it's "clean enough to eat off"... but then I'd have to just clean it again!
  30. dkavanagh
    Rochester, NY
    I really wanted to ask how it was cleaned to nicely. Soda blasted??
  31. DAGGAGH
    DAGGAGH New Member
    WALLAN, VICTORIA, AUSTRALIA
    dont know if they will fit but from OE the shockers are incorrectly mounted - gas canister should be towards front at least that is what my xj900 shows
  32. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    well it finally happened, I wrecked my bike on the 8th of May :eek:
    Short story truck in foront of me hand signaled to make a left turn when instead they turned right. causing me to play ping pong with the side of his truck and then a fence.
    would like to blam the other driver yet I should have waited for him to make turn instead or trying to go by him.
    Broke bone that contols little finger on right hand Very Lucky.
    Waiting for insurance sompanyto see what they say hopefully they will total bike and I will buy it back as you can see not really alot of damage maybe 2-3 for repairs aat the most.
    Ride Safe My Friends
  33. fastenova
    Portland, OR
    Just carb cleaner and a nylon brush, and some elbow grease... The center screw on the removable rear baffle was super corroded for some reason, while the other two were just very snug. I had to use a manual impact driver (with a non JIS bit :mad: ) to get it out, which deformed the head a little, but I don't plan on removing it again for a long time!
  34. fastenova
    Portland, OR
    Sorry to hear it, that sucks. I'm glad the damage to you (or your bike) wasn't worse. How long will the hand take to heal? Is it just splinted? This is definitely a good reminder to all of us to just slow down and "see what happens" rather than assume the cagers around us are going to do what it appears they are going to do!
  35. Franz
    Scotland UK.
    Hi dowski glad you are ok (how is your hand) same thing happened to me last year and I bought my bike back. Fortunately I was uninjured.
  36. ADragonsTail
    ADragonsTail Member
    Sunshine Coast, Queensland. Australia
    Again, I'm glad you're okay. The damage looks light, mostly bars and blinker although I see a small dent in the tank and a chip in the speedo case. Over here in Australia, if you insure your bike as a historic vehicle (ie over 30 years old) the two main insurance companies pay you out AND give you the wreck. Pretty cool I think .
  37. Tim O
    Tim O Active Member
    Charlottesville, VA
    So sorry... hopes for a speedy recovery.
  38. dowski68
    Medford, Oregon
    The tank dent was from previous owner and yes damage is light and I am glad that I a okay bumps and bruises showed up the next day lol.
    Speedometer is okay except for the manual turn knob is broken off.
  39. dowski68
    Medford, Oregon
    sligh
    Bone that controls pinkie finger slight crack luckily that is all.
    Thank You
  40. LarryMc
    LarryMc Active Member
    Lakewood, WA
    The shocks on my XJ550 are the sketchy aftermarket ebay units that have been modified to function correctly. They are shit, as delivered,out of the box and are a source for enflamed hemeroids if your into that. Theres a guy I found on line that can actually turn RFY shocks from garbage to perfect street dampers for older bikes like our XJs. One of the wisest modifications anyone should do on an older machine is address the suspension and install newer stuff.
    They aren't OEM which is unfortunate and blessing depending on how you look at it. Ill take the newer technology stuff for a better ride anyday. Im not a purist.
    I attempted to mount the shocks with the reservoir forward and ran into clearance issues plus adjusting the charge pressure is easier as they sit.
    The shocks and swingarm will be up for sale after this riding season as I am gathering stuff up to monoshock the rear suspension (and keep the airbox).
  41. kerriskandiesinc
    NY
    Did some deliveries...again ( you can take the courier out of Manchester, etc, etc, lol) on the Seca to Connecticut.....had some rain, bright sunshine, bike was a wee bit buzzy, at 5-6 thou?, other than that, and my slightly rapid filtering ( I forgot just how GOOD the slim XJ is at this...and why I chose it, and it's derivatives (Seca 650, Maxim 750) for the majority of my courier work in the uk, oh so many lifetimes ago!!!), it was a fantastic run....even hitting 90, on occasions, she purred ( and vibrated....just a little, lol) and STILL averaged 52MPG, on my ( unscientific) Tank Fill/Trip meter calculation!!
    I wish Yamaha still made these things, !! PS WHY, they never gave the Seca's a 6th gear/overdrive, is beyond me, also ....if ANY bike needed it, it's the Seca!!!
    Tim O likes this.
  42. kerriskandiesinc
    NY
    Blimey......glad you are relatively ok !! ...poor XJ!!!
  43. Tim O
    Tim O Active Member
    Charlottesville, VA
    [QUOTE="I wish Yamaha still made these things, !! PS WHY, they never gave the Seca's a 6th gear/overdrive, is beyond me, also ....if ANY bike needed it, it's the Seca!!![/QUOTE]
    Been riding mine a year and a half now and still keep reaching for 6th just about every ride... I must think it might someday magically appear...
    kerriskandiesinc likes this.
  44. kerriskandiesinc
    NY
    ;) You should try an 80's or 90's Kawasaki.....you'll search for 7th, and 8th those things can be so....buzzy!!!!
  45. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Try a Honda Rebel, you will search for more gears, more cylinders, more leg room, more seat padding...
  46. dowski68
    Medford, Oregon
    I just contacted a salvage yard here in Oregon and he still has the 85 xj700x in his yard. 500.00 and its mine-Yeah
    Only missing the rear shocks, carbs and the instrument cluster. A deal really as I have looked for replacements parts and those are almost the same price of the parts bike.
    Ok just back from the bone docs and she said only a stone bruise on my right hand (just bruised real bad).
    Now I just waiting for the insurance company to pay up. Then I will go and get the other bike for parts that I need.
    I hopefully will be back on the road within 2 weeks. :D
    Overall I would like to thank the XJ community for all there well wishes !:)
    A very quick reminder to NEVER assume anything when on the road with CAGERS!
    Ride Safe my Friends. :D
    Jetfixer, Plug, Tim O and 1 other person like this.
  47. Jetfixer
    Didn't do as much as I wanted to ...poured down rain most of the day ....went with wide to casino , won some money and deposited it back in :oops: before we left noticed my clutch lever had slop in the bracket. Dug thru my washer bin and found an extra thin washer it really took slop out of lever.
  48. Jpwolf
    Jpwolf New Member
    California
    I have a 1982 XJ750 maxim. My first motorcycle ever xD. I got it for 200 got it running by watching carb cleaning video's on youtube. Also how I found this forum lol. So today I am gonna set the new spark plugs to there proper gap positioning with my new tool. AND see what the "shivs" or "shim"? spacing is at? lol. Despite my tutorial level knowledge. I have a good conception of mechanical things and the bike seems to run better and better the more I do as instructed from informative resources from forums inspired by cool fans of this bike. I am really having a good time riding it, its getting so fast XD. Carb syncing is the most complex goal to get right. Bet its getting good fuel to air ratio so I think its going great :D and I am enjoying myself.
  49. Tim O
    Tim O Active Member
    Charlottesville, VA
    Welcome JP :)
    You are off to a good start. When I started, the great people here have taught me to: (in this order)
    1. Safety Items, break shoes, front brake lines, etc.
    2. Valve clearances and spark plugs
    3. Carb rebuild including throttle shaft seals, includes bowl fuel level setting dry and wet
    4. Synchronization (I got a four gauge set up on line for about $45)
    5. Colortune for fuel air mix, which has sync. in it as well.
    6. Synchronization again
    Or you could wing it like I did for almost a year and do everything three times :p:mad::p
  50. XJ550H
    used some aircraft stripper to strip my gas tank the stuff is great
