Another Carb Rebuild Kit With O-Rings instead of washers!
Discussion in 'XJ Technical Chat' started by Honor Lynn, Jul 12, 2018.
  1. Honor Lynn
    Honor Lynn New Member
    California
    Hey guys, I just wanted to post and let you all know about yet another ebay listing for a 4x Carburetor repair / rebuild kit with O-Rings instead of seals . Why with the O-rings ?? They dont even fit! The listing has 4 five star reviews, but not from verified purchasers. They also are not written reviews, just stars so id wager they are fake. The listing title: 4x Carburetor Carb Repair rebuild Kit yamaha xj650, and it was a waste of 32$! Sellers name: Damineding
  2. Toomanybikes
    Tsawwassen bc
    You have to do 5 posts before you can post pics etc
  3. Toomanybikes
    Tsawwassen bc
    So answer me a few times.
  4. Toomanybikes
    Tsawwassen bc
    And maybe a few other posts
  5. k-moe
    There should be 4 small o-rings for the idle mixture screws.
    What seals are missing? The ones for the float needle seats?
    None of the kits will have throttle shaft seals included.
  6. Honor Lynn
    California
    Thanks! I appreviate the advice!
  7. Honor Lynn
    California
    Instead of sending me the throttle shaft seals they sent just O-Rings, like the type used on a sink lol. I really even tried seeing if they fit, and they were the wrong dimensions even. Such a joke, I was just laughing to my self . I guess your right about them not having any kits with the seals, but how can you call it a complete rebuild kit with out them?
  8. Honor Lynn
    California
    Ill post
    I was going to make a post about how to deal with it when a transport company damages your bike during transport and refuses to fix what they broke.
  9. k-moe
    To my knowledge, no rebuild kits have ever come with throttle shaft seals. None of the kits for motorcycles I have owned have anyway.
    Start a conversaation with Chacal to get them.
  10. k-moe
    That's easy. File an insurance claim. Let them deal with it.
  11. Honor Lynn
    California
    No, legally they are supposed too, but it took me 3 months of fighting and calling and calling to get them to fix it. They claimed the bike was damaged by me after they dropped it off, and that I was only after the money. However that particular bike ( Ducati Monster) Had just been serviced before they transported it and I could prove they broke it. Since my bike sat in storage for some time, and was handled by three different agencies, they all claimed not at fault and tried to leave me with the 900$ bill to fix it.
  12. XJ550H
    those kits come with fuel rail orings that are not the correct size to thin, also have idle mixture screws spring, washer and o ring. comes in 4 packages 1 for each carb.
    float valve assembly comes with aluminim washer instead of copper. also the carb bowl gasket is rubber.
    I picked up a kit from the china supplier for 23$ I was going to test it in an extra set of carbs.
    the kit is worth the price just for the bowl drain screws. which is the only parts I am going to use out of the kit. they seem to seal and allow level check but I use antisieze on the drain screws, I do recall another post about the drain screws leaking during fuel level test
    Just wanted to see what was in the kit for 23$
    Not to knock HL but you get what you pay for. if price is too good to be true ..........
    after all a needle valve assembly alone typicaly costs 20$ on ebay from KL
  13. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Some call it Evilbay...
  14. chacal
    Ours do!
    wgul likes this.
  15. Toomanybikes
    Tsawwassen bc
    That’s not just a kit, it’s a Master rebuild kit
  16. k-moe
    Well duh...lol
    I was just talking about the commonly advertised ones. I should have been more clear :)
  17. joejr2
    Santa Fe,NM
    Those "o" rings were for the brass fuel delivery tubes that connect the individual carbs in the set.
  18. XJ550H
    and still not the correct size .......
  19. joejr2
    Santa Fe,NM
    My "o" rings were in one of those 35.00 kits from eBay : China,Taiwan,Hong Kong etc. but I lucked out and they fit.
  20. XJ550H
    I just used the bowl drain screws with anti sieze from the kit
  21. joejr2
    Santa Fe,NM
    Yeah, I put aside the carbs I rebuilt with the Chinese kit and went with another carb set and just used the existing parts cleaned up.
    Excepting bowl gaskets and float needles/seats. The second set performed a whole lot better.
