For Sale XJ PARTS FOR SALE---FOR ALL MAXIM, SECA, AND TURBO MODELS
Discussion in 'For Sale, Trade/Swap, Wanted' started by chacal, Nov 10, 2006.
  1. Golero
    Golero New Member
    Missouri
    I just got a new set of brake lines for my 82 XJ750J, since mine were still the original cables with a manufacture date of 81 printed on them. I cut into them in various places, and they didn't look cracked or bad, but that doesn't mean they aren't brittle and dangerous. I was going to update the pictures in the "Why you should replace your brake lines" but they weren't bad enough to easily see a problem.
    As for the order process, Len was awesome to work with. I sent him the part numbers I wanted, and he replied with the rest of the parts I might need for that specific brake job - crush washers, banjo bolts, and advice. I ended up getting a bit more than I originally intended because I hadn't thought about needing to replace the crush washers, so Len helped me out there for sure.
    Once I got my parts, it came with a great packet of information with advice and instructions for the marked ends of the lines. Shipping was fast, and payment was painless with Paypal. I even got some cool stickers featuring an XJ engine after I mentioned I liked the design! I added that to my computer case, it looks great.
    Len seems like a great guy running a great business. He's knowledgeable (and gave me advice on a separate issue I was having at the outset of my order), he's got a every part I could possibly need, and obviously cares about his customers. He'll definitely get more of my business as I continue working on my bike.
    MattiThundrrr likes this.
  2. sam042955
    sam042955 Member
    Maryland, USA
    Just an FYI to lets members know that I ordered two very important tools from XJ4EVER that are used to clean the enrichment circuit. They arrived quickly and will enable me to get my carbs working properly. THANKS LEN!!!
  3. Todd Hoffman
    Todd Hoffman New Member
    colorado
    Thanks Len, I received my carb parts for my 1982 Maxim in 3 days and couldn't be happier. I was skeptical with the ordering process at first, but will for sure continue to order parts through you for my now "vintage" bike.
    Great customer service and follow through!
    Chitwood likes this.
  4. sam042955
    sam042955 Member
    Maryland, USA
    I second Todd Hoffman's experience. I've never engaged in an ordering process quite like this but it works perfectly. I just received my second order today (high performance clutch) and am scheduled to received oil filters and spark plugs tomorrow. Dealing with Len is a great experience and a great learning experience as well. Kudos Len!!
  5. to the max
    to the max Member
    Akron, Ohio
    got my order super fast. thank you.
  6. RobinV
    RobinV New Member
    Australia, in the bush
    Len provided excellent service and displayed a thorough knowledge of the parts I required for an old XJ750RL. Parts arrived via a friend who works for QANTAS, to avoid the overseas delay. 5 days to an outback town in Australia must be some sort of record IMO. By the way Len all parts correct and fitted. Now just need to crank her over. Which resulted in petrol gushing out of one of the carby hoses. More about that in another thread.
    May_J_Aaron likes this.
  7. Possible malfunction
    Possible malfunction Member
    Brainerd, minnesota
    I have bought a fair amount of items from chacal, have gotten all parts ordered in a timely fashion and always the correct parts.
    Chacal is keeping my bike on the road, and for that I thank him.
    May_J_Aaron and Chitwood like this.
  8. May_J_Aaron
    May_J_Aaron Josh May
    Chandler, Arizona
    Len has been absolutely amazing in his knowledge and speed of his delivery!
    I made the mistake of buying a Front Brake Caliper Rebuild kit from BrakeCrafters that specifically had it labeled for my bike, I struggled to get THEIR piston in with no success, tried doing it by hand, C-Clamp, freezing the piston and heating the caliper.... only the have the Fluid seal tear on both of them.
    Len quickly deciphered that they had sent my a kit that was truly for a different model and they just group them all as the same.
    Yes, Lens products cost more, but THEY WORK!
    I cleaned and polished my stock caliper pistons, used Len's Caliper Seals, and everything slide in easily by hand with firm force.
    I ended up wasting time and slowing down my project by 2 weeks becasue I tried to go with a cheaper alternative and ended up still buying from Len like I should have in the first place :p
    Here are the photos of the difference between the Stock and BrakeCrafters.
    CC944C1A-4395-4115-8F89-4992F8B80270.jpeg 6CF022D2-EC6D-4171-AB86-48CE4DD72F3B.jpeg 420B6F5E-6F7A-4090-9AA1-FF2A6C88B6F2.jpeg
    I already put in another order for more parts from Len such as boots and new bleeder screw since I used the old ones like a plug..
    And my finished Calipers!!!!!
  9. xHondaHack
    Orange CT
    Been ordering parts from Len @ xj4ever.com for several years.
    Always provides top notch service with high quality parts, and every time I've needed something he has them "in stock".
    Tony
  10. ColoradoDan
    ColoradoDan Active Member
    Longmont, CO
    New Valve Cover Gasket and Pressure Washers are on the way from XJ4Ever! Its valve adjustment time again for Veronika.
    Thanks to Len for another fast turnaround - quote, sold, and shipped in a day (maybe less even)!
    Note to anyone watching the feed for new posts: ADJUST YOUR DANG VALVES! And remember the flashing logo on the top right of the forum is where to get the parts you'll need.
  11. Trum
    Trum New Member
    Philadelphia, PA
    This is a great forum for parts. I started to buy parts this year and Len has been great! if you ever run into problems, he will always sort it out.
  12. John C
    John C New Member
    Abington, PA
    I received the Break Hoses, bolts and crush washers that I had ordered for an 1982 XJ750J sooner than I had expected them. They look great and should fit well. I am happy that I had checked in with this forum and went with the Steel hoses rather than the rubber ones as advised. Thank you Len for the help and for the fast delivery. -John Cassidy Abington, PA
    Itsnotme1988 likes this.
  13. camelCase
    camelCase Member
    Raleigh, NC
    This is a great vendor right here guys. I got my OEM clutch lever delivered as expected and for a very fair price. Just spreading the word.
  14. Itsnotme1988
    Itsnotme1988 New Member
    Johnston county, NC
    Stupidly fast shipping (even with my last minute add on and pulling old/incorrect prices) Len is the man!
  15. Bilfknmury
    Bilfknmury New Member
    Kansas City
    My petcock was leaking. Emailed Len some questions Thursday night and received a reply within an hour. Placed my order Friday night and it was shipped immediately. I received my parts on Monday. I don't think I have ever worked with a vendor that moved this fast! Will definitely buy from him again when the next thing on my bike fails lol!
  16. S10gto
    S10gto Member
    Ma.
    Just received another order from Len @xj4ever. As always parts arrived quick and correct. The manual petcock I received is a very nice piece. So thankful for xj4ever.com.
    Be sure to donate guys. If it wasn't for this site how would we keep are classics going? Len and are great community just makes it easy.
  17. Chal
    Chal New Member
    Ireland
    I'll seconds that!
    I've just received my parts as described and in superquick time from Len, I just followed his superbly clear advice and hey presto !
    Thumbs up for the forum generally too its a fantastic resource.
  18. Dave Anderson
    Dave Anderson New Member
    Mount Vernon, South Dakota
    I just got parts for the carbs on my 1980 midnight special. I emailed back and forth with Len a few times for help in what I needed and what I didn't need. Len responded quickly to my questions with very helpful answers. Parts arrived quickly and my first carb is back together and ready to go. Only three more to go <grin>.
    I highly recommend reading the great information in the How-To section of xj4ever then order needed parts from Len.
  19. Marc browning
    Marc browning Member
    Wichita, kansas
    Always awesome to order parts from you,Len. Enjoy your experience and number of so hard to find parts for our wonderful bikes.
  20. ericbovee
    ericbovee New Member
    California
    Just installed the spin on oil filter conversion. Its a model of craftsmanship and I am very happy. Len got it shipped very fast and install was a breeze, now im riding again! Thanks!
  21. Joshua Olkowski
    Joshua Olkowski Member
    Los Angeles
    Stator for XJ550 Seca?
  22. David Lentz
    David Lentz New Member
    San diego
    Hey Len, do you have Carbs for a 83 550, I can rebuild just need a price.
  23. Ivo Petric
    Ivo Petric New Member
    Zadar/Croatia
    Hi I am looking for piston rings for 1985 xj 700n maxim
    Arlan Casimero Rufon likes this.
  24. xHondaHack
    Orange CT
    Keeping myself busy on my projects with another trusted order from the resident parts guru Len (aka Chacal).
    As usual, had some hard to find stuff, in stock, and at reasonable prices.
    Tony
  25. PavelK313
    PavelK313 Active Member
    Fairfield CA
    Ordered parts on Friday and revived them on Monday. Very fast shipping considering I am in California and order arrived as expected with all parts appearing to be of high quality.
  26. Mike_3001
    Mike_3001 New Member
    canada
    The parts did the trick. A pack of throttle shaft seals later and the bike can idle properly. no more run away idle.
    Toomanybikes likes this.
  27. (Jesse)
    (Jesse) New Member
    Minnesota
    I also bought throttle seals and fuel pipe o-rings from Len. I was very impressed with the service and speed at which I received the parts. Not to mention the vast amount of knowledge and experience available at the xj4ever site! I'll defiantly be contacting him again the next time I need parts for my bike.
  28. James McMath
    James McMath New Member
    NY
    These guys know the bikes inside and out as well as all the relevant aftermarket gear. Their detailed
    and comprehensive website saved me a ton of research and effort when restoring my '82 XJ650 RJ.
    Just about everything you need is here. It's essentially one-stop shopping for XJ parts.
  29. Dazsculpt
    Dazsculpt Member
    Antwerp, Belgium
  30. Tim morris
    Tim morris Active Member Premium Member
    Hopatcong NJ 07843
    Looking for seca full touring package , seat pin, it's long and bent back on it's self to make it possible to remove seat for access thanks
  31. Arlan Casimero Rufon
    Arlan Casimero Rufon New Member
    Galveston Texas
    Hi im looking for piston set for maxim x 700 and also the piston ring.
  32. James Eller
    James Eller New Member
    Oviedo Fl
    Len's the best. Order Sunday, parts received Wednesday. Best service in XJ parts on the interwebs and always has what I need.
  33. packerbacker89
    packerbacker89 New Member
    Titusville, FL
    Len is the man. A couple months ago I ordered some brake parts from him. I paid on Sunday and they were in my hands Wednesday. Seriously the best. I’ll be coming back to him if I ever need anything for my bike.
  34. Mike Smith
    Mike Smith New Member
    Witham
    Ordered some parts that seem unobtainable here in the UK (alternator brushes and associated items), Len posted them off the day I ordered, arrived after 3 weeks in the US/UK postal systems! Nicely packed , and exactly as ordered. Good guy to do business with.
    Tim morris likes this.
  35. Henthorn23
    Henthorn23 New Member
    Mount Vernon, OH
    Do you have any throttle cables for an '82 XJ 1100 ??
  36. spacetiger110
    spacetiger110 Member
    Pennsylvania
    Great service from Len, as usual. He has everything you need, fast shipping, fair prices, and impeccable customer service.
  37. Mjolnir
    Mjolnir Member
    Southern New Hampshire
    I’ve ordered from Len ( @chacal ) almost every April for the last few years as I prep my bike for each season. Shipping is fast, service is great, and products are excellent. If you need something and can’t find it, just ask and he’s always super helpful. Don’t buy knock offs on Amazon or eBay when you can buy the real thing from him.
  38. phil_mill47
    phil_mill47 New Member
    Ohio
    I just ordered from Len for the first time and it definitely wont be my last! He responded in a timely manner and the parts all looked great. Ordered a spin on oil filter conversion and a fuse box upgrade and it all worked great. The included instructions were very helpful.
  39. gingersnap
    gingersnap New Member
    Pennsylvania
    Absolutely a pleasure doing business with Len. He got back to me right away and shipped out super fast. High quality idle mix screw sets, they look and work great (especially compared to my old ones... don't even ask how I had to get those out! ).
    Good to know someone out there sells so many well made parts for these. Will definitely be ordering more stuff as my work on this bike continues. Thanks Len!
  40. msgoodwrench
    msgoodwrench New Member
    Ohio, USA
    Fabulous job again, Len!! Parts arrived fast, everything there, packed in nicely. Thank you so much for your great service! Now, it is time for me to get busy....
  41. Reed whitehead
    Reed whitehead Member Premium Member
    Does anybody know anything about tci's specifically where I can find one for a 82 Seca 750 the one that's in the bike somebody wrote on the back of it the magic marker Maxim so I don't think it's original to the motorcycle I'm willing to try and rebuild this one with a new transistor I think the transistor I need is an st 901 t or I just like to buy one that I know works for my motorcycle thank you
    jaxcob93 likes this.
  42. Reed whitehead
    I've got a full set of carbs for the Seca 750 they have a rebuild kit in them new floats and needle valve I don't need money for them apparently I need a TCI if anybody wants the carburetors they can have them just let me know
  43. Hollybrook
    Hollybrook Member
    NoVa, USA
    Just got my order from Len after he gave me lots of good advice by email -- thanks!!!
  44. jaxcob93
    jaxcob93 New Member
    Illinois
    Pm’ed you Reed
  45. XJ4Keeps
    XJ4Keeps Member
    North Shore, MA
    Brake parts and seat cover arrived today. Everything present and accounted for, and exactly what I needed. Thanks again, Len.
  46. k-moe
    Sorry I ddn't see this sooner. The 750/650 Maxim and Seca all use the same TCI
  47. chacal
    Well, not really...........
    The 1980-81 XJ650 Maxim models use their own unique TCI (black label, ID code 4H7-10). The 1982 XJ650RJ Seca non-yics engined models used their own unique TCI (green label, ID code 5V2-10); the later Canadian-only XJ650RJC models (with the yics engines) used the more common TCI (red label, ID code 5G2-10) which also used on the 1981-84 XJ750 Maxim, 1981-83 XJ750 Seca models, and the yics-engined XJ650 Maxim models (1982-84).
    The non-yics TCI (4H7-10) and the later yics TCI's (5G2-10) are basically identical, except the earlier 4H7-10 TCI boxes don't have the grounding terminal for the kickstand safety switches, mainly because those early bikes didn't have a kickstand safety switch!
    The non-yics RJ Seca box (5V2-10) had a slightly different timing advance profile than the regular 4H7-10 or 5G2-10 boxes, and, like the 4H7-10 box, didn't have a channel for the (not-used) sidestand safety switch.
  48. Rooster53
    North, FL
    I thought these were different timing as suggested but the 82 650 Seca does have a side stand switch. Therefore, the 5V2-10 TCI has the terminal for the black and white wire to disable the TCI.
  49. chacal
    Rooster, you are exactly right, thanks for the update!
    Also, if I recall correctly, you can use the 5G2-10 TCI (with the ground wire for sidestand switch) in place of the earlier 4H7-10 non-sidestand unit.
  50. CREATCHIN
    CREATCHIN New Member
    Portland oregon
    I’ve probably ordered from Len 10 times and each time everything comes within just a couple days and in great shape, I’ll continue asking for advice and ordering parts as both have been great. Thanks again
