No power to headlight or gauges?
Discussion in 'XJ Technical Chat' started by JMTaco, Sep 9, 2018.
  1. JMTaco
    JMTaco New Member
    North Texas
    I was riding the other night when my headlight and gauges started to flicker. Now, the next morning, neither the headlight or gauges light up at all. Could it be one of the fuses? If so does anybody have a diagram of the fuses? Thanks for the help!
  2. k-moe
  3. XJ550H
    what bike you talking about ? from your other post it is an 82 xj650. maxim or seca??
    meter lights run off of the headlight fuse
    main fuse 20 amp
    headlight fuse 10 amp
    signal 10 amp
    ignition 10 amp
  4. XJ550H
  5. XJ550H
  6. JMTaco
    JMTaco New Member
    North Texas
    Sorry about that, it is a 1982 650 Maxim! Thank y’all for the help!
  7. Robinwolfy
    Robinwolfy New Member
    Orlando, FL
    Might be your relay. It sits under the rec/reg. Pop it off and jump the blue/black wire to the red/yellow wire. If your lights come on the relay is shot. You can run it like this, I am while waiting for a new relay. It does put more load on the battery when starting though.
