Mirror removal
Discussion in 'XJ Technical Chat' started by HalfCentury, Feb 27, 2009.
  1. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    I have what appears to be a stuck mirror or maybe I just don't know which way is off.
    The bike is an 82 650 Max. The mirror is the right side where the front brake master cylinder is integrated.
    Is the right side mirror a righty-tighty or the opposite?
    While I am asking, which way does the left side mirror righten/loosen?
  2. JoeFriday77
    JoeFriday77 Member
    North Texas
    I believe the one on the right side is reverse threaded. That is what I found on my Maxim X anyhoo.
  3. bill
    bill Active Member
    Raleigh, NC
    Yes right is reversed - left is normal
  4. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Thanks guys. I will give it a shot tonight or over the weekend.
    Cheers
  5. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    That did it. righty loosey. Now I can clean out the master cylinder and possibly rebuild it.
  6. bigfitz52
    Didn't anybody ever notice that the flats on that jam nut have "cuts" in them (almost makes it look like two thinner nuts?)
    That's to indicate that it's reverse thread. Most aftermarket Yamaha mirrors are similarly marked (mine are.)
  7. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Now you tell me.
    I did notice the cuts. I had no idea that the cuts indicate reverse thread.
    Fortunately I did not apply heroic force trying to loosen it the wrong way.
  8. bill
    bill Active Member
    Raleigh, NC
    Fitz you are a fountain of information - I didn't know that marking system either
  9. bigfitz52
    Some old sports cars had reverse-threaded lug nuts on one side, I remember them being marked the same way, plus there are one or two in various spots in the Norton. Machine tools have the occasional reverse-threaded nut, they're marked that way too.
    Colin 85 700 likes this.
  10. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    Ok...I can go to bed now.
    I have learned something new today!
    good information to know bigfitz
  11. jeff4995
    jeff4995 Member
    Alberta,Canada
    I too have learned something new today. Great info to know.
  12. gitbox
    gitbox Member
    Everytime I log on to this site I learn something new.
    So cool! I never knew that tidbit of information. I even had to run out and check my mirrors just to see.
    Thanks, Fitz.
  13. PJC750
    PJC750 Member
    Northeast
    Righty LOOsey for the throttle side. (Removing mirror, stuck mirror). Use a 12" pair of vice grips to remove while ON the handlebars, if servicing the right switch, or mirror. You can't fathom the physical machinations you will go thru to remove mirror if switch is off bike. 100% chance you will knock your hands, or break something else on the bike, with the force applied! Great time to clean and grease 2 areas on the mirror 1)ball joint at base of mirror, and 2) adjustment nut at top of bolt ( mine frozen). And I thought my bike came with "non-adjustable" mirrors. When you go to reinstall, call mother to film and upload video of you wasting 5 minutes trying to screw the mirror in the wrong direction(High level entertainment)
  14. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    there's also a left hand thread on the gear linkage adjuster.
    stu
  15. k-moe
    I just use the correct size wrench to loosen the locknut, then back the mirror off using the hex that's on the mirror stem.
    Sometimes a bit of penetrating oil is necessary, but very little force is required.
  16. PJC750
    PJC750 Member
    Northeast
    You are right. And yes follow your directions while the stem is 'on' the handlebar. Mine was frozen after 20 yes; ). Thanks for reply...spring is coming in NEast
