Oh man I'm So Close.....
Discussion in 'XJ Technical Chat' started by sknight, Mar 19, 2019.
  1. sknight
    sknight Member
    BC. Canada
    So let Me say This first . I am a rookie trying to figure this out. Having fun, yet frusterated LOL.
    A little history of this bike. 81 XJ650 with 12000 miles. I know that this bike has had the battery hooked up backwards thanks to a BUDDY who was trying to help(he did after we figured out his mistake) But after that we got the bike running :)
    So the first thing that happened is that the square Diode in head light bucket melted...but She still runs with out it..
    • IS THAT OK. Do i need that for the bike?
    So fast forward a few months Seemed like everything was working as it should. New headlight, LED blinkers. New Brake light. NEW SEAT.
    So I put insurance on for the day just to try her out, I made it about 2kms down the road and I started to blow ignition fuses.
    Ended up melting the OFF/RUN switch.
    Fast forward ....The Winter... I have replaced the switch, fixed the short, and we are back up and running. But now I have no headlight. I have tested and do not have 12v at the headlight....
    • do I need a new relay
    • Can you wire in a aftermarket relay?
    Any insight would be awesome.
  2. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    Diodes are always critical to any circuit. Looks like it took the polarity abuse and stopped the damage. Someone needs to check your harness from A to Z with a volt meter.
  3. sknight
    sknight Member
    BC. Canada
    I have wondered about that... I had the wiring harness out and I checked what I could, for resistance
  4. XJ550H
    you need the diode block or install your own diodes and resistor
    XJ 650H diode block
    white wire from alternator goes to diode and then to your headlight relay. it turns ac from alt to dc for the bike.
    the diode resister set runs the oil light test and low oil light. another diode runs sidestand relay
    ac to relay would toast it
    Your relay may be good . if you did nothing to replace the diode block it means the 2 white wires running to the diode block connector that turn on the headlight relay are not connected through a diode . you need a diode block to turn on headlight relay, or a suitable diode hooked into the white wires
  5. sknight
    sknight Member
    BC. Canada
    So if I found a guy who understands electrical he may be able to build one????
  6. Ryengoth
    Wilmington, NC
    Don't skimp on the electrical parts. They take a lot of abuse on a bike. You will end up fixing something over and over. I could make one with the component specs, but it is typically cheaper to just buy an aftermarket module.
  7. sknight
    sknight Member
    BC. Canada
    Well at this point. Would it be better to strip the wiring and go with a minimal diagram. Rewire it
  8. Ryengoth
    Wilmington, NC
    Replace the diode module first and see where things are then. Disconnect your accessories and lights, then check for 12v across the leads at each location to get a rundown on what is still nonfunctional. Grab a cheap 12v test light from HFT instead of blowing fuses and light assemblies.
  9. sknight
    sknight Member
    BC. Canada
    Can you get a AFTERMARKET ONE, or should I try to source one from an j650
  10. Ryengoth
    Wilmington, NC
    You can buy new OEM or used. Plenty of used ones for under $10.
    4H7-81980-M0-00
