Won't idle.
Discussion in 'XJ Technical Chat' started by Paradox1559, Apr 30, 2019.
  1. XJ550H
    when the mix needle needs to be open to many turns you have to go up 1 size on the pilot jets.
    at 5 turns out I think you are at that point to change the pilot jet .
    Chitwood and k-moe like this.
  2. Timbox
    Timbox Well-Known Member
  3. k-moe
  4. Paradox1559
    Paradox1559 Member
    Ohio
    I have a jet drill set, I'll try going up a size on the old jets and see where that takes me. Worse case scenario I'm back to square one with my new set. Spare parts are fun lol
  5. Timbox
    I hope you have a drill press or some way to make sure that all four of those jets end up being the same size. Best of luck with that and I hope it works for you.
  6. Paradox1559
    Paradox1559 Member
    Ohio
    Which pilot jet am I supposed to increase? I'm overthinking, and need clarification. Is it on the top end under the diaphragm?
  7. k-moe
    There is only one pilot fuel jet, and if you aren't aware of that and where it is, then you need to slow down and not do anything until you understand where all the parts are and how they work.
    Carbs and Fuel System
    IN THE CHURCH OF CLEAN
    THE SECRET LIFE OF CARBURETORS
    Inside your Carbs
    To answer your question directly, the pilot fuel (commonly just referred to as the pilot) is covered by the flost bowl, and is the smaller (numerically) of the two fuel jets.
  8. Paradox1559
    Paradox1559 Member
    Ohio
    My confusion is derived from the picture of the upper jets, That someone had labeled as the pilot. Thank you for clearing that up.
  9. XJ550H
    the jets onder the diaphragm are air jets.
    1 jet is the pilot air jet the other jet is the main air jet.
    both the air jets supply air to be mixed with fuel before fuel is dispensed.
    the pilot jet circuit has a pilot air jet a pilot fuel jet and the mixture screw.
    the main jet circuit has an main air jet, a main fuel jet and an aspirator tube (emulsion tube) under the main jet.
    the pilot jet runs the bike to around 2000-3000 rpm which is when the main jet starts to kick in.
  10. Paradox1559
    Paradox1559 Member
    Ohio
    Is worked!! I went up a jet size and she started right up, without choke. I have her purring like a kitten. FINALLY. I suppose it was the exhaust mod throwing it off. I'm about to get my gear on and take it for a spin to see how well I got her dialed in. I just finished a running sync
    Chitwood, k-moe, Timbox and 1 other person like this.
  11. k-moe
    Check the plug color when you get back.
    Chitwood likes this.
  12. Paradox1559
    Paradox1559 Member
    Ohio
    I need new plugs before I do that. I'll just use the colortune. For now
  13. KrS14
    KrS14 Active Member
    St Marys, Ontario
    It's been running like that for 10 years or so. Not going to change it now :) Runs like a dream too.
    Amazing how just a Mac 4-1 can throw the pilots off that much though eh? ;)
    Shows how much back pressure the stock exhaust gives the total setup.
