Synch Proceedure
Discussion in 'XJ Technical Chat' started by Beer, Sep 8, 2019.
  1. Beer
    Beer New Member
    Western Mass
    Been searching for a bit, but I’m not coming up with anything useful. Borrowed a Carb Tune from a guy at work so I can synch the carbs. Does anybody have a link for the proceedure?
    ‘81 XJ650 Maxim
  2. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    First off you will want a fan to cool the engine while you tune. It will take longer then you think. Does your engine have the YICS ports? If so, you will need a "blanking tool".
    I'm sure others will chime in with to proper order for the tune.
    Stumplifter likes this.
  3. k-moe
    The YICS blanking tool is unnecessary.
    A fan is optional.
    Synch is easy.
    Hook up your gauges to each vacuum port.
    Match cylinder 1 to cylinder 2
    Match cylinder 4 to cylinder 3
    Using the synch screw between 3 and 2, match the 1/2 pair to the 3/4 pair.
    You will likely need to adjust the idle speed as you work, and then again after the synch is complete.
    Video here (good for all models of XJ): XJ550 SECA Carburetor Balancing
    It can be done if you only have one vacuum gauge, but it takes longer.
    Old School Method of One Vacuum Gauge Carb Sync
  4. XJ550H
    Franz likes this.
  5. Beer
    Beer New Member
    Western Mass
    I was just hoping for a link. You guys are great!
    This site has been an invaluable resource for the couple of months I have had the bike.
    I’ll have to take some pictures to post to the Previous Owners Masterpiece thread, though I have fixed a bunch of stuff already.
