Xj700n jets and pods
Discussion in 'XJ Technical Chat' started by Chris Dutton, Apr 1, 2020.
  1. Chris Dutton
    Chris Dutton New Member
    Kansas
    Hey guys. So I traded an old lawn mower and a tiller I fixed up for an 85 maxim. The previous owner had cut the air box out and put k & n pods on. I was curious what some of you that run pods use for your jet combos. Also curious to what the stock jet numbers are in the event I put an air box back on. I think I remember reading somewhere that the stock jets were 100 & 40 or 110 & 40.
    air head?
    http://xjbikes.wikidot.com/carb-specs
    XJ700 Models:
    Years & Models: 1985-6 XJ700 air-cooled models
    Carb Manufacturer: Hitachi
    Carb Series: HSC33
    1985 Carb Model ID: 1FG00 (N models) or 1JJ00 (NC models)
    1986 Carb Model ID: 1NH00 (S models) or 1NK00 (SC models)
    Main FUEL Jet Size: #107
    Pilot FUEL Jet Size: #36.5
    Main AIR Jet Size: #70
    Pilot AIR Jet Size: #210
    AIR COMPENSATOR Jet Size: not used
    Starter FUEL Jet Size: #36 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-20
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 1.0mm +/- 1mm (.039" +/- .039")
    Idle RPM's: 1,050 rpms
    Chris Dutton likes this.
  3. XJ550H
    X watercooled
    Years & Models: 1985 XJ700-X XN/XNC water-cooled USA models
    Carb Manufacturer: Mikuni
    Carb Series: BS33
    Carb Model ID: 1AA00 (XN models) or 1FL00 (XNC models)
    *Main FUEL Jet Size: #100 or #105
    **Pilot FUEL Jet Size: #35 or 37.5
    Main AIR Jet Size: #120 (non-removable, in carb throat)
    Pilot AIR Jet Size: #140
    Starter FUEL Jet Size: #35 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #5FZ82 (all except XNC model)
    Main jet NEEDLE ID: #5FZ83 (XNC model)
    Main needle JET Size: #Y-2 (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3.0mm +/- 1mm (.118" +/- .039")
    NOTES:
    • there are discrepancies between the parts manuals and the service manual information on the size of the main fuel jets; one source claims these carbs were equipped with #100 main fuel jets, while other sources claim a #105 size main fuel jet.
    ** there are discrepancies between the parts manuals and the service manual information on the size of the pilot fuel jets; one source claims these carbs were equipped with #35 main fuel jets, while other sources claim a #37.5 size main fuel jet.
  4. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Good luck getting it to run well.
    Chris Dutton and XJ550H like this.
  5. XJ550H
    if you need an air box I may have one;) to sell
