Xj900f new plugs , how lean does this look?
Discussion in 'XJ Technical Chat' started by Suffolkrider, Apr 25, 2020.
To lean or ok
  1. Lean
    4 vote(s)
    100.0%
  2. Ok
    0 vote(s)
    0.0%
  3. Rich
    0 vote(s)
    0.0%
  1. Suffolkrider
    Suffolkrider Member
    Uk
    Hey guys , just put the xj back together and popped new plugs in after a carb clean ,
    The bike is a custom and has pod filters , heres a pic of one of the plugs after about 40 miles , is this ok or way to lean ? Do I need to go bigger pilot and main jets ?
  2. xHondaHack
    Orange CT
    Well that sure looks to be too lean.
    Having a set of pods on it will make it a trial and error to get it the best you can, and likely not get it 100%.
    I would be going up one size on the pilots first, and make sure you color tune / sync the carbs at idle.
    Verify the float level by wet setting them, then you can start working on dialing in the mains.
    Tony
  3. Suffolkrider
    Suffolkrider Member
    Uk
    Cheers hack,
    All float levels have been done so I know there good
    I know everyone on here hate pods on these bikes but thats all I have room for on the bike ,
    So you would recommend starting with a 42 pilot but not change the main straight away ?
  4. Suffolkrider
    Suffolkrider Member
    Uk
    Just for reference heres a pic of the old plug from the same cylinder
    Thoughts?
  5. xHondaHack
    Orange CT
    The old plug looks good. Not sure how long it was in there? (Rust on it)
    Also, is that the condition of the plug as it came out with you running the pods?
    So you said the wet setting of float levels is good. Next is before you start changing jets, as I mentioned previously:
    And, what do you mean by "a carb clean"?
    Tony
  6. Suffolkrider
    Suffolkrider Member
    Uk
    Yer the bike was on pods when I got it, only change was a new 4 into 1 exhaust , originally had 4 into 2 delkevic
    Carb clean means I stripped and cleaned out the jets, floats, bowls and put the air line on every passage ,
    On the colour tune I can seem to get it looking rich enough in colour , my thoughts were maby the yics system evening any adjustments I make across the other carbs ?
    My vaccum gauges are currently with a friend so I can't do that at the moment but I have bench synced
  7. xHondaHack
    Orange CT
    Likely the original choice of the jet sizes were close based on the picture of the original plug.
    I don't see which type of bike you have, and it's a great idea to put it in your signature, so we all know.
    You mentioned the YICS system, and you'll definitely need a block off too to get the settings right.
    Search the forums and see if there's any options that may help you.
    Also, check into the correct jet positions, some in the past have mixed them up and have posted on the forums here.
    Tony
  8. Suffolkrider
    Suffolkrider Member
    Uk
    Cheers Tony
    The bike is a 1993 xj900f with bs36 mikuni carbs
    I have the parts to make a yics tool just need to get around to making it , maby this afternoon's job
    Thanks for your help
  9. xHondaHack
    Orange CT
  10. Suffolkrider
    Suffolkrider Member
    Uk
    Yer that's it , but mine was blue and purple,
    Now though it's not got any fairings , round headlight , chopped rear subframe and hoop , custom electrics tray , battery box ect .
    I will post some pics when completed
  11. Suffolkrider
    Suffolkrider Member
    Uk
    Nowhere near complete but here's a progress pic plus one of the stripped tank
    I stripped the tank (I painted it black a whole ago) in the kind of rusting slightly then clear coating ,
    Does anyone have any experience with rust patina them clearing ? Any tips maby ?
