Changing final drive on XJ900F to a XJ1100 final drive?
Discussion in 'XJ Technical Chat' started by Neonlight, May 26, 2020.
  1. Neonlight
    Neonlight New Member
    Sweden
  2. xHondaHack
    Orange CT
    No, it's not compatible. Different axle size and hub drive gear style.
    You're best option is fitting the tallest rear tire possible, but will only give you a small decrease in rpm's.
    Sure could use a sixth gear like my Maxim X.
    Tony
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Hmmm, why not fit the whole thing - wheel and all?
  4. xHondaHack
    Orange CT
    It's the same gear ratio that he has, so no sense in that.
    Tony
  5. Neonlight
    Sweden
    oh okay, too bad... But thanks for the response!
  6. Neonlight
    Sweden
    Isn’t there a higher gear ratio in the XJ1100 final drive? Read somewhere that XJ900 has 2,9 and XJ1100 has 3,3
  7. xHondaHack
    Orange CT
    Well after I took a look at my old XS11.com bookmark I discovered you are correct on the 3.3 ratio.
    http://www.xs11.com/forum/showthread.php?threadid=13614&perpage=15&pagenumber=2
    However, you would want to go lower numerically from what you have to lower cruise RPM, so that would be going the wrong direction.
    At some point there was a thread hear on swapping the middle drive gear, but seemed to be a lot of work.
    Search for that but may not be worth the trouble to change out.
    Tony
  8. Neonlight
    Sweden
    Alright I see, I will search for the thread regarding swapping the middle gear.
    But your suggestion changing to a higher rear tire seems like the best/easiest one.
