Crankcase breather bent?
Discussion in 'XJ Technical Chat' started by Harvey Thomas, Jun 28, 2020.
  1. Harvey Thomas
    Harvey Thomas New Member
    Bristol, UK
    Hi guys,
    I have just bought a 550 maxim here in the UK. Needs some work to get it running right.
    I noticed what looks like a crankcase breather hose bent? Is this what this is? And why would someone do this? Or maybe just a mistake?
  3. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    It looks like the side stand switch has been removed and that is part of the wire loom to the switch.
  4. Harvey Thomas
    Bristol, UK
    Awesome guys thanks so much, first bike first big project. Going to be a steep learning curve
  5. lostboy
    This something to investigate. It is part of the safety system. It keeps you from driving away with the side stand down.
    Harvey Thomas likes this.
  6. XJ550H
    just to add if sidestand is down when you put bike in gear motor stalls , also when you pull up and park and deploy sidestand motor shuts down.
  7. Harvey Thomas
    Bristol, UK
    Thanks ill look into this, she's arrived and I'm checking everything over 20200629_144055.jpg
  8. XJ550H
    you will want to replace that paper fuel filter with a sintered brass filter paper tends to not work well.
    you can pull the side stand relay to bypass the sidestand untill you can get parts to fix it . it is the one under the seat behind the tool tray. you can see the holder in photo
  9. Harvey Thomas
    Bristol, UK
    Filter in the post, will be sorting that, cleaning tank and syncing carbs.
    Will create a build thread to replace this one
  10. Harvey Thomas
    Bristol, UK
    20200629_144119.jpg I'm assuming this is it?
  11. XJ550H
