xj550 oil pan/sump bolts
Discussion in 'XJ Technical Chat' started by Harvey Thomas, Jul 13, 2020.
  1. Harvey Thomas
    Harvey Thomas New Member
    Bristol, UK
    Hi guys,
    I've moved on to remove my sump and replace the gasket as there is a nasty leak. Problem is I'm having a nightmare getting the bolts out. They are Allen bolts.
    Soaked in oil and the bolt snapped halfway. Heated up with hot air gun and stripped the head of the bolt!
    Any tips would be much appreciated as I have at least 3 to now retap.
  2. Harvey Thomas
    Bristol, UK
    More pictures please help!
  3. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    I suspect the PO's solution to stop the oil leak was to crank those screws way too tight.
    You're going to have to drill the head off so you can get the pan off, then hopefully grasp it with vice-grips.
    If it were me I'd remove the gas tank, battery, all the fluids and lay the bike over.
    Working underneath the bike like that is not something I can even think about.
    If you have to install any heli-coils much better with the bike on it's side.
    Franz likes this.
  4. Harvey Thomas
    Bristol, UK
    Thanks simmy! Lent on side and manage to get a few more out and found the perfect size for the rounded ones 15946470438987302477294132093227.jpg
  5. Simmy
    clever, I hadn't considered that.
  6. Harvey Thomas
    Bristol, UK
    And the fruit of the labour
  7. Harvey Thomas
    Bristol, UK
    Ummm.... is this cracking in the sump normal? Could it be the cause of the leak?
  8. a100man
    a100man Well-Known Member
    Bedford, UK
    Looks like casting marks not cracks so normal. You can try reinserting the sump plug and torque to spec and see if the 'open out' if your unsure, or take a needle file to them
    and dress them back.
    Harvey Thomas likes this.
