Beware of project bikes
Discussion in 'Hangout Lounge' started by joejr2, Aug 23, 2020.
  1. joejr2
    Santa Fe,NM
    If you are like me, always on Craigslist or Facebook marketplace looking for xj parts bikes or neglected
    garage queens for sale, beware of bikes described as "projects". You have no idea what the tinkerer
    Has done to the bikes internals before he lost interest or got over his head. Always look at a project
    As a potentially salvageable source of parts rather than an opportunity to assemble an an cheaply.
  2. joejr2
    Santa Fe,NM
    Xj was changed to an
  3. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Yes, don't let the excitement of finding a bike blur your vision on what the end result could be. If it does not feel right it is best to walk away.
  4. Franz
    Franz Well-Known Member
    Scotland UK.
    I bought a 250 Honda twin when l was young and learned from that one. Was not worth fixing at least l made the error with an inexpensive bike.
  5. lostboy
    We all do silly things when we are young.
  6. Franz
    Scotland UK.
    Yup all part of the learning process.
  7. XJ550H
    unfinnished project bikes are the ultimate in PO bikes.
    most never get bike running or running properly first. Out comes the sawzall and grinder and cans of paint. pull all the relays put them back where ever they fit
    jets all mixed up in carbs.
  8. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Does that mean I’m still young?
  9. bigfitz52
    #1 cardinal rule should always be a compression test. For most of these bikes, major things like replacement pistons, etc., are simply not available.
    A compression test will give you a basic idea of the viability of the motor; beyond that it is a case of how much work you want to do and how much money you want to spend. For a true restoration, things like stock mufflers, etc., can present a real challenge. If the bike is complete and makes good compression numbers, and you're prepared to replace all "wear items" and any gasket or seal you disturb, then have at it.
    With project bikes, it's not so much a case of "beware." It's more a case of "know what you're getting into" when making the decision. I've walked away from more than one promising fixer-upper because one cylinder was dead. (Note: a 4-cylinder bike will run- not well, but run- with 3 healthy cylinders and one really bad one.) Hence my recommendation for a compression test.
