XJ-750RK Sealed Battery
Discussion in 'XJ Modifications' started by smokamoto40, Jan 24, 2008.
  1. smokamoto40
    smokamoto40 Member
    sacramento, ca
    Alright all you Seca 750 geniuses-I'm changing to a sealed battery and need to know how to defeat the bloody battery water sensor so my dang dash BATT light stays off. :roll:
    Any constructive ideas, anybody?
  2. Polock
    a: hook the wire to +12volts someplace
    b: take the bulb out
  3. smokamoto40
    smokamoto40 Member
    sacramento, ca
    Are these cures you have used?
    I'm pretty sure the "bulb" is part of the LCD, and can't be "taken out"-yes :?:
    Thanks for replying.
  4. Polock
    the 12 volts will work and is safe,light out never on, but i played around and found that a *3600 ohm* resistor gives a low battery indication
    like if the key is on while your doing something and the battery gets low, the light will glow for a while after its started then go out, nice
    *3600* is from memory, i'll measure it tomorrow
    the bulb is just me being a smart ass, sorry
  5. Nick
    Nick Member
    Vernon, BC Canada
  6. smokamoto40
    smokamoto40 Member
    sacramento, ca
    Polock-thanks for more details-and no worries-that's the issue with writing-can't catch the tone.. :)
    Nick-thanks for the link, I'll try that. :idea:
    Results to follow
  7. MGM8675309
    MGM8675309 Member
    Fort Worth, Texas
    PO cut off the sensor so I added a length of wire to it and ran it directly to the positive battery terminal.
  8. schmidtap
    schmidtap Member
    Ft Stewart, GA
    I just took out the warning light on my max, Main reason is now the light don't come on, and with LED bulbs in my tail, I get the warning for the tail on occasions
  9. Polock
    the 3600 from the other post should be 5900 ohms
  10. noob
    noob Member
    Southport, UK
    I just had a look through that link, and it can be connected directly to the battery as the sensor wire goes through the ignition switch. Found that out the other day while severley hacking a headlight to my Seca.
