Fork top plug
Discussion in 'XJ Technical Chat' started by Moss, Jan 22, 2021.
  1. Moss
    Moss New Member
    Ireland
    hi lads, i needed to rebuild my forks including replacing one of the stanchions (inner pipe) but when the new one arrived it was threaded internally for the top plug instead of being held in with a snap ring, so anyone have a threaded plug to sell me? Or just tell me the partnumber ?
    Thanks guys
    Oh, its a 1982 seca 750
  2. Polock
    the tubes with the snap ring are for maxims with the adjustable compression, i think, i'm not sure your valving is going to work
  3. Moss
    Moss New Member
    Ireland
    Thanks Polock, mine is a european spec Seca so maybe the same as a maxim? There is no adjustability in the forks except for air pressure and the current top plug is just a solid plug so if i can get any threaded plug i can seal it,
    Thanks bud.
  4. k-moe
    You'll have to order the plug for that upper tube. Threaded tubes were not used on the XJ series. You have a functional, but not exact, replacement tube.
  5. Moss
    Moss New Member
    Ireland
    Thanks K-moe, makes sense to me, might get the tube machined, remove the thread and cut a groove in it, i'll have to ask an engineering company, unless you knowwhat that plug is from or a part number, thanks.
  6. XJ550H
    xj1100 uses a threaded fork cap maybe that will fit.
    part listed as unavailable In US catalog
    10M-23111-00-00
    the maker of your tube may have the proper cap
  7. Moss
    Moss New Member
    Ireland
    Ok thanks XJ550H, i'll have a look at that. Ive contacted the supplier but havent had a reply yet.
  8. bensalf
    bensalf Well-Known Member
    yorkshire ,england
  9. Moss
    Moss New Member
    Ireland
    Thanks Stu, might be able to chase that up
  10. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Radian and FZ600 also have threaded plugs and 36mm tubes.
    Radian has plain hex cap, FZ600 has Schrader valve.
  11. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    XJ1100 has 37mm forks, same size as XS1100.
  12. Yammaat
    Yammaat Active Member
    Netherlands
    I still might have some plugs since I have the same model and another one in parts.
    Have to check though wether the plugs are the same with the spare tubes.
  13. Moss
    Moss New Member
    Ireland
    Thank you all lads Food for thought,
    @Yammaat , that would be great if you have one you're happy to part with i be delighted
  14. Yammaat
    Netherlands
    Well, i have to disappoint you.. all plugs are screwplugs...
    @k-moe.. all the tubes I've got (xj750 seca and xj600) have threaded tubes..??
    Models are from UK/Canada.
    But I'm pretty sure I've had xj's with a pushcap...???
  15. Moss
    Moss New Member
    Ireland
    Ok, its the threaded plug im looking for my original tube had a plug held in by a spring ring and the one they sent me has a thread, so its a threaded plug im looking for, a plug that screws in a bit down the fork tube and the push cap just fits in the top of the tube as a finisher. Thanks.
  16. Yammaat
    Netherlands
    Well, in that case I could help you with a cap.
  17. k-moe
    All of the NA models of XJ I've seen have pushcaps, up until '84 or so.
    I know for a fact that the US '82 Seca 750 only had push caps held with a wire clip, and have only seen refrence to such in the service manuals for all NA and UK delivered machines. None mention a threaded fork cap.
    Moss likes this.
  18. Moss
    Moss New Member
    Ireland
    Yep, thats what i had originally
  19. Moss
    Moss New Member
    Ireland
    That would be great, im in Ireland so postage could be a few quid, just let me know you want for it plus postage and ill send it to you by paypal if that suits you, I can put my address in the paypal 'note' if thats ok too. I'd just need your email
    thanks mate.
  20. Moss
    Moss New Member
    Ireland
    That would be great Yammaat, Im in ireland so the p@p could be a few quid, just let me know what you want for it and the postage and I could send it by paypal if that suits you, my email is
    mg240d@gmail.com if you want to get in touch off the forum,
    Moss
  21. Yammaat
    Netherlands
    @ K-Moe; My Haynes manual only talks about screwed caps..??
  22. Moss
    Moss New Member
    Ireland
    Just an update folks, theres a threaded plug on the way to me courtesy of Yammaat (gentleman) so hopefully that will be the end of these particular troubles,
    Thank you very much for all info, advice and help, great forum
  23. Moss
    Moss New Member
    Ireland
    Last post, plug arrived from Yammaat, fits perfectly, so thanks once again everyone for all the help.
    Yammaat likes this.
  24. k-moe
    Does your Haynes include the North American models?
    Keep in mind that we have found several errors in all of the available service manuals, including the official Yamaha manual.
  25. Yammaat
    Netherlands
    Will check but the SecaRat is from Canada (=NA?) and has screwcaps aswell
