1982 XJ speedometer replacement
Discussion in 'XJ Modifications' started by Thomas Martinez, Feb 9, 2021.
  1. Thomas Martinez
    Thomas Martinez New Member
    Albuquerque, NM
    Hello,
    does anyone know of a aftermarket speedometer I can put on my 1982 XJ750 to replace the OEM one?
    These are the features I am looking for: MPH, Works with existing speedo cable, and Fuel gauge
    It would be preferable to have a Speedo/tach combo but that isn’t necessary.
    Doesn’t matter if it is analog or digital
    thank you in advance for your help!
  2. Toomanybikes
    Tsawwassen bc
    Swap over an 83 gauge set same as the xj650 maxim. But most aftermarket ones will need some fiddling to make work
  3. XJ550H
    the display portion can be retained there is a thread or 2 about keeping it.
    otherwise you do an atari removal add in the jumper wires needed to make the harness work.
    then swap in a set as suggested above.
    fuel guage could be done with a small meter like the 550 seca uses or a digital meter set up to wprk off of the resistance change in the "sending unit " in the tank
    fuel guages are just a volt meter set up
  4. XJ550H
  5. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    [​IMG] Cheers 50gary
  6. Dave in Ireland
    Ireland
