1997 yamaha xj 600 rear brake caliper
Discussion in 'XJ Technical Chat' started by MagnaXJ600, Feb 17, 2021.
  1. MagnaXJ600
    MagnaXJ600 Member
    I am trying to repair my rear brake caliper on my 1997 yamaha xj 600. DOes it have just 1 piston on 1 side or 2 pistons 1 on each side? I got 1 piston out but the 1 that faces the rim is stuck or is this just 1 piston and the other side does not move? Thx
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    there should be 2 pistons and they both should move. if its stuck ,you need to replace the one you got out, back in, and hold it in with a "G" clamp or the like , re- bleed the oil , and pump the stuck one out, they can be stubborn little b*ggers.
    stu
  3. MagnaXJ600
    MagnaXJ600 Member
    OK I guess ill be doing that tomorrow. I bought 2 of these bikes. The 1 that runs had a stuck rear caliper and I rounded off the allen bolts that hold that pads in and now I cant get them out. The parts bike I got had stripped out mounts on the caliper. So I oredered 1 from Ebay. I got the allen bolts out but the 1 piston is stuck. Ill be puting it back together and clamping the 1 side. Thx for the info.
    Also I just did the clutch rattle fix and now im on the brakes.
  4. bensalf
    yorkshire ,england
  5. MagnaXJ600
    MagnaXJ600 Member
    Yes it has 2 bleeders. I have 3 calipers and they all have the same piston stuck, but I noticed they are each sticking out at different measurements. One is flush with the casing one is a few mm raised and another is a few more mm raised, so unless they made them all different those pistons are at different levels. Stuck at different levels.
  6. bensalf
    yorkshire ,england
    yeh, they're just stuck at different levels
  7. MagnaXJ600
    MagnaXJ600 Member
    I hope to find out tomorrow.
  8. MagnaXJ600
    MagnaXJ600 Member
    Finally got it apart. It has 2 pistons.
