update on my 550 seca
Discussion in 'XJ Technical Chat' started by Diver14_98, Jan 16, 2008.
  1. Diver14_98
    Diver14_98 New Member
    fairview hgts il
    i put a battery in it and just found out the motor is locked up. is the bike worth messing with.
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    are you sure it's locked up?
    did you try push-starting it to see if it would turn over?
    EDIT:
    better yet, take the timing cover off and try turning the motor with a wrench
  3. MiCarl
    Better yet, pull all the plugs and put a teaspoon of penetrating oil in each hole. Wait overnight and repeat.
    Make sure you have oil in the crankcase and bike in neutral. Then try to turn with a wrench on the timing plate nut.
  4. Diver14_98
    fairview hgts il
    where is the timing cover at
  5. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    Left side, front.
  6. Diver14_98
    fairview hgts il
    the bike is still locked up. need more help.
