Weird problem on my Yamaha XJ650 Turbo
Discussion in 'XJ Technical Chat' started by RussellNash77, Sep 11, 2021.
  1. RussellNash77
    RussellNash77 New Member
    Italy
    Hello,
    I finished after many months of work my XJ Turbo but she has a weird problem.
    The bike starts fine, she need only a just a little choke from cold and suddenly she idle without the choke.
    If then I go and ride, the engine run smoothly and fine at any RPM but if I leave her at idle she start to go on 3 cylinders after let's say 1 minute, number 3 usually have problems! Then if I close the fuel petcock and wait a little then she runs on 4 normally. Basically I can't leave her on idle without previously closing the fuel petcock.
    Last day at a traffic light I did not close the fuel tap and then she started going on 3 and even I think on 2 cylinders then she stopped! I was not able to restart the bike again, I removed a couple of spark plugs to check them then, as it was becoming night, I mounted them again. Then luckely the bike started normally and she ran really nice!
    These are the works I did on the bike:
    - Valve clearence checked, shims replaced and in specs.
    - Compression test done and ok.
    - Carbs cleaned and refurbished with carb kits (except the pilot screws and their o-rings)
    - Fuel levels set with clear tube.
    - Air Filter Changed (new).
    - Spark plugs changed (with resistors).
    - Sparks Caps changed (without resistors inside).
    - Coils and wires changed (new).
    - Check valve replaced.
    - Fuel hoses replaced.
    - Carb Sync done.
    - Elettrical wires cleaned nearby the Ignition Unit.
    - Fuse box replaced with a modern one.
    - I checked many times the spark plugs and they are really fine, cleaned and no black carbon or oil on them.
    My considerations on how to solve the problem, but I'm not an expert mechanic so I need your suggestions:
    - Is the probem due to the fact that on cylinders number 2 and 3 the main jets are too large? At the moment 132.5 so as requested by specs. But from what I know main jets are not in use in idle...
    - The problem could be caused by the ignition unit?
    - Replacing the pilots screws and clean again the seats could solve the problem?
    I don't have anymore ideas, hope someone can help me with this.
    Thanks in advance.
  2. k-moe
    First. What do you mean by close the petcock? The stock petcock is vacuum operated and has no OFF setting.
    Second. What brand of carb rebuild kits did you buy?
  3. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    This is incorrect for Turbo petcocks, which do indeed have an On-Off-Res (although I forget the order).
    You say you replaced the check valve. Was this the FUEL check valve. I had issues with mine where I had replaced the seals, but after sitting for months it got sticky and would only let a little fuel by. This would starve the engine, especially at highway speeds. Sometimes sitting would allow enough fuel to sneak by to fill the bowl again and let it run.
    However, you closing the petcock (assuming you're getting the positions correct) would suggest that the carbs may be flooding, and closing the petcock is stopping this. How did you wet-set your float heights? On a Turbo is particularly taxing because you need to set them with the fuel pump running (you can put the bike on the center stand, turn on the bike and ignition, select 1st gear and put the kickstand down. Pushing the start button you will only hear the fuel pump running). If you want to check it's not so bad on the bike, but if need to adjust, you'll want to build a rack and set up the fuel tank and 12V source for the pump (not a lot of fun).
    If you use clear tube method to drain a carb bowl, then right the tube and run the fuel pump, you should see the level come back up very quickly and stop at the appropriate level. If it takes a long time and is inconsistent, then check your fuel check valve. If it overflows, suspect the float on that carb. If they all overflow, it could be your pressure regulator. The best way to check that (that I found) is a fuel pressure sensor, but that setup runs a little over $100 for the gauge and sensor.
    Jetfixer and k-moe like this.
  4. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    I agree with @ManBot13 and suspect a float is not shutting off.
    Shutting the fuel off may correct the overflow condition as you've found.
    I'm not sure this is good for your fuel pump as it's a positive displacement pump pulling against a dead end.
  5. Simmy
    there is a very obvious reason why a vacuum operated petcock won't work on a turbo.
    As soon as you develop boost pressure it would shut the fuel off.
  6. RussellNash77
    Italy
    Thank you for all the comments first of all.
    I did not check the carbs with the fuel pump running, I check them on the bench with the clear tube and a classic teporarily tank.
    I checked the closure of the needle valve many times because it was the initial issue. I took out the carbs 3 times from the bike but last time I worked and changed again the valve seats and check them many many times, let's say 20 times!! Really 20 times because I had to be sure they were closing correctly.
    In fact the spark plugs are really clean, no deposit at all. Before doing the work I always found them really carbon black.
    Could you tell me more eventually on how to proceed with the fuel pressor sensor?
  7. RussellNash77
    Italy
    You are right about the fuel pump, I did not think that practice could damage it.
    Another thing, It will be possible for you that the fuel pump has too much power and so it delivers too much fuel?
    I'm asking because I don't think is an OEM one but there's no brand or written on it, all I know is that it is working fine and also the return line to the tank is very consistent.
  8. Simmy
    If your pressure regulator is working properly then a larger capacity pump will not matter as the excess fuel is just returned to the tank.
    ManBot13 likes this.
  9. Simmy
    you need to tee in a pressure gauge between the fuel pump and the regulator.
    It doesn't matter which side of the fuel check valve you are on as pressure is the same on both sides.
    @ManBot13 suggested a nice trick about putting the bike in gear, side stand down. When you depress the starter button like this the fuel pump runs without the starter motor.
    You're looking for a pressure between 2-3 psi so you will need a 0-15 psi fuel rated gauge, they're cheap on eBay
  10. ManBot13
    Fairfax, VA
    A cheap fuel pressure gauge works if you only want to use it diagnostically. However, unlike a boost gauge, you can't run it up to the dash (you wouldn't want fuel coming up to your dash or somewhere you can see, then fail and spray fuel everywhere). An electronic gauge allows you to T off a sender in the line, and connect it to an electronic gauge. I liked this because it also helps you see that the fuel pump is keeping up with the boost pressure and regulator is working as well. If you forget to open the petcock, it'll also tell you because the fuel pressure will go from 2psi to 0 before the engine actually stops running (I had done this several times).
    Wet setting with the fuel pump running ensures that the float needles are set for this extra 2psi fuel pressure, as well as showing that the regulator is working.
    Simmy likes this.
  11. RussellNash77
    Italy
    So, resuming, do you think that with a fuel pressure I will solve the problem?
    Do you have a link for the regulator or pics?
    About the wet setting with the fuel pump I really don't know, it seems quite complicated and I'm confident that the needle valves are closing correctly otherwise the spark plugs were not so clean.
    What about changing all the pilot screws and relative o-rings? May be the problem?
    What about turning the main jets of carbs 2 and 3 from 132,5 to 127 as the outers?
  12. Simmy
    Does it stay running if you raise the idle to 2,000 rpm?
    How many turns out are on the mixture screws?
    I think your regulator is probably ok if the bike runs good, delivers turbo boost on the highway.
  13. RussellNash77
    Italy
    I did not check this, I will do and let you know. The strange thing is that even during cold start she don't need choke, not full at all, just a little. Then turning choke of she keep idle very well...
    Pilot screw are moreless 1 and half to 2 turns out.
    Yes the turbo is working fine.
  14. Simmy
    I'm still trying to find the idle sweet spot with mine. Last weekend I tweaked them an additional 1/4 turn which leaves them at 3-1/4 turns out.
    This is too much and I'll be moving them back to about 3 turns.
    In your case I would give them a little more fuel for idle conditions.
    This still does not explain why shutting the fuel pump off helps your idle condition.
  15. ManBot13
    Fairfax, VA
    Simmy, 1/4 turn adjustments to idle are really too large. Rickomatic had a post long ago showing the sweet spot is the width of a dime (when colortuning). Also, each one may need to be adjusted slightly differently. I do remember my turbo being at least 3 turns out (vs the 2 1/4 that is usually prescribed).
    Note that idle really should be what is specified in the manual (1050 i think?). 2000 rpm is too fast and will not be running on the idle circuit. You may also be off in sync if you don't do it at idle. These engines, when properly tuned, will idle like a sewing machine.
    When I had my turbo, it ALWAYS needed choke and would take a mile or two to warm up enough to turn it off. If you don't need any choke, then somehow too much fuel is getting to the engine, either because your idle screw is set to high (this usually accompanies a bad sync and not idling on all four cylinders), or and overflow of fuel (in one bowl, or possibly a leak in the "choke" circuit.
    Returning to your original post, you definitely want to replace pilot screw o-rings, and this should be standard in the kit. If the pilot circuit is clogged, bleeding air, etc, you can't idle off of it. By cracking the idle screw just a bit, you may get everything to "balance out" and get an idle, but you'll have problems off idle, etc.
    chacal likes this.
  16. Simmy
    I was only suggesting the 2000 to see if @RussellNash77 's stalling went away.
    If so I suspect his mixture screws maybe too lean.
    I was not suggesting this as a fix, I can see how that could be interpreted.
    With my bike I had it idling pretty smooth but the RPM's were hesitating a little when returning to idle, when hot.
    My experience in past has always been remedied by tweaking the mixtures a little richer.
    I agree with you 1/4 was too much.
    BTW I've never had any success with the Colortune.
    Whenever I start moving a mixture screw looking for the appropriate coloured feedback I end up way out of whack and usually just return them to 2-1/2 and tweak from there, with the Colortune back in the box.
  17. RussellNash77
    Italy
    Yesterday I tried to raise the idle to 2000 rpm and there was no problem. Anyway I put it back to 1050rpm, the bike has no problem at all and idles correctly.
    I managed to set the pilot screws without removing the fairings and I faced the problem from a different point of view. I compared the temps of the cylinders at the exaust pipes, trying to take the temp at the same distance from the engine, after few minutes at idle I noticed that cylinder 1 was way too hot, cylinder 2 too cold, and 3 and 4 at the same temperature. So I turned out a little pilot screw 1 to rich the mixture and turned in a little pilot screw 2 to lean the mixture. Doing another temp check they are now all 4 at the same level of temperature.
    Then I tried the bike from cold and she reacted normally to choke and ran really nicely! I left her at idle during stoplight and in other situations, she ran really well and no smoke at all.
    I hope this problem was only due to the pilot screws settings, like Simmy I had no luck with colortune in the past...
    If randomly the problem will raise again I think I will try to change the ignition unit, hope is not the case.
  18. Simmy
    If a temp check works this makes tuning a 4-cyl bike much easier.
    What are the temperatures you saw?
    How many degrees do they differ between cylinders?
  19. RussellNash77
    Italy
    It depends where you take the temperature, I decided to take it just below the initial curve of the exaust pipes (to have a reference point) using a
    thermometer gun so to have continuos readings. They were about 98 degrees C. on 3 and 4 but 135 C. on number 1 and something like 80/82 C. on number 2.
    Let's say, a part the numbers, that cylinder 1 was about 35/4o degrees above and cylinder 2 about 20 C. below the other two.
    Tomorrow I will try again, after leaving her at idle for a couple of minutes, to check the temperature.
    It is of course very important to check the temperature at the same distance from the cylinder as it changes really fast.
    I don't know if this procedure is already "normally used" and "acceptable by purists" but, from what I saw and at the moment it is working and think it can help to set the pilot screws, as you said, on 4 cylinders bikes.
  20. RoadsScholar
    RoadsScholar New Member
    USA
    Russell, are you still out there?
    It's not the ignitor unit.
    I've had the same problem, but am unable to find mixture adjustment screws on my BS30s.
    Will you post a photo of their locations?
  21. RoadsScholar
    USA
    Your problem is the OEM fuel pump regulator. Put in a Holley 12-887 ($88) and leave it at the Holley setting. Don't adjust it. You won't believe the difference. Then add a K&N air filter (go to the turbomotorcycles website for instructions) and be amazed once more.
  22. RoadsScholar
    USA
    For many years my Turbo suffered from a random, high-speed, high-boost misfire. Luckily, these bikes do not require that very often as they go fast enough without high boost. The problem persisted and worsened until the bike developed a misfire at idle. After eliminating all the ignition components except the pick-up coils, I suspected a fuel supply problem.
    I checked the petcock, installed an aftermarket gas cap (the OEM caps do not vent properly), and gutted the fuel check valve (they accumulate fuel reside and stick). When it misfired again, I pulled the drain screw from #4 float bowl and observed very little fuel draining. Much less than the inside float bowls (the outside carbs are fed from the inside carbs). Then I knew it was a fuel supply problem.
    First, I installed a Carter P74017 ($28) inline fuel pump. With the proper fittings and fuel lines it fits where the OEM fuel pump was located. I added an automotive fuel filter as the OEM fuel pump has an inline filter. The new fuel pump and filter made no difference so I went back to the 40-year old, 143,775-mile OEM fuel pump and went on to the next fuel supply component – the fuel pump regulator (FPR).
    On the XJ Bikes website, a search for an aftermarket fuel pump regulator yielded the suggestion of using a Holley12-887 ($88) FPR that had worked for another Turbo owner (thank-you). After taking a good look at the OEM FPR, I saw that it was cheaply made and wondered how it ever lasted as long as it did. I suspect the OEM FPR was inadequate from day one.
    Immediately upon start-up with the new FPR, my Turbo shot to 3000 rpm at the same throttle setting where before it idled at 1250 rpm. I took the bike for a test ride, hoping the carbs' needle valves would hold at the new FPR setting (according to the very helpful and knowledgeable folks at Holley the factory setting is 6 psi) and was very thankful the carbs held. Not only was the misfire gone and the throttle response better than ever, the bike now does something it never did before – it fires as soon as I hit the starter button. These bikes are notorious hard-starters. Now I know why.Plug color is a little dark, but the gas today is so dry with all the alcohol content running a bit rich is a good thing. Besides, it now runs and sounds like I put a hotter cam in it. I don't notice any difference in fuel mileage, but my Turbo now runs at lower boost (2 psi) at the same speeds (60-70 mph) where it used to pull 4 psi.
    Apparently, the OEM FPR has been fuel starving this bike since new. The dyno chart also reveals this. I feel very certain it has picked up a few horsepower too (increasing fuel pressure is an old hot rodders trick).If you install the Holley FPR on your bike, I think you will be amazed at how much better it runs especially if you install a K&N air filter in place of the OEM set up (for details on this visit the website. My suggestion? Every Yamaha Turbo owner should install a Holley FPR! - Backroad Bob
  23. ManBot13
    Fairfax, VA
    @Roads Scholar I would be careful removing or gutting the fuel check valve. The purpose of this valve is to not let the residual fuel in the lines and pump flow back into the carbs and overflow them when the bike is shut off. It's also a safety precaution in case the petcock was to fail. I sold my Turbo at the beginning of the pandemic, but once I corrected the sticky valve problem, it had no issue with fuel delivery. As long as it's run frequently enough (one of the reasons I sold it, I wasn't riding it enough for it to be happy) it shouldn't accumulate fuel residue.
    As for the holly FPR, it's great that there's a substitution available and for a reasonable price. I was always worried about the regulator failing on my Turbo and having no alternative. Again, I suspect that your stock regulator may have failed (they are non-repairable or adjustable), because the stock one worked perfectly on my Turbo and I was running 11psi boost with a manual boost controller.
    I think running a higher pressure FPR necessarily requires a higher pressure pump as well, as the pump needs to over come boost pressures and the regulator pressure. Stock pump is rated to 14psi, so this could limit boost to 8 psi (fine for stock waste gate setting at 7psi, but would be an issue using power up kit or manual boost controller). Just another consideration.
    I suspect the effect of your higher pressure FPR is to effectively raise the fuel level in the bowls. This can change the amount of fuel mixture (I think at all RPM). As long as you don't over flow the bowls (it sounds like you didn't) then you've effectively set them higher without bending any float tabs. Again, I recommend wet setting the fuel level, but maybe this is a novel way to adjust fuel levels (adjusting the pressure regulator) without having to pull the rack (assuming all four carbs are even to start with).
  24. RoadsScholar
    USA
    Thank you for your reply. All good points. I have put 800 miles on the Turbo this summer using this set-up and encountered no problems. I have had the petcock fail, but that was thirty years ago and the check valve didn't stop the carbs from filling the crankcase with fuel. Luckily, I realized what was happening as the bike was warming up. Replaced the gasket and it's held ever since. It did pre-maturely cause my original turbo seal to go bad (slight smoke at start up), but that was at 110.000 miles (2002) and I had purchased two used spares over the years. I have a piece of ribbon on my key ring to remind me to shut the petcock off. So far, so good.
    My bike has never been stored. Even in the mountains here where I am lucky to have five months of good riding weather (only three months guaranteed without snow), I always started the bike at least every two weeks (except when it was below zero). Despite my best efforts of always periodically running the bike, the fuel line check valve still stuck so I gutted it rather than have it hang up and stop the bike from starting.
    I did wet check the float levels and the levels were all fine. I think the problem is keeping them filled once boost begins.The stock fuel pump supplies more than enough fuel for the new FPR even running 15 psi (wastegate disconnected). There's a Yamaha Turbo dyno run on YouTube set up like this and it makes 90 hp and 68 ft-lbs. I believe it!
