86 xj700 spark plug caps
Discussion in 'XJ Technical Chat' started by to the max, May 1, 2022.
  1. to the max
    to the max Member
    Akron, Ohio
    my 1 and 4 plugs both have 10k caps on them. 2 and 3 have 5k caps... what are they supposed to be?
    i'm using BP8ES plugs.
    sorry for yet another caps thread
    since i posted this, i found this...
    XJ700 air-cooled models:
    Pick-up coils:
    120 ohms +/- 20% = 96 ohms to 144 ohms acceptable range
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.7 ohms +/- 10% = 2.43 ohms - 2.97 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    12K ohms +/- 20% = 9,600 ohms - 14,400 ohms acceptable range
    Spark plug caps:
    1985 N/NC models: 5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range
    1986 S/SC models: 10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
    Spark plugs:
    1985 N/NC models: 0 ohms per plug
    1986 S/SC models: 5K ohms per plug
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
  3. to the max
    to the max Member
    Akron, Ohio
    That’s how you set yours up and it worked good?
  4. Huntchuks
    East Rochester, NY
    Seems to.
  5. SQLGuy
    SQLGuy Well-Known Member
    Wow. I wonder whether the coils are different in '86, too. That's quite a difference in burn time.
  6. to the max
    to the max Member
    Akron, Ohio
    My coils have 12k. After reading a few threads in here, It appears that we can’t really trust any of the service manuals. I did what Huntchunks said. I plan on doing a colortune so after I do all that I’ll come back here and post my whole setup
