stuck throttle
Discussion in 'XJ Technical Chat' started by oscarcat, Jun 6, 2023.
  1. oscarcat
    oscarcat New Member
    scotland
    hi. looking for help with 750 maxim stuck throttle. cable lubed up. attached at handle the throttle turn free. but as soon as i attach to the carb retainer, the throttle wont turn. is the link at the carbs supposed to be attached to a spring of some kind (mine is not), the link moves freely but i think it should be attached to something to cause the throttle at the handle to snap back . thanks
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Each carb in the rack has a spring at the adjustment screws. They all pull together and should provide lots of snapback to pull the cable back to idle position.
  3. Franz
    Franz Well-Known Member
    Scotland UK.
    16860782698365867386110167005264.jpg Is the outer cable in its seat.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    Are you booking the throttle cable to the choke lever instead? Seen it happen on here before.
    Franz and Huntchuks like this.
  5. oscarcat
    oscarcat New Member
    scotland
    hi Franz,
    the choke cable is pulling correctly, i can see the carburetor bar moving - but the throttle link is bot attached and has very free movement, its as if the link has detached from a retaining spring, i might have to take the carbs out to have a look, thanks Ken
  6. Franz
    Scotland UK.
    Can you post a video of what is happening?
  7. oscarcat
    oscarcat New Member
    scotland
    hi Franz. i will post up video ill get my son to help. i took photos and trying to upload. thanks again
  8. Franz
    Scotland UK.
    I think you need five posts before you can upload photos.
  9. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    do you have the short link cable attached, between the throttle cable and the carb , shown here at the bottom of the picture 077.JPG
  10. oscarcat
    oscarcat New Member
    scotland
    ah thanks, I cant see that on my bike, ill have a look later -i think something like this has become detached, thanks
  11. oscarcat
    oscarcat New Member
    scotland
    image.jpg IMG_20230607_175806_HDR.jpg IMG_20230607_175830.jpg IMG_20230607_175843.jpg
  12. oscarcat
    oscarcat New Member
    scotland
  13. Franz
    Scotland UK.
    Does the throttle shaft turn if you attach a wire to the bracket the throttle cable fits into and pull it? Have the carburettors been rebuilt?
    If you remove the throttle cable from the carburettor then turn the twist grip to the fully open position grip the outer cable and pull the inner cable. Does it operate freely?
  14. oscarcat
    oscarcat New Member
    scotland
  15. oscarcat
    oscarcat New Member
    scotland
    the throttle shaft moves freely with no cable attached but solid when throttle attached at both ends. cable is moving free within cable cover when i twist grip when detached from carb link as in photo. also the throttle link has 2 pivots like an elbow, at the bottom of the link and at the arm where cable attached
  16. oscarcat
    oscarcat New Member
    scotland
  17. oscarcat
    oscarcat New Member
    scotland
    hi franz hope you can open videos i have attached
  18. Franz
    Scotland UK.
    Have you got the throttle cable fitted correctly to the twist grip? I can see your video.
  19. Franz
    Scotland UK.
    Do you have this elbow arrowed on your machine?
  20. Franz
    Scotland UK.
    Is the cable fitted correctly in the twist grip?
  21. Franz
    Scotland UK.
    How many millimetres is there when the cable is attached? How long have you had the bike and was it running before? I am wondering if you have the correct cable or it is attached incorrectly at the twist grip.
  22. jayrodoh
    jayrodoh YimYam
    Cleveland
    It appears in the quick videos that he is just flopping the linkage around and not actually opening the throttles. The cable will pull that linkage up to open the throttle plates, the piece is supposed to flop around without a cable as it's on a pivot.
    Can you get a video with the cable attached? It seems from my view/best guess that the throttle shaft is frozen. Did this run?
  23. oscarcat
    oscarcat New Member
    scotland
    https://photos.app.goo.gl/oadnBSf1p5B6pQCz9
    ah thanks for your replies. everything appears to be right at the twist grip. my bike has the elbow part that retains the cable. what is the purpose of the large spring next to the elbow. should it move when cable turned to open carbs. thats not happening . thanks
  24. oscarcat
    oscarcat New Member
    scotland
    hi thanks for your help the spring next to the thottle cable linkage is solid. should i be able to move it manually with screwdriver to open carbs. thanks. correct the thottle shaft is floppy and appears to do nothing
  25. Franz
    Scotland UK.
    Jayrodoh is right about the cable lifting the pivot bar. That spring is one that shuts the throttle shaft. Here are my carburettors with a piece of wire attached. Have the throttle plates ever been removed and refitted? Can you turn the large idle screw at the back of the carburettors clockwise?
  26. Franz
    Scotland UK.
    I tried to upload a video of the mechanism moving and returning under spring pressure but file was too large. Fit a piece of scrap wire as l have in the photos to see if the mechanism is free and not binding up.
  27. Franz
    Scotland UK.
    Is your bracket like this?
  28. Franz
    Scotland UK.
    I wonder if one of the two throttle shaft nuts are too tight binding the throttle shaft and preventing the twist grip opening the throttles?
  29. Franz
    Scotland UK.
    The large spring is one of the springs that shuts the throttle shaft.
  30. oscarcat
    oscarcat New Member
    scotland
    ah ok well that spring is solid and wont move manually either. carbs out to have a look ?. thanks
  31. Franz
    Scotland UK.
    Yes looks like the throttle shaft is binding. These are from a 750
  32. oscarcat
    oscarcat New Member
    scotland
    thanks Franz, is this repairable or new set of carbs ? - thanks for your help
  33. Franz
    Scotland UK.
    You should try and repair your carburettors. There is plenty of information on here and many people who have overhauled their carburettors. Can you move the throttle shaft when the carburettors are off the bike? Where are you from in Scotland? The carburettors in the picture were overhauled.
    Timbox likes this.
  34. oscarcat
    oscarcat New Member
    scotland
    hi the throttle shaft doesn't move. only the elbow part that the cable attaches to. haha was wondin where you were. im in ellon aberdeenshire thanks again
  35. Huntchuks
    East Rochester, NY
    Remove the carb rack. Something is jammed or the main spring coils are rusted together.
    oscarcat likes this.
  36. Franz
    Scotland UK.
    Can you turn the idle screw at the back of carburettors? I have been to Ellon years ago l live near Glasgow.
  37. oscarcat
    oscarcat New Member
    scotland
    fair play. im going to have a poke about at weekend & see what i can see. cheers
  38. oscarcat
    oscarcat New Member
    scotland
    thanks. thats possible it has sat a while ill take carbs out for a look . thanks
  39. chacal
    Probably something jammed, as the springs are made from stainless steel (I believe), as I've never seen a rusted set (dirty, yes, but never rusted). A number of things can cause the the butterflies to jam:
    - incorrect carb rack assembly: if the rack screws were ever loosened (doesn't even require removal of the carbs, just loosening the screws will allow the carbs to walk a bit and get out of linear alignment with each other, and then the brackets on the throttle shafts bind against each other).
    - butterfly valves re-installed incorrectly (off-center, or in some cases, upside down).
    - extreme oxidation of the carb bodies
    - incorrect re-assembly of the throttle shaft, brackets, and springs.......although the springs look all the same, they are actually all different and although you can "force" the spring from (example) carb #1 onto carb #2, you'll end up with either a really loose or a coil-bound spring.
    - bent throttle shafts. Rare, but it happens.
    - other reasons.
  40. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    I don't know about "extreme oxidation" @chacal , both my Hitachis and one set of Mikunis were seized solid when I got them - UK weather can be harsh...
    So I would say not uncommon to see these seized solid..
  41. chacal
    Well, perhaps, if they've set outside for an extended period of time. We've certainly seen carb sets where the shafts/butterflies are seized, but it's never been due to seized throttle shaft return springs, it's always due to some other reason.
    The images and video that oscarcat posted don't show any corrosion of the springs.
  42. Minimutly
    West Wales, uk
    Yes I meant the shafts, not the springs
  43. oscarcat
    oscarcat New Member
    scotland
    hi franz. got it sussed carbs out and sprayed with carb cleaner. free as a bird . hooked all up now starter button not workin n throttle very slow to snap back. . gettin there. avin a beer n watchin glasto. try again later
  44. Franz
    Scotland UK.
    If you have the original glass tube fuse box replace it with a blade type one. Clean the old fuse clips and check for voltage at the solenoid harness connector. Will it turn over if you bridge the solenoid contacts with a screwdriver? Mabe power is not getting to the start button.
  45. oscarcat
    oscarcat New Member
    scotland
    cheers franz must be an issue one on the fuses blown
