easy oil filter ????
Discussion in 'XJ Technical Chat' started by Old-Grunt, Feb 27, 2008.
  1. Old-Grunt
    Old-Grunt Member
    What is part# for Fram oil filter that fits the old XJ's
  2. 07spacker
    07spacker Member
    Utah
    CH6003 for '82 maxim good luck finding it though
  3. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    I get my Fram oil filter from my local NAPA dealer.
  4. 07spacker
    07spacker Member
    Utah
    your lucky that your local store believes in motorcycle filters... grrrrrr
  5. lostboy
    They have to order it in. It takes a day to show up I get three at a time.
  6. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    I believe I've seen them at walmart before, I've never found them hard to find
  7. RickCoMatic
    They're not hard to find. They're on a lot more Bikes than just the XJ-Series.
    I get the Fram from AutoZone or STP from other retailers and get BOTH O-rings needed for the job ... right in the box!
    For less than what you'd spend for the Big O-ring, alone, at the Dealer ... you get the Filter and 2 O-rings.
    That's a Goood Deal!
  8. Old-Grunt
    Old-Grunt Member
    Usually I just order at nearby autoparts store,but I am going to Town tommorrow(yes I'm a old hayseed LOL) and was going to check walmart in Topeka to see if they carry them .
  9. MiCarl
    The Wal*Mart here doesn't stock them.
    I ordered a bunch of them from Chacal. He stocks them.
  10. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Mills Fleet Farm carries them here.
    A word to the wise: Don't use Fram spin on filters. They changed owners and changed the manufacturing process a couple years ago. Now they are junk and perhaps the worst spin on filter you can use. The bypass valve inside them was made cheaper and does not work properly. Infact it lets oil thru without filtering it at all! There are sites that explain it all, and if you cut on apart, you will see for yourself.
    I see most auto parts stores have one whole section of just Fram filters and sell tons of them to unsuspecting customers. The air filters seem to be alright and I use those, but I won't buy another Fram spin-on oil filter. PD
  11. Altus
    Altus Active Member
    London, Ontario
    Here's a quick list of Yamaha's that use the CH6003 filter:
    Fram      WIX      Purolator      Height      OD      ID
    CH6003  24934  ML16803     1.441     2.996   0.768
    XS360 1976-1977
    FZR400 R 1990
    FZR400 R 1988
    XS400 Maxim, Seca 1977-1983
    XJ550 Maxim, Seca 1981-1983
    FJ600 1984-1985
    FZ600 1986-1988
    FZR600 1989-1990
    YX600 Radian 1986-1990
    XJ650 Maxim 1982-1983
    XJ650 Maxim Midnight 1981
    XJ650 Maxim 1980
    XJ650LJ/LK Seca Turbo 1982-83
    XJ650RJ Seca 1982
    XJ700 Maxim 1985-1986
    XJ750 Maxim 1983
    XJ750 Maxim, Seca 1982
    XJ750 Seca 1981-1983
    XJ900 Seca 1983
  12. Oldgoat
    Oldgoat Member
    Montreal
    I bought 3 from Chacal.
  13. Danilo
    Danilo Member
    Vancouver canada
    Having bought/used a 'few' The Yama filter IS of a lot higher quality, if that matters to you.
  14. abames
    abames Member
    Northwestern Ontario Canada
    Hate to resurect older thread but could anyone confirm if this filter also fits the 84 XJ 750RL, as i couldn't find it locally to compare and don't wanna order wrong one if it doesn't fit.
    Many Thx
    A.B.Ames
  15. sgknies
    sgknies Member
    Elkview, WV
    Believe it or not, I got mine from my local Advance Auto store. They also carry other maintenance parts for my 80 xj650
  16. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Advance Auto, They had an oil filter for my XJ650G and one for my XS750. Only had stock champion plugs though, no plats.
  17. brtsvg
    brtsvg Member
    Davenport, IA
    I agree with PainterD. This change in FRAM manufacturing quaity has been well documented in many web places. There's a reason Wal-Mart carries only FRAM. I have since switched all my car oil filters to Purolators, readily available at Mills Fleet Farm here in MN for about $3 each. Better quality product.
    Paul
  18. weoxstan
    weoxstan Member
    Central Michigan
    I also got mine at Advance Auto. Filter and both o-rings was about $3.
  19. abames
    abames Member
    Thx all,
    But there are no such stores where i live (Small town/city Canada). Also I'm sorry as I didn't want to start the brand debate was just trying to see if My 84 XJ 750 uses the same filter as the bikes listed in this thread (as no place in my town lists my bike in their filter books).
    I did though find out it is the same, I forgot the XJCD (i just recently recieved, many thx to Dwayne Verhey) had parts diagrams so I was able to compare the different bike filter #s and they match.
    again, mny Thx
    A.B.Ames
  20. PSteele
    PSteele Member
    Nova Scotia, Canada
    weoxstan and Rick:
    Are we talking an easy replacement spin-on or one that needs an adapter?
    Any help appreciated guys.
  21. rdbhere2
    rdbhere2 Member
    anyone have a part number for a xj650 spin on oil filter? thanks
  22. Altus
    Altus Active Member
    London, Ontario
    For those wanting to check what bike uses what filter, I personally like this site:
    Motorcycle Oil Filter Cross Reference
    As for the spin-on adapter, there is no "part number" as this is an aftermarket creation from some enterprising XJ owners - Mike Oberle specifically. Don't know if the one Chacal carries is the same, or a different source.
  23. PaulT
    PaulT Member
    Wilton, NH
    I found one (just one) at VIP auto parts (new england chain).
    My 81 Seca 550 has after market 4 into 1 exhaust, so the oil filter cover wouldn't come completely off the bike. What a PITA that was. managed to turn it far enough to get the filter and seal out and new ones in.
  24. pvtschultz
    pvtschultz Member
    Milwaukee, WI Area
    Yup, my local Advance had mine in stock also.
