WTB XJ550 Carb
Discussion in 'For Sale, Trade/Swap, Wanted' started by shotgunjoe, Apr 15, 2012.
  1. shotgunjoe
    shotgunjoe New Member
    Long story short, I need the left outer carb, had a problem with the pilot jet, now I have a problem with an easy out...
    I will buy the whole set if need be, but I need this to be as cheap as possible. I'm on a "unemployed single father of three" kind of budget.
    Please email me, as I've had some weird issues with the PM system... or I'm old and un-forum-edumucated.
    rustydatsun510 at hot(mail) dot com
    Thanks guys.
  2. shotgunjoe
    still need...
  3. moellear
    moellear Member
    Lima, Ohio
    hmm I will keep my eyes open. is this for a seca or maxim?? I spoke with someone via telephone near my area last Sunday evening who had a very similar situation, and failed to mention about this site. what's your location? it'd be crazy if you were the same guy! sorry that's not much help though I know...I don't have an extra set lying around
    I started taking my 550 carbs apart last evening *gulp* and needless to say it is in sorry shape as well. hope I don't stumble into what you guys have gotten yourselves into *knocks on wood*
  4. hogfiddles
    550 maxim and 550 seca's have the same engine, so carbs should be the same, too.
    Dave F
  5. shotgunjoe
    Well... I found a great set today at a local shop. They'd been on the shelf for quite some time.
    The old guy who runs the place made me feel a little silly... "dont even think about trying to remove the jets without first applying heat and penetrating fluid"... working on bikes for 50 years teaches you a few things, and I'll take his word as gospel.
  6. moellear
    moellear Member
    Lima, Ohio
    Kroil !!!!
    invest in the stuff. it works & I even convinced my dad to use it too. he's hard-headed machinist who uses it and was surprised as well.
  7. bigfitz52
    Not exactly.
    The 550 Seca and 550 Maxim motors have different cams; and as a result the carbs have some internal differences although they do use the same bodies.
    The PILOT AIR jet and main JET NEEDLE are different and would need to be retained from the original carb if swapping between a Seca and Maxim.
    BTW, there are some transmission drive-ratio differences between the two as well; the motors only LOOK the same.
  8. shotgunjoe
    Thanks for the info bigfitz. I'll have to check those now... I was planning on rejetting them anyway, since the bike came with a kerker 4-1 exhaust and stock jetting.
  9. 4nik8r
    4nik8r Active Member
    Ottawa, ON, Canada
    Is it just the cams, and nothing else, that is different? I thought that the compression ratio and/or heads were also different. I have a line on a maxim 550 motor to rebuild my seca 550 motor, but not sure what I can actually use.
  10. hogfiddles
    Just stick the engine in and go.
    Franz likes this.
  11. hogfiddles
    ALL info is pulled straight from the INFORMATION OVERLOAD HOUR
    XJ550 Maxim and Seca cams can be swapped between these engines (but not with any of the 650-up engines). The 550 Seca cams are "hotter", they have more lift, and probably also have increased duration and possibly overlap.
    tech:
    XJ550 Maxim
    Intake Lift: 6.80mm
    Exhaust Lift: 6.80mm
    Duration: not given
    Overlap: not given
    XJ550 Seca:
    Intake Lift: 7.80mm
    Exhaust Lift: 7.10mm
    Duration: not given
    Overlap: not given
    carbs are the same... small differences in jetting:
    XJ550 Models:
    Years & Models: 1981-83 XJ550 Maxim North American models
    Carb Manufacturer: Mikuni
    Carb Series: BS28
    Carb Model ID: 5K500
    Main FUEL Jet Size: #112.5
    Pilot FUEL Jet Size: #35
    Main AIR Jet Size: #70 (non-removable, in carb throat)
    Pilot AIR Jet Size: #165
    AIR COMPENSATOR Jet Size: not used.
    Starter FUEL Jet Size: #35 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #4GN
    Main needle JET Size: #O-8 (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 2mm +/- 1mm (.08" +/- .039")
    Idle RPM's: 1,200 rpms
    Vacuum reading at idle: not specified
    Vacuum, allowable difference between cylinders, at idle: not given
    Although not part of your carbs, your valve clearances should be considered as part of your "intake system", so here are those specs, too. Note that valve clearances should be measured with the engine "cold", meaning 70-degrees Fahrenheit or less:
    Valve Clearance Intake: 0.11 - 0.15mm ( = 0.004 - 0.006")
    Valve Clearance Exhaust: 0.16 - 0.20mm (= 0.006 - 0.008")
    Years & Models: 1981-83 XJ550 Seca North American models
    Carb Series: BS28
    Carb Model ID: 4U800
    Pilot AIR Jet Size: #170
    Main jet NEEDLE ID: #4GZ11
  12. 4nik8r
    Ottawa, ON, Canada
    Decided to rebuild the "parts bike" Seca engine, now that I got the broken plug out. I have a gasket kit on order and just trying to clean it up. Thanks for posting those clearances; once its all together again I'll check them and see if I need to do any shim swaps. Now, anyone know where I can source an adaptor for a compression tester? Mine has a 14mm x 1.5 end but I need a 12mm x 1.25 to fit the spark plug hole. No one has anything in Cantada anymore.
    hogfiddles likes this.
