  1. Dan Gardner
    Minneapolis, MN
    Are you thinking about using the O2 sensor for just tweaking the idle mixture? Or are you thinking you will do some rejetting? Just curious.
    Each individual header pipe has a test port of some sort - any way to use those so you can measure each cylinder individually??
    Edit - I see you have an aftermarket header, so nevermind the question about the test ports on the stock header pipes. Although it did get me thinking about maybe taking some crusty old header pipes and having O2 sensor bungs installed on them.
  2. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    Just want to dial-in the mixture as a whole using a wideband and to get a feel for what's going on during the 6k bog. Don't need exact numbers just a snapshot.
  3. Dave in Ireland
    Ireland
    It's what I'm doing on my GS850
    One bung just after the collector, Scorpion gauge and wideband Bosch sensor.
    But... I'm only using a single carb. Doing it with multis is more problematical.
  4. Brhatweed
    Mora MN
    That's okay Ive been called problematical all my life. :)
  5. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Spent a couple of hours tig welding the corroded away threaded corners by the camchain tunnel on a set of xj900 jugs. Took a bit of sussing out and preheating. Now in the process of machining the blobs away to original shape. Before drilling and tapping.
    Will it be worth the bother? It's likely to be 6 hours of workshop time, so not likely with the low cost of good replacements, but good to know it's doable.
    Big thanks to @Franz for supplying them, the 900 engine I have is an unknown, so who knows if I will use these (they look to have very little wear).
    Franz likes this.
  6. Franz
    Franz Well-Known Member
    Scotland UK.
    The engine had 34,000 miles on it when I got the bike.
  7. Minimutly
    West Wales, uk
    Got a pic here..
    Dave in Ireland, Brhatweed and Franz like this.
  8. Franz
    Scotland UK.
    Looking a lot better already.
    Brhatweed likes this.
  9. Timbox
    Timbox Well-Known Member
    No riding in the Midwest till the roads are cleaner. Unless the bike has on/off tires. I am also on the upper end of the age scale, so if I went down, it takes longer to heal. You enjoy that ride, it sure is tempting.
  10. Brhatweed
    Mora MN
    If our brief warmup passes 35F I'm putting some highway miles on. Also found two cheap-azz GoPro HERO-2 cams for the bike, one front and the other back to catch the whoever rear ends me while playing on their phone... too much stupid behind those smartphones.
    Franz and Dave in Ireland like this.
  11. Brhatweed
    Mora MN
    And it got above 35F so I got the speedo above 70... bike fired right off like I just parked the night before. No fussin' with the carbs or battery as it was on a small milliamp charger. Roads are a little wet and salty but I stayed on the main highways only goosing it to the century mark on a dry stretch. Yeah it was a good day on the SECA
  12. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Brrrr.
  13. Brhatweed
    Mora MN
    Yeah a little chilly. I have insulated work pants which gave me a good barrier and a winter jacket over the leather as a windbreaker the only thing really cold was my big ol' nose. Not sure the engine cares for the cold blast on the front but it ran well. Might get out tomorrow before we head into the deep freeze... -9F for a forecast high.
  14. Timbox
    You have to get out there sometimes, just for mental health sake. I get it, that and seeing all the hard work paying off.
  15. Dan Gardner
    Minneapolis, MN
    Bonus points for going out next Monday in the sub-zero climate!!
  16. Brhatweed
    Mora MN
    I will come down and do a burnout in your driveway!
    Seriously I'm not going out in that below zero if I don't have to but do have a question for the experienced; looking at changing over to a drag style handlebar and I want to go with a top mount master, what's the consensus on this? I've been looking thru the Brakes Section-J of the tech page and I really don't see anything yay or nay other than the 750 SECA uses the cable op master and that the larger bore cylinders will be faster acting. Okay so the 650 Maxim is a single caliper and I'm assuming would take lots of lever to move enough fluid, same with the 550 SECA so would say a 750 Maxim or 650 SECA have enough to work the brakes with the anti-dive and are these a 7/8" bar? What other models would be compatible with this switch? My big reason for this is I don't particularly like the cable-op master to begin with or the farm implement style 750 SECA bars but I want to check with the experienced before committing.
    Thanks in advance.
  17. Minimutly
    West Wales, uk
    Update. I won't skim it now, it can wait until the machine is set up.
    Damn, why file too large?
  18. Franz
    Scotland UK.
    Strange your picture posted the last time.
  19. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Emgo make 7/8 bars in any shape
    Make sure they have at least several inches of rise to avoid clearance between the choke lever and the tank.
    650 Seca master should work well then order custom SS lines
  20. Brhatweed
    Mora MN
    Thanks Simmy :) The bars I'm looking at are take-off Drag Specialties from a 650 Maxim but as you pointed out the riser clearance this is something I don't have. For $10.00 I'm going to take a chance and if they bump then I have my answer and a spare set of bars to pass along to someone who could use them.
  21. Tristan Kernick
    Tristan Kernick Active Member
    Pittsburgh, PA
    Since the server migration, I haven’t been able to post full-size iPhone pictures in messages. If you’re posting from the phone that took the pictures, there’s a way to select “Medium” quality instead of “full” quality when you upload. That worked for me.
    For example, here’s a carb I was in the process of taking apart yesterday, so I could replace the body with one I bought from Len.
  22. Brhatweed
    Mora MN
    Gave the drag style bars a try on my SECA this afternoon... a no-go using the stock headstock mounts. Basically I pulled my OE bars out of the clamps and pushed them out of the way and dropped the drag bars in place, not enough side clearance on full turns for my hands to the tank and as Simmy pointed out the choke would hit the tank as well.
    So for now it's the stock ugly bars and their mounting tabs for the plastics that broke off last summer. Might just cut & grind them off and re-spray the bars this summer.
    Tristan Kernick likes this.
  23. Tristan Kernick
    Pittsburgh, PA
    I finally finished my laundry list of winter maintenance items on my 650 Maxim. Over the past month and a half, I have:
    • Rebuilt caliper
    • Rebuilt master cylinder
    • Replaced brake hoses with stainless braided lines
    • Replaced front brake pads
    • Checked valve clearances, replaced 5 shims
    • Replaced ancient valve cover gasket
    • Replaced carb #2 body due to cracked float post
    • Set carb fuel levels, tuned, and synched
    • …oh, and apparently put the freaking horn on correctly, since the previous owner had it in the wrong place. Never noticed until I took the valve cover off.
    Last thing I’d like to do before next season is get new tires. Mine seem to be in great condition, but they’re from 2011. Their age does not inspire confidence.
  24. Franz
    Scotland UK.
    Don't forget the rear brake shoes they delaminate and you don't want your back wheel locking up at speed.
  25. Tristan Kernick
    Pittsburgh, PA
    Indeed, that was already done before the end of the riding season. My shoes didn’t show any signs of delamination, but they were soooooo crusty. Even though I was told to expect worse braking performance before the new shoes are broken in, the rear brake’s effectiveness improved immediately. Was definitely a good call.
  26. Brhatweed
    Mora MN
    Bad brakes are not worth the savings.
  27. Huntchuks
    East Rochester, NY
    Try these:
    https://www.amazon.com/dp/B07TWF8TYF?ref=fed_asin_title&th=1
  28. Tristan Kernick
    Pittsburgh, PA
    For anyone curious about what happens when you install the horn backwards, check out this groove it wore into the valve cover.
    The locator tab on the little mounting bracket technically still lines up when the horn is mounted backwards. But still, I don’t know how you could install it with the noisemaker pointed towards the rider and not think something is up.
  29. Brhatweed
    Mora MN
    It only proves ya can't fix stupid.
  30. chacal
    Just when you think that you've seen it all...............
    Tristan Kernick and Brhatweed like this.
  31. Brhatweed
    Mora MN
    Picked up a handful of older GoPro action cameras for $15/ea with the waterproof clamshells, numerous batteries and aftermarket chargers. Got three of the HERO3+ models and one HERO2 so I'm thinking the 3+ on the bike, front, back and helmet should about cover any mishaps with those who insist on not seeing motorcycles while playing on the phone behind the wheel. The HERO2 has already found a home on my 05 Impala-SS rear window.
    Franz likes this.
  32. chacal
    Then you can get really cool shots like these guys:
    ksigurdsen likes this.
  33. chacal
  34. chacal
  35. Brhatweed
    Mora MN
    He gave that bike a serious spanking! I've checked out a few of those FNF vids, no way I'm doing near 200 thru traffic like that, there's a reason I turned 55 years old but I may post a run or two of my SECA at top speed on a known dead road.
  36. chacal
    Yeah, watching some of those videos makes me break out in a scold sweat (and wanting to borrow my buddies Busa and go tearing down the freeway at warp(ed) speeds). If I was an insurance agent I sure wouldn't write any life or health insurance policies for them.....
    But just like any external drug, an adrenaline rush is an internal drug which can become an all-encompassing addiction that requires a liter bike and a crowded roadway to satiate.
  37. Brhatweed
    Mora MN
    The neighbor kid has a first gen 'Busa, I have more riding experience than his parents have been alive and it still scares the $#!T outta me. Honestly I hope his time in basic has matured him some.
  38. Timbox
    Been very hard for me to stay away from lager faster bikes. Now that I am very close to 60 yrs, I find myself on the V twins more. Low end torque when needed, with a top speed of maybe 100. I lived in the Warner Robins area for a while and had a ZX14, I used to drive on very nice roads faster then you should be. No one was hurt and I normally pre-road the route for gravel and other road issues. There is really nothing as cheap and easy access to it that compares.
    Franz and Brhatweed like this.
  39. Brhatweed
    Mora MN
    What a disappointment! Those 130 Watt Hella H3 halogens I'm running in my lower light are NOT what they're advertising. I went to use my spare as a replacement in another fog light believing it was 130 watts but when compared to the existing good bulb it was the same intensity so I measured it with my meter. 13.65 volts at the terminal with a measured 7.45 amps of current using a Fluke 77 meter... 101.6 watts??? This is NOT the 130 watts that's advertised on the package. Okay so maybe a bum bulb. Pulled the one from my SECA and checked it, 7.31 amps on the power supply at 13.65 volts.
    Come Hella not high watta... :(
  40. Dave in Ireland
    Ireland
    What current draw do you get if you set the power supply to 14.5V
  41. Brhatweed
    Mora MN
    7.78 amps at 14.50v this voltage measured at load and this comes out to only 112.8 watts.
    My bench power supply is a Motorola R1011B which can do 0-40 volts at 0-40 amps... it can spin my 750 over solo without a battery.
    chacal and Timbox like this.
  42. chacal
    That's pretty impressive......
  43. Dave in Ireland
    Ireland
    Close enough for marketing purposes.
  44. Andrew Nichols
    Andrew Nichols Active Member
    Minneapolis, MN
    Saved myself $5 plus gas by repurposing an empty Harbor Freight bin to use for my valve shims.
  45. Brhatweed
    Mora MN
    Being only 90 miles north of you I could repurpose a few of those in my 750 SECA :) just sayin. Hello from Mora
  46. Andrew Nichols
    Minneapolis, MN
    I currently have three 900 Secas, a 750 Seca, a 550 Seca, and a 550 Maxim. I just started checking shims last summer but I've found I really use 260, 265, 270, and 275 so if you're in need of some of the other ones, let me know.
    I've been using that bolt on tool to hold down the shim buckets but it must've slipped off and now I have a shim that popped out of the motor. I ordered one of the hemispherical wrenches to help me reinsert the shim.
  47. Brhatweed
    Mora MN
    Might have to make a trip down for a handshake
    Andrew Nichols likes this.
  48. Brhatweed
    Mora MN
    Got the bike into my service area for some needed work. My supervisor did a lengthy Cat Scan and said I really need to get busy. He found some electrical gremlins and said I should replace the front pads. Might do the top mount brake master conversion and a few additions that include two LED indicators in the atari, one will be a red to indicate when the rear brake light is actually on and the other a yellow for the fog as I sometimes hit the switch during the day.
    Other work will be a mass cleaning as I didn't really clean things off when the fork seals popped last summer and I need to replace the hold down grommets after shimming the valves. Should keep me busy for a while.
    Checking the carburetors
    Hey Hooman! I found the problem!!
  49. Brhatweed
    Mora MN
    Can't argue with these numbers, triple checked them on their base circle and verified the feelers with a digital caliper. Only issue I found in the engine itself is #2 plug shows it's running rich.
  50. Brhatweed
    Mora MN
    Continued the checks today doing a compression test and found everything to be waaayyy below the norm. Found the jugs to be 76-42-72-38 in order and the pressures didn't go up much with shots of oil. Last night I had the good sense to pull the header off while cleaning the front of the engine and during the compression rounds heard the tell-tale "sskkk..sskkk.sskkk. from the exhaust ports... yes it's time for a full-on valve job. To confirm this I made an adapter to pressure the cylinders with shop air locking the one in question to TDC in 5th wheel rear locked and confirmed the leakage is the exhaust and not so much the rings as it showed very little blow-by from the vent at 150 PSI, hot it's a bit more and the inside of the air box is oily.
    Was hoping I didn't have to go down this road but my gut tells me if I don't I'm going to have a handful of burnt valves, also looking at rings going this deep as they're 44 years old now and not that expensive.
    The games are about to begin.
