XJ900 Rear Wheel Obsolete Bearing - Work-a-Round (hopefully)
Discussion in 'XJ Modifications' started by cds1984, Mar 9, 2025.
  1. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Long winded story (mostly finding an engineer who didn't sneer at me for such a small job)
    My rear wheel on the XJ900 had a bad bearing, which also ate out the wheel hub a bit so it has been a bit wobbly to ride on.
    I bought a 2nd hand wheel and tarted it up (paint), haven't fitted it yet, but it looks good... needs a tyre on it still.
    Finding that bearing for an affordable price is not possible and I figured there must be a way around it. We can't just throw away our XJ900 because of a single custom Yamaha bearing surely!
    Bearing: 93302-20306-00
    Basically I eventually got a chap 'Precision Shims' in Australia to make me a spacer $33AUD out of tool steel and use an off the shelf bearing to be the actual bearing with a spacer on top, so to speak.
    NSK 3203B-2RSRTNG $55AUD
    or
    NTN 63203LLUNTN $62AUD
    To be fair I bought both these bearings in 2021... and I took the Yamaha (KOYO) bearing down to 2 different bearing places and they sold me these. In other words I put my trust in those guys.
    17mmID x 24mmOD x 3.5mmWidth
    Here are some pics of it fitted.
    The idea was to use a false axle and put it in the wheel while fitting so the spacer was in alignment.
    The axle would pop the false axle out of the final drive.
    But... I don't think it is necessary as the spacer can't actually fall too far out of line anyway... even so I have made one if it is an issue.
    I can't see any real reason that this won't be okay as the funky bearing just bridges the gap... but we shall see in the future I guess.
    [​IMG] [​IMG]
    biggo, chacal and Dave in Ireland like this.
  2. Dave in Ireland
    Ireland
    Good work!
    I was aware the rear drive bearing was rare and expensive, this is an excellent solution.
    Was just keeping my fingers crossed mine didn't crap out, but they're generally pretty long-lived.
  3. chacal
    Nice work and write-up!
    Although.......I'm still curious as to why Yamaha would have specified such an odd bearing if such a simple solution was possible. Back in those days, manufacturers were much less likely to specify super-duper "propriety" custom parts (to replace standard off-the-shelf parts) as is all the rage nowadays.
    P.S. the XS1100 / XJ1100 also use a cylindrical roller rear wheel bearing on the left side, just like the 900's....and then the R1/R6 models in the early 00's.
    The rationale for using roller bearings instead of ball bearings is typically due to the the higher load-handling ability of rollers (both axial and/or radial loads) than ball bearings. Swingarms and steering stems (and the clutch pivot shaft in the clutch cover) also use roller bearings...all of which can have axial displacement (in-and-out rather than just round-and-round) loads.
    But it's odd that Yamaha used them for a while on the rear wheels of some models but not any others...........they had a reason, that's for sure, but I don't know why.
  4. Dave in Ireland
    Ireland
    As you say, greater load carrying capacity, but otoh my higher-mileage GS doesn't use them; final drive bearings are original and over 300K now.
    Yamaha being cautious, I suppose.
    Now that I've seen how to get around the shortage/price of the larger bearing, I'd be quite happy to use a shorter Koyo in its place, with a spacer. I've been using nothing but Koyo in my wheels for well over 30 years and never had one fail. They put up with surprising loads and keep on going.
    cds1984 likes this.
  5. biggo
    biggo Member
    Kapiti Coast New Zealand
    great work . I do have a spare OE bearing but this is a great solution at a fraction of the cost . Keep us updated once your using it
  6. DaygloDavid
    DaygloDavid Active Member
    North Yorkshire (UK)
  7. cds1984
    I actually bought one those kits, from a German place.
    I think the idea is you just replace the custom bearing with the 2 smaller bearings.
    I'm sure it would work but then the drive hub would be jammed onto the outer race of the wheel bearing.
    I guess it would negate the rubber dampening somewhat or completely... If my assumption was the concept of those 2 bearings.
    Looks like the later models 900s use 2 bearings and a spacer, from the parts lists.
    BTW Len does have them, but... A limited supply which is why (plus the awful exchange rate) I decided to go this route.
  8. Dave in Ireland
    Ireland
    cds1984 likes this.
  9. cds1984
    Getting closer!
    Obviously riding it for 20 years will be the real clincher but still.
    NEW TYRE!
    Love the indenting on the tread... the cool kids what?!
    On the other end, they aint cheap but damn the battleaxe is good.
    [​IMG] [​IMG]
    Dave in Ireland likes this.
  10. cds1984
  11. Timbox
    Timbox Well-Known Member
    For next time, I would take the old part to a good heavy-duty tool and die. My shop here can find anything, they measure it and then put those measurements into the computer and order one. Great job with the wheel looks good.
  12. cds1984
    I took it to a friend who is a truck mechanic plus restores bikes and anything. Gave up on him after a year or so.
    Then took it to an engineering place that I'd used before who does car stuff. After a month I asked and the guy literally told me that he didn't want to make the washer.
    So... Finding that workshop is the hard part that's for sure.
  13. cds1984
    So. Couple of rides down and all good and...
    The dreaded sub idle crawl in first gear in peak hour didn't leave me exhausted and wondering if the cops might pull me over for a breath test.
    Winning.
  14. cds1984
    KOYO bearing disassembled.
    Rust!
  15. Timbox
    These were my neck bearings from my 2005 Nomad. I wondered why it was a little jerky when I rode it.
    [​IMG]Rust by Tim Brown, on Flickr
  16. cds1984
    LOL yes... water is not our friend
  17. cds1984
    I pulled 2 normal bearings apart while I was at it.
    Different brands and I see the reason for being brand specific.
    It's all about the cage and how well it is created.
    I pulled one apart and the cage was flimsy and pulled apart simply but the next one was seriously tacked welded together and a thicker plate.
    Same bearing spec, different manufacturer. I'm talking about single race bearings mind you.
    The double race are just on their own, cage wise.
    Never realised these things till this adventure and Len getting all sciencey haha go figure.
    Good times.
  18. cds1984
    Ahh yes.
    From the specs.
    The NSK I mentioned is a double race bearing and the NTN is single race so yeah.
