Necesito ayuda
Discussion in 'XJ Technical Chat' started by Carlos gonzalez, Apr 30, 2025.
  1. Carlos gonzalez
    Carlos gonzalez New Member
    Venezuela
    Buenas noches tengo un maxin xj700 enfriado por agua lo compre con instalación eléctrica muy dañada y cables destruidos por favor habrá alguna manera de encender la moto haciendo un bypass para prenderla sin el uso de los interruptores y rele de encendido gracias.
  2. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Run a jumper wire directly from the battery to the red/white wire on the TCI unit. Leave the red/white wire plugged in when you do this. TCI now has power for spark. You can crank the bike by jumping the big terminals on the starter solenoid with a short wire or wrench.
    If still no spark, try unplugging the black/white wire from the TCI during this test. If it now sparks, that indicates your sidestand relay is bad.
