  1. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Because the odometer finally rolled over your birthday! You were born on November the 55th of 1966. Leap year? Ok, I don't know.
    Fuller56 likes this.
  2. ScottFree
    ScottFree Active Member
    Northern Ill-Annoy
    By resetting the trip meter at 11556.6, I set it up so that in 789.0 miles the odo and trip meters will read 12345.6 and 789.0 respectively (11556.6 + 789.0 = 12345.6). Which would look pretty cool. And is a thing you can only do once in the life of a bike with a mechanical speedo.
    Alas, 'tis not to be: after I reset the trip meter, it did not record the first tenth. So it appears that I will end up with 12345.6 and 788.9
    Dangit. Well, maybe I'll try to get 23456.7 and 890.1 next time. But that won't be anywhere near as cool. I'd shoot for 98765.4 and 321.0, but I think I'll be about 90 years old by the time the bike reaches that mileage!
    UPDATE: Now that I think of it, I have seven more chances to get it right, because the XJ's odometer reset isn't a push button; it's a knob. Which means that as I reset the trip meter, it passes through 111.1, 222.2, 333.3, etc. Each of which gives me the opportunity to try again. Next one is at (I think) 11667.7 miles on the odo, when I would reset the trip to 111.1 miles. The last chance will be at 12334.3 miles, when I would reset the trip to 777.7 miles. 11.3 miles later the odo will reat 12345.6 and the trip will read 789.0 (remember to carry the 1)...
    About twenty years ago I saw a picture in an Aerostich catalog from a guy who did this on his airhead BMW. I think the Beemer had a push button trip reset, so he had exactly one chance to get it right. I have eight in all, failed the first time, seven left...
    Brhatweed and Dave in Ireland like this.
  3. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    Smashed a few bugs today after changing the final drive oil. 79F it was a perfect day for a ride.
  4. co.dirtbiker
    co.dirtbiker Active Member
    Colorado, USA
    Found some cheap Amazon saddle bags that seem like they should work pretty good on the 900.
    This is actually the second pair I tried. First ones (by "Vuudh") had an ill-conceived mounting system that I couldn't imagine would work on any bike I've ever owned.
    These ones by Kemimoto are actually workable. They aren't the sturdiest bags I've seen, but they are darn near the cheapest - about $62 including tax. I think they'll be fine for on road use. Easily removable with just 4 buckles. Biggest concern is they aren't waterproof. They came with rain covers, but they are just held on with elastic and I give it about a 99% chance they'll blow off at highway speeds. I'll have to figure out some way of securing them better.
    ksigurdsen and Brhatweed like this.
  5. Franz
    Franz Well-Known Member
    Scotland UK.
    For longer journeys could you could use zip ties to add additional security?
  6. co.dirtbiker
    Colorado, USA
    I was thinking maybe some grommets in the cover and small bungies that go behind the bags so they can't slip off.
  7. Franz
    Scotland UK.
    Yes they are better.
  8. Dave in Ireland
    Ireland
    I can vouch for Oxford bags. A couple of years ago I lucked into a full set of Oxfords - the panniers, tank bag and tail bag plus an extension for the tank bag, all for 50 quid. Ok, they're red, but I don't five a guck about that.
    They've been overloaded so many times to almost bursting during my shopping runs and haven't given the slightest sign of trouble from stitching or zips.
    New prices would make your eyes water, but there are thousands of them out there that have only been used for maybe three summer tours, if that.
    Franz and Brhatweed like this.
  9. ScottFree
    Northern Ill-Annoy
    What did I do to my Yamaha today? Ordered a set of the nearly impossible to get Napoleon "Baren" bar-end mirrors from an eBay supplier in Japan.
    I wanted these specific mirrors because they have a spring-loaded pivot at the base of the stalk (where it joins the handlebar insert), which allows me to just flip them inward for getting into tight spaces like my garage or between cars (not that I would ever do that, as filtering's not allowed in IL ;) ), and then flip them back out to their original position. I had these on my Buell M2 back in the '00s. Since then they have been damn near impossible to find. Can't even find cheap Chinese knock-offs on Amazon. Finally found a set of the original articles from a supplier in Japan on eBay, and while they were not exactly cheap (though not all that much more expensive than the ones I had on my Buell--especially when you consider I bought them over 20 years ago), they will be worth it. Further reports when they show up, hopefully in a couple weeks.
  10. Brhatweed
    Mora MN
    Too bad because MN is set to allow filtering in July. Given the number of brain-dead knuckleheads playing on their phones I'm not sure legal filtering is going to be a good idea.
    Andrew Nichols likes this.
  11. Dan Gardner
    Minneapolis, MN
    It will be interesting....
    If I disappear all of the sudden you might know why.
  12. Robert Strumbell
    Robert Strumbell Member
    United States duluth mn
    After looking at the splatter pattern I would determine YOU WERE SPEEDING.
    Brhatweed likes this.
  13. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Squeezed the front Avon off the wheel of my 650 Maxim to clean and reseal the tyre to rim. Managed it without removing the wheel too. Quick spin in the sunshine and maybe an oil change this afternoon...
  14. Brhatweed
    Mora MN
    Pleading the fifth...
  15. Dave in Ireland
    Ireland
    I've been filtering in the UK and Ireland for 50+ years and only once had an off because of it. Even that was at just above walking pace as I was slowly making my way down the outside of a queue of cars and an asshole got fed up waiting, deciding he could scoot across the road into a sidestreet, without checking his mirror.
    My lawyer took him to the cleaners.
  16. Fuller56
    Fuller56 Well-Known Member
    I accidently found my Motion Pro rotor removal tool (essentially am M16 x 1.5 bolt with a nice finish) while looking for some other lost motorcycle part. I had completely forgotten that I had it and had been seeking a similar bolt for weeks. I immediately went to the XJ750 engine that needed it's rotor removed and put the tool to use. I need an inventory of tools and bits and pieces and their location.......
    TheCrazyGnat and Andrew Nichols like this.
  17. Dave in Ireland
    Ireland
    There's something in my memory about the GS rear axle bolt fits the rotor extractor hole.
    It would be nice if the XJ was the same.
  18. Franz
    Scotland UK.
    I used a bolt out of a nut splitter l had.
  19. Franz
    Scotland UK.
  20. Trkdrvr
    Trkdrvr Member
    New Hampshire
    Changed oil and final drive gear oil took for 50 mile test ride just to check for leaks and now at 6.12 pm I am kicking it back with a couple cold ones! Hope you all are enjoying your Saturday evening
  21. Fuller56
    I would not be surprised if that worked. I had an '82 Honda CB900F that it's axle worked to remove it's rotor. Our XJ's are not that cooperative and I don't have a GS. I was happy to find the tool and frustrated that I forgot I had it and annoyed that it took me 2 weeks of looking for something else to find it. Oh well, first world problems. The agonies of having too much "stuff".
  22. Rooster53
    North, FL
    I think I would get totally confused if I had two locations to keep that stuff too. Hmmm, was that the winter house or the summer house that I last used that :(
  23. Franz
    Scotland UK.
    Any cam chain problems on the 900f?
  24. Fuller56
    @Franz, No cam chain issues on the 900F that I know of. When it came to me it had, I think, 22k miles and had been in the original owner's garage for something over 20 years after the charging system failed. His wife got tired of walking around it and he sold it to me for a pittance. I rehabbed it and made it almost safe as I did not change out the tires and sold it to a fellow who had been searching for one to restore. He went absolutely crazy restoring it to show worthiness.
  25. Franz
    Scotland UK.
    @Fuller56 I liked the CB900f and a friend of mine got one. Six months later l was still riding my Suzuki GT250 and my father bought a local newspaper and there was an advertisement for a Honda CB750 and l thought it was the DOHC machine. It was a SOHC K2 with low miles and it was in a timber shed that had been creosoted. Even today when l smell creosoted timber it reminds me of my immaculate Honda four. Oh and the 900F's cam chain snapped which was terrible, wrecked the valves. He got a Gold Wing after that. Later he got another CB900f and didn't have any problems with it which was great and he still has it.
  26. Minimutly
    West Wales, uk
    Well this didn't quite turn out as intended. The tyre sealed on the wheel, I took the 650 maxim out for a spin in the country, local roads, nothing exciting. And that was the issue, this 650 is flat as a pancake, up to 8000 rpm, when it takes off like a scalded cat. So I decided to take the tops off the carbs to move the needles up. (Some might remember this bike came to me without carbs, and the only ones I could find were XJ/fj600 mikunis, which I duly fitted, along with the air box).
    Anyway, I dropped the needle clip two steps, so the needles were as high as they would go, and off for a spin.
    Immediately I could feel the bike too rich at part throttle, even some surging. So, back to the drawing board, dropped them back one step. This time I did a running synch and went through all the mixture screws - which showed I had an issue with no3 carb, not responding... So it will be off with the whole lot to check this out.
    In the meantime I looked to see if I had some weaker pilot jets, but no I don't, so I ordered a set one size smaller. The test ride was a big improvement, with the surging gone, replaced by flat response just off idle, but full power available from 4000 up - it really goes like stink.
    Interesting thing about the xj600 mikunis, No2 carb has a different needle, and not by a small amount, it's clearly a lot thinner...
    Anyway, fingers crossed the new jets help, if not I will have to resort to machining needles in the lathe - but damn, what are they made from - anyone know?
  27. ScottFree
    Northern Ill-Annoy
    The "Napoleon" bar end mirrors showed up from Japan yesterday and went on the bike. Today I took it for a nice ride in the country... as long as your definition of "nice" includes winds gusting to 45 mph... No destination at first, but while stopping for gas I got a text from the shop, letting me know the oil filter for my Harley is in. Well, good, now I had a destination!
    It was a nice ride. For reasons I don't entirely understand, riding this bike makes me happy.
    I had my second chance to reset the trip meter (to 111.1 this time) so that the odo and trip will read 12345.6 and 789.0 a few hundred miles from now... and again I didn't get it quite right; the trip meter is one tenth of a mile ahead of the odo, so when the odo is at 12345.6 the trip will be 789.1. Nuts! Well, I have six more chances; I have now been ahead by one tenth and behind by one tenth. Maybe the next attempt will be the one where I get it just right.
    StorminNorman and Brhatweed like this.
  28. co.dirtbiker
    Colorado, USA
    @ScottFree's talk about mirrors reminded me I needed to do something about the 900. All I could see in the mirrors were my elbows, and they aren't really something that holds much interest.
    I didn't want to spend a lot of money or lose the look of the stock mirrors, so I found these cheapie extenders on Amazon and ordered a set. First ones showed up with wonky hardware...different size socket heads on each, and the left-hand threaded one was shaped like a banana. Returning those, but thankfully the replacements are much better. Bolts are straight and both take the same size wrench. Seems like they'll do the job nicely. I've had it out to run some errands around town and visibility is much better...I can actually tell if there's someone behind me now. :)
    Andrew Nichols, Simmy and chacal like this.
  29. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    I agree the CB900F is a great looking bike.
    It was going to be my 1st street bike.
    I looked at one used, I think it had an aftermarket fairing.
    Then I saw Yamaha pushing their Turbo’s out of show rooms 2 years non-current, I chose the Yamaha, no regrets
  30. Franz
    Scotland UK.
    I have seen a CB900f with a Suzuki Bandit 1200 motor and another in a bike magazine with a Z1 motor. Honzaki he had painted on the tank.
  31. Dave in Ireland
    Ireland
    Going back in time, the one that started it all was the Triumph engine in a Norton Wideline frame, giving rise to the Triton name and establishing a convention on naming - generally engine / frame in that order.
    Which gives rise to the question - who were all the unlucky bastards who built NorUmphs from the leftovers?
  32. Franz
    Scotland UK.
    NorUmphs lol have not heard that before.
  33. Minimutly
    West Wales, uk
    Removed, stripped, cleaned and fitted 37.5 idle jets in the mikunis. (Down from 40s). I think it needs 35s, still some bogging around 2000rpm which isn't cured by opening the enrichment. It's better though.
    Changed the bars for some with slightly more sweep back, hopefully will relieve my aching wrists.
  34. Brhatweed
    Mora MN
    Dad had a Norton Commando 850... then he came to his senses and bought a Bonneville 750 new in early '77, still has the bike today.
  35. Franz
    Scotland UK.
    He has looked after it, nice bike.
  36. Brhatweed
    Mora MN
    27-some thousand miles on the clock and never on its side. I spent a lot of time on the back of that growing up and was the first to sit on it the day Dad bought it... they threw in a free helmet for me. I was 8 years old. Lots of cruising and camping trips on that horse.
    Franz, chacal and Simmy like this.
  37. Fuller56
    @Brhatweed, oh I like that! Very pretty. I have always liked and thought I wanted a Norton as to my eye they have the prettiest lines and shapes. I also never thought I was a good enough mechanic to get and keep a Norton running right. Your Dad's Triumph is a close second in looks and probably better daily use machine.
  38. Franz
    Scotland UK.
  39. Minimutly
    West Wales, uk
    Latest on this - the new bars are a big improvement, slight back swept, and I've set them kicking up slightly, best they've been for me.
    I thought I would investigate why no4 mixture screw arrived at a whole turn further out than the others - along with an occasional backfire. Some propane from a torch was enough to decide it - a vacuum leak at the manifold/head gasket. I got a length of tube and listened to it... Well, I didn't want to take the whole lot off again, so for now I smeared some silicon on the joint, which cured it.
    The rich spot just above 1500 rpm still remains, of course I need to resynch the carbs, set mixture again, then retry, but I don't expect the issue will be fixed.
  40. Brhatweed
    Mora MN
    Added a few miles to the clock today to blow some of the rain water out and added the XJForever decal to the side panel. Too many dough-heads on the road right now making a bee-line to their cabins with their big campers and boats to do any "relaxed" riding. I'm right in the thick of cabin country and they're not watchin' the roads.
  41. StorminNorman
    StorminNorman Member
    Virginia
    Ordered a set of TC Bros forward controls, a used shifter pedal and a used brake pedal so I can mod them and not the original parts. Going to change the ergonomics so I can cruise the XJ650 and see if it gets me the ride I want.
  42. Minimutly
    West Wales, uk
    I fitted a set (of unknown maker) to my Vmax trike, linked to the originals (by welding new arms to the brake and gear levers). So I can "cruise" , or I can use the normal ones if getting a shift on. Works for me.
  43. Brhatweed
    Mora MN
    Wrung it out today on a nice little ride on the back roads with a GoPro on the helmet. Give me some time and I will post the good parts to YouTube... you know the ones where I pass the ten-grand mark and keep going. Audio isn't the greatest but you can follow the tach & gears to know how fast it's moving.
  44. Brhatweed
    Mora MN
    A 13 minute ride on my 750, few bounces off the redline (frequent visitor) and some passes but the audio is typical GoPro not so pro... check it out let me know what ya think. Might strap a multi-track to the bike and do some real engine sound caps.
    Roast644 likes this.
  45. Brhatweed
    Mora MN
    Did a long road trip over the weekend and passed the 45,000 mile mark. Only complaint is the tank lasts longer than my butt on that seat.
  46. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Oil change today on the X, getting ready for the Carb Clinic.
    TheCrazyGnat and Brhatweed like this.
  47. Brhatweed
    Mora MN
    Done the carbs on my SECA so many times I can do them in my sleep... insomnia or insanity?
  48. Turbobob23
    Turbobob23 Member
    Fredericton N.B. Canada
    Well I synchronized the carbs, then used the Gunson Colortune to check fuel mixture after jetting up. Way to rich so now I disassemble carbs and downsize one size to make it right.
    Would love to show y'all my xj1200 build, but can't upload the photos
  49. co.dirtbiker
    Colorado, USA
    Since CNYCC was a bit far, I did the next best thing and rode the 900 on the 160-mile round trip to the Colorado Vintage Motorcycle Show in Erie.
    Pretty good turnout. Lots of bikes to see - probably close to 100, and they were still coming in when we had to leave. I didn't see any other XJs, but there were a few folks that recognized the 900 for what it is. Several other Yamahas, including a nice unmolested XS650. Was tempted by a '73 CT 175 that a guy was selling. That could probably be considered the bike that got me interested in motorcycles when my dad bought one new back in '73. I was never big enough to ride it before he sold it, but I used to spend a lot of time sitting on it in the garage pretending. :)
    Beautiful ride up. We've been getting a decent amount of rain this year, so things are really green. The 900 never fails to put a smile on my face with how good it runs. 53.5mpg(US) average for the round trip! Not bad for a 42-year-old bike.
    All in all, a pleasant day.
  50. Franz
    Scotland UK.
    Upload your xj1200 build photographs to imgur for example and post the link here in other motorcycles since it is not an XJ :D.
    TheCrazyGnat likes this.
