Bike shoots up to very high rpm when starting
Discussion in 'XJ Technical Chat' started by Donglord, Aug 22, 2025.
  1. Donglord
    Donglord Member
    Arkansas
    I got my valves are FINALLY adjusted. Bike fires pretty good now. But it goes straight to 6k rpm (roughly) as soon as it fires. My idle screw is as far out as I can go. Would I need to maybe adjust my air/fuel mixture screw?
  2. chacal
    Has a running (vacuum-gauges) synch been performed yet? Runaway engine rpm's are one of the tell-tale signs of an out-of=-ynch engine (although it could be due to other causes).
  3. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Also, check that the butterflies are closing.
    Carb boot clamp rubbing on the actuator
    Throttle cable not sitting in the holder correctly
  4. Donglord
    Donglord Member
    Arkansas
    Alright I'm dumb. My throttle cable wasn't seated properly where it sits on the carb rack.
    cds1984 likes this.
  5. Donglord
    Donglord Member
    Arkansas
    I must've bumped it when I put the gas tank on somehow
  6. chacal
    It happens. Very small spaces down there.
  7. Dave in Ireland
    Ireland
    Oh, don't worry, you're not the first that's ever done that.
    Not that I've ever done it myself, you understand.
    Never.
    Nope.
    Not me.
    Dan Gardner likes this.
  8. cds1984
    Lol me either.
