Simmy's Naked Turbo Project
Discussion in 'XJ Modifications' started by Simmy, Feb 25, 2017.
  1. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Most important thing is to stick with a project. Most guys get bored then stall out.
    My next project is a mint OEM 650 Seca. I haven't done a thing with it since acquiring it but I did find the OEM operator's manual I've had since 89.
  2. Simmy
    I hooked up my carb stick and tweaked the carbs as level as I could.
    I've never used the YICS tool, maybe its more responsive to adjustment IDK
    It idles really steady but reads real lean at idle.
    As soon as I raise the throttle it reads under 13 which is good.
    Maybe this is normal, I've never spent this much time idling with the wideband.
    Anyway, good enough to go for a ride once I put the tank and side covers on
    Fuller56 and Dave in Ireland like this.
  3. Simmy
    Well I have 32 kilometers on the new motor. I spent all the time under 5,000 rpm and the 02 levels stayed below 13 so currently no concerns. Throttle was very responsive, now there is good torque even at 3,000. I opened the throttle to 5000 and the boost gauge was showing boost at 4500 so big improvement.
    There is nothing to adjust at the moment very happy
    Rooster53 and Rayzerman like this.
  4. Simmy
    Believe it or not I have another failed base gasket.
    I finally figured out what is going on,
    When I had a mm skimmed from the bottom of the block I always had in mind to shorten the dowels to.
    I swear I measured the depth of the holes for the dowels and determined their was clearance. Maybe I was wrong.
    I think the dowels are bottomed out and not allowing a proper clamping of the gasket between the block and the cases.
    Any pressure in the cases is blowing the gasket out
    There's no oil leaking out anywhere and the bike is running incredible so I'm going to clean this up and fill some gasket goo for now. I'm not sure how many kilometers I need on these rings before giving it boost.
    If there's any carb changes to make I'll do that while changing the base gasket again. Sheesh
    Today was just awesome riding this bike even though I didn't give it the gas, the bigger bore really gives this some grunt
    Weather was warm just an awesome ride. Looking forward to more testing
  5. Fuller56
    Fuller56 Well-Known Member
    Impressive work on the build. Sorry to hear about the dowel/gasket issues. I can only imagine the disappointment. I really hope you can make it to the CNYCC.
  6. Simmy
    Just ordered another base gasket.
    I'm getting pretty good at top end rebuilds now.
    At least I know the low rpm jetting is good, I can be pleased about that.
    The motor is very smooth, I never did compare the weight of the pistons.
    Dave in Ireland likes this.
  7. Simmy
    After some retrospect I'm not going to do anymore riding in the present condition.
    With the block not sitting square there would be unknown stresses on everything, especially when making big hp on boost.
    chacal likes this.
  8. Simmy
    I'm attempting to dismantle the top end without removing the carbs.
    I left the surge tank attached to the carbs and have both pulled clear of the head.
    If I can get away with this it saves a lot of work.
    Removing the cam chain tensioner was a challenge.
    I had to make a very deep #5 allan to get it.
  9. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    It's going to be fun lining up the gasket and tensioner screws when reassembling.
  10. Simmy
    You're right, I think the carbs will need to be out of the way for the reinstall.
  11. Simmy
    this was a very careless oversight on my part.
    I remember measuring the locating dowel at #1 cylinder and determined there was clearance.
    These dowels are precision fit as they need to carry the oil to the head without leaking.
    I'm sure I checked them but must have screwed up.
    Whatever I took off the block I need to take off these dowels.
    One O-ring was cut up to so apparently I needed to go back in here to fix that, ha.
    They are slightly bent so I need to sort through my junk pile for new ones then sand, grind or file them down.
  12. Simmy
    I took 1.6 mm off the block so I did the same with these dowels.
    Started with a file then sandpaper and got them to the correct size.
    after file and sanding
    I received another 900 base gasket but I had another look at the OEM turbo base gasket.
    Its still completely intact, the holes are just slightly too small.
    Its metal and rubber, I could try enlarging the holes with sandpaper, maybe a rotary burr, it won't take much.
    And the 1st thing I'm doing tomorrow is double checking the clearance on the locating dowel at #1 cylinder.
    I'm not removing this block again.
  13. Simmy
    I took a rotary file to the OEM Turbo base gasket.
    2 passes around each hole and a cleanup with a knife it fit perfect, so I went with it.
    The head is torqued back in place.
    The cams I can install quick as I have a technique now.
    I could work for Yamaha's assembly line.
  14. Simmy
    OK I have the motor back together.
    Any short cut of trying to leave the carburetors in place was a foolish idea.
    Everything in this cavity needs to come out to reinstall the cam chain tensioner
    these are the components which need to come off to get the carbs out.
    The nice thing about the Turbo is that the surge tank and air cleaner assembly can be removed and reinstalled with the motor there, unlike the normally aspirated air box which needs to be installed before the motor
    All back together and ready for another ride, basically a 2 week set back since the last ride.
    I had the mercury stick attached but it didn't really need much tweaking.
    Unfortunately it's pouring rain here today so no riding this.
    Fuller56 and Rayzerman like this.
  15. Simmy
    Actually January 17th is when I blew out the 1st base gasket during a compression test.
    April 18 is 3 months set back. 3 months of unnecessary extra wrenching if I had measured that properly or just clued in sooner.
    We haven't had riding weather yet. It's ready to roll now.
    I had a Turbo new in 84 and I don't think I put too many kilometers on it before opening it up.
    I wonder if the Turbo operator's manual specifies any different break in period from their other motorcycles?
    I had fun when I did ride it and I stayed below 4000 for 32 kms maybe once to 5000
    I know how smooth it was then, now that the block and cases are actually sitting together I have big expectations for this motor.
    Once I have 100+ kms on these rings I'll start giving it the gas.
    Dave in Ireland and Fuller56 like this.
  16. Dave in Ireland
    Ireland
    1. Up to 300km, rider may go 'Whoo'.
    2. Between 300 and 900km, rider permitteed "Ooohhh Heeeee".
    3. Full "Whooooooo Hooooooo" allowed after 1000km.
    Tootle vigorously on horn and avoid the Mud Demon.
    chacal and Simmy like this.
  17. Simmy
    Well I rode the Turbo into work today. 3 more weeks until retirement for me.
    It was 2C this morning but forecast for 20C this afternoon.
    Planning to take the long way home to get some miles on it.
    So far, if I had to guess the big bore has made the carburation a bit richer.
    I haven't raised the revs much past 5,000, it always stays rich, mostly reading around 12:1.
    And I still have a persistent oil drip from the feed line to the turbo unit, been there since day 1.
    The connections are tight, I think I'll need to remove the line and air test it to see if there's a leak within the line.
  18. Simmy
    I now have a few miles on the 772.
    I had to replace the battery so that delayed things a bit.
    The bike is a complete gem to ride now.
    On the highway I have boost before 5,000 rpm and the low rpm torque is vastly improved.
    The 02 sensor stays below 12:1 at all times, suggesting it's currently running slightly rich.
    I'd like to try a leaner pilot and maybe drop the needles back 1 notch.
    My perseverance has paid off.
    1st bike night in my area tonight, can't wait.
    My sidecar Seca is ready to go to, #2 float stop was stuck closed, I had to physically pull it loose with my fingers.
    It had sat for 6 months.
    Which one to take, hmm.
    Fuller56 and Brhatweed like this.
  19. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    I know decisions... decisions... right?
    Personally I'd run things a tad on the rich side with the modern garbage masquerading as gasoline just to be safe, I can't imagine detonation in an air cooled engine under elevated boost would do any good.
    Simmy likes this.
  20. Simmy
    I took the Turbo to the Wednesday bikenight about 50 kms from my city.
    A small event probably just 50 bikes at the peak. Good eclectic mix of rides.
    The shop is a moto lifestyle clothing shop.
    The biggest impression of this bike is the monstrous roll-on torque at 5,000.
    I haven't red-lined it yet, no need to and I'm just a little nervous about stressing things just yet.
    Dave in Ireland and Brhatweed like this.
  21. Rayzerman
    Rayzerman Member
    Ontario Canada
    Pray tell, Simmy..... where is this bike night? I'm within striking distance.....
  22. Simmy
    Stratford
    Perth County Moto
    Rayzerman likes this.
  23. Simmy
    I attended the 52nd annual Canadian Vintage Motorcycle Group rally on the weekend.
    New location this year.
    This year was dedicated to 2-stroke motorcycles.
    Maybe by coincidence there were just no mosquitoes, LOL.
    Never seen so many Suzuki RG500's in one place, good to see they're still around.
    Kawi triples were everywhere.
    This was the 1st time I had my little Seca family lined up together.
    Seen a lot of interest and appreciation with my bikes.
    Dave in Ireland and Rooster53 like this.
  24. Simmy
    I made up plaques for each bike otherwise the Turbo would go unnoticed as anything special.
    I saw one gentleman with a determined b-line right for my display, I got ready to answer some technical questions but he was most interested in how I mounted the plaques, LOL.
  25. Fuller56
    That is one pretty line of Secas. Looking at them is probably almost as much fun as riding.....almost. Well done Sir.
  26. Simmy
    Thank you very much appreciated
  27. Brhatweed
    Mora MN
    Looks like an outdoor sales event for new bikes. They're stunning!
    Simmy likes this.
  28. Rayzerman
    Rayzerman Member
    Ontario Canada
    I was all over the place, however, I neglected to explore the whole campground...... Missed ya!! So now you have to invite me up for coffee and some St. Jacobs apple fritters.......
