NOT a typical Hitachi carb issue...?
Discussion in 'XJ Technical Chat' started by Miixxa, Jun 2, 2026.
  1. Miixxa
    Miixxa Member
    Finland
    Okay, been lurking the forum for the whole spring while building my XJ750S into a caferacer (I know, I didn't start the project, but I'm finishing it)
    Anyways, I have gone through chacals carb posts with a fine comb and still can't get these stupid HSC33 carbs to work properly.
    When I got the bike I immediately noted that these carbs are... let's say interesting and checked everything. "Luckily" for me the previous owner already did something to the bike since the carbs had 43 pilots and 112 main jets installed, but as far as I know it had been run like that prior disassembly. Unfortunately all the original plastics, including the airbox were missing.
    Welp here comes the part most already guessed: pods.
    Since there was no airbox and this was a cafe build the only option was to put pods onto the carb rack. Opted for foam pods instead of true metal pods since apparently Yamahas really dislike the metal net pods...
    Since I wrongly assumed the jetting was stock (now know it doesn't match to anything chacal's info really) I threw on a 120 main jets and after wet setting the floats and syncing the carbs I needed to switch the pilot from 43 to 45 to get the mixture screw around the 2-3 rotation area. Now the idle is spot on and synced.
    The issue is the main jets and middle area. I always assumed that there was gonna be some dead zone between the transfer from pilot to needle circuit, but no matter the jetting or shimming the needle there's an severe burple/rich zone at 3k rpm. After that it pulls well, but I'm down to 112 main jets again and it still feels extremely rich at WOT and middle area.
    To further confuse me after test pulls the 1 and 3 spark plugs are completely sooted up BUT 2 and 4 seem good/a tad lean...how? What's happening? Can the YICS cause this or what am I missing?
  2. Uxbridge Brule
    Uxbridge Brule Active Member
    Uxbridge Ont
    Have you done a compression and valve check? Little things can add up.
    Miixxa and cds1984 like this.
  3. Miixxa
    Miixxa Member
    Finland
    Yup, compression is good and valve clearances within spec (although I did check these before running the engine after it had sat for a few years). At the same time I had all covers off and checked the internals. Also checked the cylinders with a borescope and everything seemed spotless (engine only ran for 50tkm)
    Today I lowered the floats about an 1mm (wet level is now about 2-3mm) and I'm down to 110# mains and from cold it seemed to run extremely well, but still blubbers rich when warmed up, but it's frustatingly close and way better anyways.
    I'm fairly confident the pilot circuit is spot on as the idle and 0-10% throttle is about perfect. I plan to further adjust the pilot circuit with a lambda sensor after I get the carbs otherwise set.
    After the test run the plugs are the same: 1 and 3 sooted up while 2 and 4 remain almost more to the lean side, which makes no sense to me...
    I also noted that it couldn't hurt to inprove the air flow into the carbs by tossing the uni filter collars and currently printing a velocity stack style mounting collars for the filters. Pulled the dimensions outta my behind but let's see...
  4. Miixxa
    Miixxa Member
    Finland
    Forgot to mention that the unifilter mounts I'm manufacturing will remove any harsh angles in front of the carb intakes and will provide a total of 6cm of stack style tubing of which half sits inside the foam filter.
    In my head this should inprove the operation of the carbs and in theory might lean the mixture enough to suit the current jetting...? Easy test anyways.
  5. Miixxa
    Miixxa Member
    Finland
    Update:
    Went down to 108# mains and tried the unifilters with and without the self made "laminar flow" tubes between the filters and carbs. Tried lowering the floats down to 5mm wet level, and did a test run between every change and basically it went worse.
    What throws me off is the fact that this thing is supposedly close to it's stock jetting with pod filters and it's still running extremely rich ..what gives?
    Simmy likes this.
  6. Miixxa
    Miixxa Member
    Finland
    Aaand took the carbs to church with all steps this time and found out an issue with the enrichment circuit, which is basically leaking. Lapped the plungers and wells and plugged the extra breathers on there and made sure the plungers aren't leaking by sitting brake cleaner in the wells.
    Slapped everything back on the bike and...it's still drowning in gas and randomly picking up revs at idle. Tried it with new sparkies and now change. Can't find any intake leaks, vacuum systems have all been deleted and even the idle is all over the place. Real freaking weird...
    Maybe it's time to let this one sit for a while because I'm just stumped at this point.
  7. slackard
    slackard Active Member
    Earth, Terran System
    Picking up revs at idle sounds like an intake air leak. Check that your head-to-carb boots arent cracked, & that the clamps aren't worn out & actually hold.
    Once verified, do a full carb sync for a really smooth idle.
    Also pull your plugs and verify they aren't fouled or running too lean.
    https://turbododgeparts.com/content/faqs/how_to_read_a_spark_plug.html
    Also, poor running with stock jetting and pod filters is what we expect. Stock jetting on pods will never run right.
    Pod filters permit a different amount of airflow than the stock airbox does, and so, one must jet the bike to match the pods.
    When I got my XS, the airbox was gone and someone installed pods with stock jetting, which ran like shiat. I went on ebay, got a used/correct airbox and now she runs awesome..
    Pods and bobs and bling and all of that is about how the bike looks, or maybe how you look on the bike... Personally, I only really care about how it runs and these bikes all run best with the stock airbox.
  8. Miixxa
    Miixxa Member
    Finland
    Thx for the input but it was mostly unnecessary if you had read the previous posts...
    Sure the original airbox would be nice, but not worth sourcing especially now when the whole bike is built to a specific look/style.
    Someone else started this project and has done a bunch of misc. crap on top of losing most of the stock parts - including switching the jetting into "something" which I now realize is from a generic rebuild kit. Pilot was 43# and main 112# which I mistook as being stock and replaced them with 45 and 130 and have since come back down by steps until it's now 45 and 108 AND still running rich /.
    All possible intakes have been ruled out with an overpressure smoke test and none found. Also visibly gone through everything.
    That said I did found out the culprit for the wandering high idle rpm: it was the throttle axle seals. The outermost seals were already switched into double o-rings and all the rest were.those proper V-rings BUT I took another blunder by checking them and deeming them ok by visually checking them and determining they wete soft and tight on the outside seats...what I missed was that they were all almost 1-2mm loose on the axle itself. -> replaced all the rest with suitable fat o-rings and no more wandering idle + they synced great.
    All this done the bike runs richer than ever. Apparently Hitachi carbs don't require as dramatic up-jetting than Mikunis and I now have way too large jet on the pilot at least. According to data I can find and crosscheck these euro spec XJ750's should have 40# as pilots and 104# mains on the outer two and 106# on the inner two cylinders.
    After my holiday the trial and error continued...
  9. chacal
    For most of the rest of the world, a combo like that is stock for the 650cc carbs.
    The HSC33 carbs (if that is truly what is on your bike) used much leaner (smaller) mains and pilots but the air jets were changed and the main jet needle was massively richened up (probably to compensate for the much leaner fuel jets). The emulsion tube was also different than the HSC32 series, as well as the vac piston spring (which probably contributed to a greater and/or quicker rate of rise of the vac pistons and hence the richer main jet needle...........).
    It's actually unusual to have any of these HSC series carbs run rich in stock form, unless:
    a) too large jets or incorrect main jet needle
    b) mixture screw is turned far out from proper position
    c) choke plunger valves are not fully seated, or, there is a flaw (gouge, etc.) in the choke plunger valve seat machined into the carb body.
    d) fuel levels in the bowl set way too high
    e) some combo of the above.
    f) someone has drilled out fuel jets to a larger size or installed one of those "performance" jet kits (which typically also involve drilling the vac piston air bleed holes to a larger size). NOTE: aftermarket "performance" fuel jets may not be marked with the correct Hitachi "size" designations. Hitachi fuel jets (but not the air jets) are marked in millimeter sizes: for example, a #120 fuel jets should have the drilled hole diameter or 1.20mm, a #130 should be 1.30mm diameter, etc.......a 340 pilot jet would be 0.40mm diameter). Aftermarket mfgs. might inscribe "43" on a pilot fuel jets, but measurements show it to actual be a size #50 (for example).
    TOO LEAN is the issue most commonly encountered.
    Maybe so.....and certainly not part of your current rich-condition issue.....but I would strongly suggest that you eventually replace those o-rings with the correct v-seals.
  10. Miixxa
    Miixxa Member
    Finland
    Hey chacal, I truly appreciate the reply!
    Yeah, this thing quickly turned from an easy project to an headache caused mainly by the carbs.
    The bike is without a doubt an XJ750S euro model, with the HSC33 carb rack.
    No idea about the real model year since my country designates model year by registration and it's registered 1986, but it still has the same color carbs. Fuel inlet is between the 2/3 carbs, breathers between 1/2 and 3/4 and the extra breathers at the mixture screw base on every carb, which makes me certain these are HSC33.
    The air jets on each one are 225# and 70# which should be stock. Now I also replaced the fuel jets into 41# pilot and 108# main since my own research points to the Hitachi's not being THAT sensitive to pod filters.
    It seems to be way better mixture wise on the 41# pilots as it's no longer eye stinging rich...
    That said, the throttle axle seals were a miss. Throttle is sticking bad and keep experiencing random intake leaks, although can't pinpoint the location. At the moment I can't proceed with adjustmens since it's all over the place, one second it's choking and the next it's pulling 4k while sitting on it's own.
    Only thing I am sure is that it's not leaking from the boots or YICS...
    And yes the enrichment plungers are still causing issues by not seating correctly. No idea how to fix that issue other than blocking them off completely for now. I might need to abandon these Hitachi's and get something else to get this thing working properly...
  11. Miixxa
    Miixxa Member
    Finland
    Update on the current plan:
    So I know I could have get the correct seals from chacal, but living where I do those seals won't get to me for this riding season so....
    I did an inquiry run around my city and found a set of 8x12x3mm actual axle shaft seals to go. I plan to install these onto the carbs "wrong way around" to keep air out rather than fluids in. In my head these proper shaft seals can't be worse than the original "V-seals" right...?
    These seals are a bit too fat with that 3mm thickness, but the excess is on the outside lip which will poke out of the carb body -> exacto knife will take care of that ~ 0.7mm excess that would be binding on the shaft spacers.
    On top of that I wen't ahead and bought a new arsenal of lapping compounds and will take my time lapping the enrichment plunger seats on each carb + thoroughly test them after that they absolutely do not leak.
    These will be the final steps I'm willing to take with these carbs and if the enrichment plungers still leak these carbs are scrap anyways...
  12. Miixxa
    Miixxa Member
    Finland
    This is now turning into a project thread, but I need to vent...
    So 2 out of 4 carbs now done. Took my time with each one, completely dismantling everything and spending about half an hour per enrichment plunger of lapping. Tested the plungers with penetrating oil (the extra breather nipples on HSC33's came handy on this) and neither one I lapped had any kind of leaks even with air pressure. So the choke/enrichment circuit shouldn't cause issues after I get the other two worked on.
    Also took my time to soak and clean everything again, just to be sure. Got the new shaft seals on the carbs, which did need some modifying since the seats on the carb bodies are actually 11.5mm and the seals outer diameter was for 12mm hole, but damn they should be tight now. Also polished the throttle axles and rounded off any sharp edges on them before installing them on the carbs with plenty of grease.
    I have to say I'm pretty confident on these seals working like a charm and the axles now move with basically zero friction...
  13. Miixxa
    Miixxa Member
    Finland
    Update:
    Got all of the carbs "refurbished" so to say. For some reason the 4# carb enrichment plunger was leaking really bad when I originally thought the 1# was the worst with the couged plunger seat. On 4# it took about four times the work to get it lapped and sealing properly but got it done.
    Finally bench synced the carb rack and took the effort to reposition the throttle flaps so that they have the exact same opening on the lower edge + exact same amount of pilot orifice showing.
    Now I need to find the motivation (and time) to get the rack back on the bike, synch them and get on the road to see if the needle and mains still need work...
    Huntchuks likes this.
  14. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Wet set float levels before putting them back on the bike.
    Just to make certain all 4 floats are shutting off
  15. Miixxa
    Miixxa Member
    Finland
    I've done this for half a dozen times already, mainly because there's contradicting info on what the levels on this spec bike should be. Tried the 1mm wet level first which was just ridiculously rich and now I have them wet set at 5mm(+/-1mm).
    Took dry measurements before I dismantled everything and verified that the levels were the same while rebuilding... But you may be right, I might wanna wet set them again - again just to be sure...
    Luckily this is a cafe bike now so it's pretty straight forward taking the carb rack out and back in again. Done it so many times in the last month I lost count...
    Speaking of the float valves: does anyone have concrete info if the HSC33 should have rubber tipped needle valves or brass? Because this thing has the rubber tipped ones and again, contradicting info if these are original or some BS aftermarket ones...
  16. chacal
    Hitachi float valve needles were originally rubber-tipped; many (but not all) of the Mikuni carbs from that era used metal-tipped needles. Thru the aftermarket, you can purchase metal-tipped needles for the Hitachi HSC32 / 33 series carbs, and that's actually what is recommended for people who live in an area that has fuel (gasoline) with a high (10%-up) ethanol (alcohol) mixture as the available fuel (this is a very common mixture in North America). The reason for the use of metal-tipped needles is that they are far less prone to seizure within their seat, which is much more likely to occur with a rubber-tipped needle.....especially in the presence of alcohol (which will cause most types of rubber to swell a little or a lot, depending on the type of rubber used to make the tip).
    So the metal-tipped needles greatly reduce the chances of fuel delivery issues due to a needle that gets seized in the closed position (no fuel!) or seized in a partially or fully open position (flooding).
    Miixxa likes this.
  17. Miixxa
    Miixxa Member
    Finland
    Thanks @chacal, that confirms that everything inside the carbs should be correct. Clearly the previous dude bought some kinda kit for the carbs since needlevalves, seats etc. were new/spotless. Shame that he didn't bother to replace the seals while at it, but it is what it is...
    Fortunately we still have 5% ethanol gas still available and that's what I use on all my gas guzzlers for obvious reasons. (Daily drivers are all EV, so never need to buy any other type either)
    Got some motivation finally to test the current setup and determined that I'm a dum-dum...
    Screw me sideways but after installing the newly sealed carb rack on and getting the engine warmed up the erratic extremely lean condition came back...LUCKILY I had switched into clear gas tubing and realized that my forward tilted tank(to allow adjusting) was low on gas and the rear mounted petcock was running dry...filled it up and repositioned the tank more vertical to continue adjusting. /end of dum-dum
    That said the idle is now THIS CLOSE to being spot on but still a little bit lean while the screws being at 4.5 rotations open, any more open and it just chokes out so guess that's the end of adjustment for these screws. No matter, they shouldn't be that far open anyways.
    Just ordered 42 and 43 pilots and will test with the smaller first. Didn't bother to test drive it for the full throttle or middle area because of the limping idle and living in the city, but stationary/against the clutch it seemed to be pretty peppy and revvy.
    Uxbridge Brule likes this.
  18. slackard
    Where are you ordering Hitachi Pilots, jets, etc? My xs850 has the HSC34 (running stock airbox and jets). MikesXS has carb kits for the HSC34, but I've never found a source for the individual jet sizes... anyone?
  19. Miixxa
    Miixxa Member
    Finland
    Well I was having a hard time since Hitachi jets are apparently non-existent nowadays...
    Literally just happened to test some Dellorto 5mm jets, since they look the same. The thread pitch is not perfect as Dellorto has 0.75 pitch and Hitachi has 0.8 pitch...but they do fit without hassles and the jet sizes are the same.
  20. Miixxa
    Miixxa Member
    Finland
    While gathering motivation and rejetting the carbs, I decided to check the intake boots again - just to be sure. The boots I had never taken off because the bolts were extremely stuck. I tried the 4th boot upper bolt and it immediately snapped and I had to drill it out. Didn't touch the rest of them since...
    Well decided to do this properly for once and got a smoke machine aaaand...check the first picture. ALL of the boots were leaking from the gasket except cyl 4 which I already replaced...
    Glad I did it before trying the carbs back on though. Even more happier when 2 and 3 boots came undone without hassle. Of course cyl 1 boot BOTH bolts snapped no matter how delicately I tried to warm them up and drench them in penetrating oil...(Second pic)
    Luckily they were on the first pot so easy to drill out...in theory until my extra hard Magnum bit snapped in the lower bolt...fun times let me tell you.
    Ultimately got them out and all of the boot gaskets replaced. Boots themselves were original but surprisingly completely fine (we need the 80's rubber and rock back!)
    Finally checked again with smoke and found no further leaks. Next throw the carbs back on and see how far off the jetting is now since there were hiding intake leaks again... IMG20260711170736.jpg IMG20260711171058.jpg
    Dave in Ireland likes this.
  21. chacal
    Very clever testing method and very typical results (including the sheared bolts). Keep us posted, great work.
  22. Miixxa
    Miixxa Member
    Finland
    Well smoke generator is a must have tool in the automotive world, so borrowed one from work. Really need to get my own in the carage...
    YICS channels made the smoke test very straight forward as I only needed to feed the smoke into one intake and block the rest (ping-pong balls happen to be perfect blockers for most bike intakes).
    Funny how all of the boots had basically a pinhole leak exactly at the center bottom of thw gaskets. And of course none of these reacted in any way to spraying with pilot while running...
    We'll see how this thing ends up. Still quite baffled how I managed to do almost 140km of test runs and determine it was running damn rich with all these issues found since. Other than the leaky enrichment plungers nothing really explains that - it should have been extremely lean all through this.
    I'm hoping that tomorrow is the day my family doesn't need me for anything and I'll get to take my time with the carbs and hopefully get this thing into proper driving condition.
  23. Miixxa
    Miixxa Member
    Finland
    Status update:
    Got the carbs back on, got it running and... it's freaking running so lean that it just continuously pops from the exhaust. Now seriously what the...
    I upped the pilots, managed to find an correct the remaining intake leaks and still it's ridiculously lean with the pilot screws 4,5 turns out on the #43 pilots. It is not pulling extra air through the carb rack or inlet boots. Now I'm seriously baffled about what is happening and lost all motivation again...
  24. Miixxa
    Miixxa Member
    Finland
    Again monologuing here, but after a small beer fueled thinking-over I still might have few things to check:
    1. Cause of the conflicting data available the float wet levels might be too low. No real way to test this other than wet setting them again for the +1mm level (goddammit)
    E: Yup this isn't it, just re-checked and wet levels are exactly 1mm while on the bike.
    2. The open headers are causing part/most/all of this. Need to try with some temporary baffles and order some kind of mini mufflers (open pipes are honestly starting to annoy me too)
    3. I have synced the carbs with proper manometer but I didn't block the YICS channel. What I found out online was that while generally the blocking tool is unnecessary it can cause that false lean floating rpm issue if you have bad luck... let's just assume this concerns me at this point.
    4. And my personal favorite: all of the above
  25. Miixxa
    Miixxa Member
    Finland
    Okay, after another few hours I verified all the carbs wet levels being at 1mm on the center of the bowl while on the bike, this should be correct right?
    Open headers were infact causing reversion, and the popping went away after I made baffle flutes on the collector outlets. Hoped restricting the open 38mm tips down to ~18mm would have also helped with the mixture but no dice. Still having the rpm hover...
    Tried to re-sync the carbs with YICS blocked. Managed to find perfect diameter rubber hose that sat extremely tight in the channel when I screwed a 5mm threaded rod through it. No noticeable difference on manometer readings with YICS blocked, won't bother with that again...
    Guess I need to fiddle with the jetting again.
    What I can't comprehend is how in the world was this thing running/idling so ridiculously rich with all those previous air leaks and with #45 pilots and now starting over from #41 to 43 AFTER fixing several intake leaks it's still so lean?
    Literally no difference with the #41 pilot with those small boot leaks compared to these #43 pilots, no leaks and baffled up exhaust. How?
  26. chacal
    Couple of thoughts:
    a) does your carb set (assuming you have verified that they actually are HSC33's) have the 4 or 5 brass "nipple" ports coming off the side of the carb bodies, just to the left or the pilot mixture screw block. These would be facing rearward at a 45* angle, horizontal, tilted towards the rear of the bike? (on some models, the #2 carbie had one of those ports AND and up-towards-the-sky brass nipple port in the same general area). NOTE: these are not the bowl overflow t-fittings between the #1/2 and #3/4 carbs.
    b) have you super-verified that the AIR JETS (living under the vacuum piston rubber diaphragm) are not reversed in their positions (they can be physically interchanged). The smaller "size" (engraved onto the top of the jet) is the MAIN air jet, and should be located in the "center" hole (i.e. directly above the main FUEL jet below it), while the larger "size" jet is the PILOT circuit air jet, and should be located in the forward-most of the 3 holes (towards the front of the bike). Reversing these 2 jets (or having wildly different sizing than stock) will cause the bike to run very rich.
    c) have you verified the main jet NEEDLE size (and verify that the needle has not been disturbed within its small white plastic "head cap")? For your bike 1986 XJ750 air-cooled---perhaps a 41Y model?---I believe they should use the size Y-14 model needles (and I'm not sure of that, as some Euro bikes have used some very obscure sized jetting and needles to meet specific country emission requirements, and we do not have a comprehensive list of those variations). These needle "sizes" are (most of the time) inscribed onto the shaft of the needle, just below that head cap (note: on some models, Hitachi did away with the "Y-xx" inscription, and instead used a series (single, double, triple) circumferential engraved "rings" in the same position on the shaft....a really dumb things to do, in my opinion, but certainly easier to do from a manufacturing viewpoint).
    Original main needle size configurations are as follows:
    Y-10: used on all USA market XJ650 (except Turbo) models, 1982-84 XJ650 Canadian bikes, and 1982 XJ650 Euro (model 14R) carbs.
    Y-11: used on all 1980-81 XJ650 Euro (model 4K0 and 4K1) and XJ650 Police (37G) carbs.
    Y-12: used on all Canadian 1980-81 XJ650 Maxim, Midnight Maxim, and Canadian 1982 XJ650RJC Seca (non-yics) models.
    Y-13: used on all USA market XJ750 (1981-83) models.
    Y-14: used on all non-USA market XJ750 (1981-84, except XJ750RL and XJ750E-II) models and XJ750 Police (24L and 37H) models.
    Y-17: used on all XJ750E-II models.
    Y-18: used on all XJ750RL Seca models (1984) only.
    Y-19: used on all XJ700 air-cooled models (Canada)
    Y-20: used on all XJ700 air-cooled models (USA)
    All of the following size needles are used on Hitachi HSC40 series carbs, and are much longer (and do not interchange with) the shorter HSC32/33 series needles above.
    Y-22: 1981-82 XV920 RH/RJ models and 1981-83 XV750 models
    Y-23: 1981-83 XV750 models
    Y-24: 1982 XV920 J models
    Y-25: 1982 XV920 J models
    Y-29: all 1984-85 XV700 models, 1986 XV700SS on the #1 cylinder, and 1988 XV750 California models
    Y-31: 1983 XV920 K models and 1983 XV920 MK models
    Y-32: all 1986-87 XV700 models on the #1 cylinder
    Y-33: all 1986-87 XV700 models on the #2 cylinder, 1983 XV920 K models, all 1984-85 XV1000 models, and all 1986-87 XV1100 models
    Y-34: all 1984-85 XV1000 models
    d) other than that, I'm out of ideas!
  27. Miixxa
    Miixxa Member
    Finland
    Truly appreciate the cents chacal.
    a) Don't know how to further verify these being 33's other than measuring the throats. I have went with the thought that none of the 32's should have these extra features that these carbs have, like those extra nipples you mentioned. Check the pictures, every carb has that extra breather in the base of pilot mixture screw that I have capped off.
    b) I have verified that the air jets are okay and they even correspond to your list of variants possible. As a super-duper verification I went and took a picture. 70# main air jet is in the middle and 225# pilot air jet in the front.
    c) Now this is where it gets tricky. Previous owner said he had "replaced all the brass" in the carbs and when I tried to get more info he couldn't elaborate. When I first tore everything apart I was pretty convinced he only replaced both fuel jets and possibly the needlevalves, since everything else was caked/untouched especially in the top floor of the carbs.
    I tell you this because I do believe the needles in every carb are stock, but what throws me off is that they're only marked as "Y403S", which gives me absolutely no reference to anything...
    Any ideas on that part?
    d) you an me both! I know my writing can be a little rambling, but honestly I do try and work this out logically in the real world. Have checked and tested many other things I haven't specially mentioned, but never had this much trouble with a carb rack ever...
  28. Dan Gardner
    Minneapolis, MN
    Looks like 33s to me - they have the funky air vent at the top
  29. chacal
    The Y-403S (actuyally, I think it's Y-403Z according to my info) are reproduction needles that correspond to the stock Y-14 needles, we've found that the repro needles are very high quality/precision, so that isn't (shouldn't be) the issue.
    The brass vac ports next to the pilot mixture screws.........do you leave those un-capped or use a rubber cap over them (like the rubber caps used on the intake manifold brass vac nipples)? If I recall correctly, you can have running issues if you leave those un-capped, while on other models you have to leave those un-capped and attach a long vac hose to each of them (about 16" long or so) that drape over the carbs and then hang down and are open to atmosphere at their far end. I believe they are part of some type of emissions control system on XJ700 models (here in the USA) but there is absolutely no usable/explanatory documentation about them in the factory manuals.
    In North America....the only place that the HSC33-equipped XJ700 models were sold --- the carbs were jetted really, really lean from the factory (in order to meet stricter and stricter emissions requirements) and was partially mitigated by using a very skinny ("rich") main jet needle....but that "richness" only occurs at above-part-throttle conditions. They also used a different emulsion tube, a different vacuum piston unit, and a different vac piston spring (the long slinky one) than their little brother HSC32 models (and all those items will physically interchange between HSC32 and HSC33 carbs, but they are different....and by the way, don't ask me what the differences are or how to verify the differences, because besides the vac piston return springs, I can find no visible or measurable differences between the HSC32 and HSC33 versions, even though there must be some).
    My guess is that Yanaha/Hitachi was having great difficulties around this era (1983-up) with meeting both emissions requirements and providing performance, which created a lot of interesting mix of jetting and other internal components within the carbs. I know that a lot of people (including myself) have experienced a lot of tuning difficulties with the HSC33 series carbs.....much like what you are experiencing. I think the solution that I came up with was to plug up / block-off those brass nipples by the mix screw ports, and only then could you get the engine to operate properly. But I think others have reported the reverse siutation, and if I recall correctly, one method works on the 1985 air-cooled XJ700 models but doesn't work on the 1986 models --- and although the carbs are "basically" the same externally, there may be internal air flow passage differences --- even though there's no internal jetting differences between 1985 and 1986 model carbs, that could play a factor.
    And for extra fun, California model carbs had an additional vac port up there (only on the #2 carb body) which ran to a "charcoal cannister" emissions device, and which caught fuel vapors out of the tank and re-circulated those vapors back into the #2 carb (so that carb was always going to run a little richer than the others, especially on very hot or very low outside-air-pressure days, as those conditions will cause more fuel-in-tank evaporation----and of course also depended on the proper operation / condition of the YICS system, which "shares" fuel mixture conditions amongst all of the carbs).
    Holy Mother of God, this was the pinnacle of carb design tweaking madness.........
    And if that's not enough, on both years there are some differences between California and non-California carbs, since (at that time) California had much stricter emissions regulations than the other 49 US states.
    The FUEL LEVEL specs were also dramatically changed, from 3mm +/- 1mm on HSC32's to 1mm +/- 1mm on the 33's, raising the fuel level in the bowls significantly (and higher fuel level = less vacuum suction needed to deliver an equivalent amount of fuel thru the jetting).
    If you held a gun to my head and made me guess, I would theorize that those 4 brass ports atop the carbs are part of some air regulation system that affects the rate of rise and fall of the vacuum pistons, which in turn lifts the main jet needle......and recall, the Y-14 (Y-20 in the USA) needles are among the "richest" needles (once off-idle) of any of the HSC-series needles, so if the vac pistons (and main jet needles) are rising too much (even at idle) that would cause a rich situation (up to about 2000-rpms, as only the pilot circuit is active at those speeds, it's providing 95% of the fuel supply, and thus not influenced by the main jet needle size or position). HESC32 series carbs had 2 rather large-bore "air compensator" jets in the rear of the carb throat (facing the airbox) which were eliminated on the HSC33 carbs....there are just wide-open holes on the 33-series in those locations.
    Perhaps those ports were also designed to restrict vacuum suction within the bowls, thus reducing the fuel draw at lower rpm's, and lowering emissions.......in that era, about the only way to win the emission game was to really lean out the engines at idle/off-idle speeds, since it's at those speeds where the EPA emissions testing was done.....hence, if you could lean out the engine dramatically at those engine speeds, then you passed the test, and if the engine got "dirty" at higher rpm's, who cares? So we'll design things to be ultra-lean at idle/off-idle and just richen the crap out of it once the main fuel circuit comes into play to regain performance and operational stability.
    I mean, that's what I would have done......
    Again, no documentation from Yamaha on the "air compensator" jets purpose, but they vent directly into the bowls, and I've always assumed that they just provide atmospheric air pressure to the bowls so a vacuum lock doesn't develop in there. On the HSC33's, those restriction jets disappear and all of a sudden those brass nipples appear on the top-side of the carbs (as well as the overflow ports between adjacent carb bodies). Something subtle-yet-major was going on for all of these changes to occur, and I'm not enough of a fluid dynamics / carb theoretician to understand exactly what they were from a "system-wide" perspective.
    Try plugging off those big carb nipplea top-side and see if that helps. Or, if they are already plugged, remove the plugs and open them to atmosphere.
  30. Miixxa
    Miixxa Member
    Finland
    Yup, and all the jetting etc. matches on info about 33's + the missing jets at the throat makes me believe they're 100% 33's
    That said, despite having a massive headache st the moment I ripped the rack off again since the throttle axle started sticking for some reason, probably because I mistakenly left the petcock open and flooded the carbs...
    Well took the bowls open again and actually compared the "original" pilot jets I have drilled out to 45# that were causing massive richness and my aftermarket 41-43# jets and the orifices are visibly different sizes. I mean I can't see a difference between the undrilled after market ones, but compared to the drilled 45# there's a massive difference. As a test I drilled one to supposedly a #30 and even that is visibly larger than the 41 and 42 aftermarket ones.
    All this leads me to believe that:
    1. Drilling jets is BS (sherlock moment)
    2. The aftermarket jet sizes are all over the place.
    So tomorrow I'm going to get some larger sizes of these cheapo jets and try something I can eyeball between these empirically determined lean and rich jets. Seems like it's a crap shoot to get the sizes right with these kinda jets...
    Anyways, if that doesn't work my thinking now is that I was way closer on the mixture with the drilled jets and may just have the floats too high up. That's the next step after trying some "middleman" aftermarket jets.
    @chacal thanks for that very thorough input again.
    The needles are in fact stamped Y403S, I have quadruple checked and it's even visible on that previous photo. No idea hot that differs from the Z needle...?
    I have actually blocked those extra nipples with rubber caps and since I got the enrichment plungers corrected and seal up, it makes no difference if they're capped or not. With the leaky plungers capping them clearly richened up everything and vice versa. Cyl 1. was the worst and real easy to test on the fly...
    The nipples actually are just a straight channel into the enrichment barrel holding the actual plunger and spring. I have determined their only use is/was to provide extra air to the enrichment circuit by engine vacuum only. I can't see any other way of operation for these since they don't have a way of connecting into anything else internally
  31. chacal
    Well, maybe, but I can't visualize why you would need to provide any air to the enrichment (I'm assuming you mean the "choke" / starter circuit) since that circuit has a pretty precise, fine-control mechanism already built into it (the rotary thumb knob on the LH handlebar control switch). And that circuit is a rather "coarse" design anyway, and since it's only used (in theory and practice) for just a very insignificant amount of time (compared to all of the other air and fuel circuits and components in the carbs), going to all that trouble in carb re-design for just that typically un-used circuit seems like "a lot of sound and fury signifying nothing" (that's a bit of Shakespeare for those keeping score at home........).
    And, if I recall correctly, emissions testing was conducted (at that time) on an engine that was already warmed up, meaning the choke system wouldn't be contributing to any emissions at all, as a warmed engine doesn't require choke/enrichment usage.
    But like I said, I may be all wrong about all of this........I'm just trying to think my way out of the box of emptiness (information-wise) that Yamaha left for all of us.
  32. chacal
    Yes---especially if one used once of the aftermarket "performance" kit that supplies different sized fuel jets, recommends drilling the vac piston ports, cutting the vac piston return spring, etc. Their jets may be engraved as (for example) a #43 pilot, but that "#43" size may not have any relation to an OEM Hitachi "#43" size (oem sizes are millimeter measurements of the fuel passage hole on Hitachi fuel jets...a #43 jet is 0.43mm diameter, a #36 jet is 0.36mm diameter, a #122 main fuel jet is 1.22mm diameter, etc.). Note that this applies to Hitachi fuel jets only; Hitachi air jets use a completely different "formula" for air jet "sizes".
    And Mikuni fuel jet sizes bearing no relation to any physical size, so for example, a #35 Mikuni fuel jet is not 0.35mm diameter......unlike the much more logical (to me) size marking criteria used for Hitachi fuel jets (even though most people would agree that Mikuni carbs are much more of a "performance-designed" type carb than similar Hitachi carbs).
    Hitachi fuel jets are "sized" in a much more user-friendly manner, while Mikuni fuel jets are "sized" according to engineering principles:
  33. Miixxa
    Miixxa Member
    Finland
    I think you're correct on everything and I really have no answers to why Hitachi did this to the 33's. All I know is that the extra "breathers" don't lead into anywhere other than directly into the starter circuit plunger barrel and that it draw massive amounts of air (and fuel) into the cylinder with a leaky plunger... Original hose routing from those nipples should lead directly back to the airbox which supposedly has some kind of vacuum inside of it too so...it feeds just a little bit of extra air? Who the heck knows at this point...
    Luckily other than the fuel jets and needles everything else seems stock and there are no drilled orifices in the piston etc...
    I did some digging and like I previously said I have used Dellorto fuel jets for now, I found some data that while dellorto/hitachi jet sizing is the same (1/100th of a mm) the hydrodynamic properties of the jet orifices is radically different. Dellorto has longer jet orifice and different tapers on it which drastically lowers the flow rate of the jets. Meaning Dellorto 43 jet is radically leaner than proper Hitachi 43 jet.
    Basically I screwed myself trying to be clever + the fact that these cheapo jets really don't seem to be sized correctly as I physically can't fit a 0.3mm micro drill bit through a 43# marked jet...
  34. chacal
    Now that is interesting and something that I didn't know (or even considered, more than in a very vague and hazy way). I've never seen flow rates for Hitachi jets, and from your description it seems as though Mikuni "sizes" their jets in the same manner as Dellorto (although probably using a different standard). Jet sizing is one of the blackest of black arts.
    The most extensive (and understandable) discussion of jetting issues that I've come across is here:
    For further insights and understanding, the Holy Grail (meaning: the whole miserable, un-varnished truth of what a real chore carb tuning is going to be, written by people who actually know what they're talking about, rather than by people who are trying to sell you something) can be found at:
    www.factorypro.com
    and then click on the "Product Support" link at the top of the page, then on the "Motorcycle Tuning Tech" link, and then the "CV Carb Tuning" link........and then read, weep, study, and do....if you still dare to! HINT: if reading through it makes you think to yourself "sheesh, this sounds like an incredible amount of effort!", well, you're right! That's just some of the joys (and pitfalls) of getting to play "tuning engineer", which is what you're going to be doing. Yamaha probably has 10 of those types of guys on staff, and millions of dollars of test equipment, both physical and computer-aided, that allowed them to get the mixture settings just right---from an overall drivability AND power output standpoint----and now, since you're changing the airflow parameters thru the engine, you'll have to figure it all out "from scratch", but WITHOUT the benefit of 10 trained engineers and all that test equipment and experience.
    which is basically why we (and many others) caution against using "pod" filters or any other such efforts to increase engine performance via fuel system tinkering (short answer: get a bigger engine!) since although all of the steps outlined in the article above are certainly do-able, that's way more work than your average wrencher is willing to go thru (racer's will, as there is pride and/or money on the line, both of which are extreme motivators).
    I'm not going to doubt you, especially if you determined this via a smoke test, but I'm still having a hard time understanding that there's some good reason to introduce some massive amount of additional airflow into the choke circuit; once the choke plunger valve is lifted, the choke passage leads directly into the venturi of the carb throat, just forward of the butterflies, and that vacuum effect draws lots of fuel up thru the choke circuit.
    And there's actually an air bleed passage in that brass tube for the choke system that comes down from the bottom of the carb body and dips into the bowl "well" where the tube sucks up fuel from....it's a tiny hole and easy to miss unless you look closely for it.
    The open ends of the rubber hoses don't go into the airbox (that would introduce a mild vacuum, and would possibly suck fuel/air out] of the circuit). The hoses are open to atmosphere at their other end, as are the "bowl overflow" t-fitting hoses between adjacent carbs (as are the bowl vent ports in the back of the carb throat --- although since those are in the flow path of the air from the airbox, I imagine there is a positive pressure introduced into those ports, in effect pressurizing the inside of the bowl a small amount....the HSC32 carbs even had restrictors for that passage ("air compensator" jets they were called......I've always wondered what form of "compensation" they were providing, as the name of those jets are rather specific but vague).
    We need to find a retired Hitachi carb engineer that we can strap down onto a chair, put bright kleig lights onto, electrodes onto his balls, and force him to spill the beans.....
  35. Miixxa
    Miixxa Member
    Finland
    Well, being the stubborn tinkering millenial I am, I have heavily outsourced all data mining to AI and I believe one of it's sources was exactly that site!
    I have also lived in the false reality that jet sizing is just sizing and f.e. Dellorto has basic mm sizing since my moped days... Never even occured to me that there are other factors in play and I'm literally a freaking mechanical engineer... Live and learn I guess, but now that I think about it, it sure does make sense.
    Fun fact, I got a load of the Dellorto jets and f.e. Dellorto 50# has no perceivable difference when compared to an 41# but they're both visibly smaller than Hitachi 45#...dunno what to think of that really.
    As I'm not building an actual racer I rrslly don't care what kind of power I get out of this thing. I only care about the design/looks and that it just works properly. Secondarily I don't have most of the original parts like the airbox and I'm just stuck at getting it to work like this. Thirdly I'm a bit of a masochist and apparently enjoy this tinkering since I'm coming back to it daily.
    And you're quite right @chacal on the extra breather hose routing, I totally remembered wrong. They are in fact just open hoses under the air box. Again I outsourced things to AI and you can take this with a grain of salt since I didn't go through all the sources but:
    According to AI these extra breathers on HSC33 1984-1986 models are in fact atmospheric equalizer vents for the upper part of the carbs. "They are uniquely configured on these specific carb castings to maintain balanced atmospheric pressure inside the upper sections of the carburetor circuits"
    The open vents are then routed with hoses under the airbox for obvious reasons.
    And to further kick myself I asked what happens if I cap these vents:
    - "If you cap these ports, your engine will experience severe fueling issues, primarily a massive rich condition at idle and a total loss of throttle response."
    - "Fuel Siphoning (Extreme Rich Condition), Because these lines provide a necessary atmospheric vent to the upper pilot circuits, capping them turns the idle fuel circuit into a closed straw."
    - "Rough, Hanging, or Impossible Idle, Without atmospheric pressure venting the top of these circuits, the pressure differentials inside the carburetors will become completely unstable."
    Well...I'm speechless. The "best" part is that I originally had these ports open and hosed under the carb rack to open air. I also had the actual bowl vents/overflows hosed up all the way to the rear swing mounts. I watched some youtuber dude building a caferacer and giving a lesson on CV carbs where he mentioned to remove the overflow tubes since they can affect the fuel level in the bowl without active airbox vacuum...And I guess with that in mind I first removed those extra breather hoses too and capped them off since it seemed to work better that way. (Which I do realize now it was just an accidental result among all the issues)
    ...at least this clusterknot is starting to unravel now. Time to retrace my steps somewhat and un-cap the breathers, add snorkel hoses to them and start fiddling with the jetting again.
    Sigh, I basically bamboozled myself again but this thread sure as hell got my grey matter moving, so thanks for that everyone!
    chacal likes this.
  36. chacal
    Wow.....I'm stubborn too (though not a millenial), and I am / was an M.E. also.....but really, air flow is the realm of physics (fluid dynamics) and as one of instructors once observed, all you really need to know about physics is "F=Ma, and you can't push on a rope". Life-long good advice........
    You're finally getting that degree in fluid dynamics that you always dreamed about....
    Umm, I'm getting a queasy, un-easy feeling about this AI guy, whoever he is. "Balanced atmospheric pressure" inside the upper sections........I wonder what "sections" they are referring to? The area under the vac piston diaphragm sees "atmospheric pressure" due to the large, curved vent at the rear of the carbs (above the throat, but still open to the airbox), and which dumps directly into that chamber where AIR jets are located, and then actually also exhaust itself thru the choke passage ("after" the plunger, and before the exit port in the carb throat). I was always of the assumption that is was this flow of air (along with the pressure drop after the venturi section in the carb throat) that was used to suck the fuel up thru the choke passage.
    What? The idle (pilot) fuel circuit starts at the pilot fuel jet in the below, sipping gasoline from the bowl, travels past the mixture screw, and then goes directly to the 3 little holes just past the butterfly valve directly into the carb throat.
    https://www.xj4ever.com/inside your carbs.pdf
    Looking at these pictures again, I see that there is no direct dissection of the big brass nipple on the top/side of the body....luckily, it was actually an HSC33 body that was ritually sacrificed for this project, so I'll have to go dig thru the largest pile of "other stuff" imaginable to see if I can find those pieces and see where that port/passage actually leads to.
    Okay, then why would capping them lead to "fuel siphoning (Extreme Rich Condition)" (as if it was a "capped straw")? "Capping" and "closed straw" would seem to imply little to no fuel passage, which surely can't (by itself) leads to an "extreme rich condition"....could it? Siphoning thru what? Where? You can't really siphon thru a capped straw.......
    Oh my, it's AI: https://www.xjbikes.com/forums/threads/xref-from-xjcd.133554/#post-693982
  37. Miixxa
    Miixxa Member
    Finland
    Yeaaah, fluid dynamics is fun... Not saying I'm any good at it, but I have some experience from the modeling world as I've built and tinkered with flying RC objects since the 90's.
    And like you so wonderfully pointed out this AI guy is dumb and often contradicts himself. Like I said, grain or few of salt. Luckily I'm a 90's kid and actually capable of fact checking. As a clarification, I use AI as a tool, not as a source. Put those quotes on there as is because to me they point a direction I need to know and actually dig through those sources AI used (like chacals wonderful writings on the matter). Despite what that AI spewed out I'm still stubborn and think these nipples can't affect the actual carb circuitry, unless there's sone hidden passage somewhere I just haven't seen...
    I also need to check the carbs myself if those extra vents actually have anything to do with anything, but at this point it seems like the safest bet is to open them up and otherwise get the setup as close to stock as possible minus the airbox and related fuel jetting. Anyways need to test them open since I haven't even tried if it has any effect at all now that all the air leaks are solved.
    Now that you(chacal) mentioned about the air compartment exhausting itself into the choke passage, if that's what the extra breathers are for - to release pressure from the air jet chamber? Can it cause an air lock in there where air rushes in builds excess pressure without being able to vent into the choke passage and out of those breathers?
    It would be great if you find that dissected 33 from the pile and can provide any sense on those ports, because they have been bugging me from the beginning of this project!
  38. chacal
    Exciting "Breaking News" incoming, stay tuned for the full report later.......
  39. chacal
    As promised:
    It is with mild embarrassment and great chagrin that I must admit that I was (probably) wrong about a few issues regarding these HSC33 carbies.
    After carefully fiddling with the razor-sharp sectioned remnants, I was able to put them back together in their correct order, and I have come to observe the following:
    a) the brass nipple on the side of the mixture screw porch exclusively empties its contents into the internal choke gallery. The length of hose attached to the port possibly serves to both eliminate any "backdraft" fuel splatter which may occur, as well as serving to streamline the air flow into that cavity.
    b) this method of creating airflow past the choke plunger (when un-seated) is different than from where this airflow "river" was sourced on the HSC32-series carbs, as that same choke plunger "cavity" on the HSC32's carbs receives its air supply from the area under the vac piston diaphragm (where the air jets live) and swirls around a curving opening (cast, not machined) and into the choke plunger gallery.
    c) what everyone refers to as "bowl overflow" T-fittings (and attached hoses) on the HSC33 carbs are actually bowl vents (although, if you lay down the bike, fuel from the bowls may indeed overflow into those T-fittings and attached hoses). Those t-fittings (fitted between carbs #1 & #2 and also carbs #3 & #4) lead to internal passages which are open to the fuel bowl, and then pass directly to round, un-threaded and jet-less openings in the rear of the carb throat
    Since I feel that you can only have positive pressure from the airbox, this jet-less passage serves to ventilate the bowl to atmospheric pressure.
    Interestingly, only one of these 2 "back of carb throat passages is actually functional.....the one side closest to the location of the T-fitting is active, while the other side on the same carb body one is a "blind hole / dead end".
    c) the HSC32-series carb have those "air compensator" jets that was discussed previously. On those carbs, both holes are threaded, have a fairly large passage size screw-in brass jet, and both holes on each carb body vent into the carb bowl.
    d) one last thing of possible interest: on both HSC32 and HSC33 bodies, there is a small drilled passage between the bowl cavity (far above a typical fuel level in the bowl) and the long, oblong depression in the bottom / forward / center of the carb body (next to the brass suction tube). This oblong depression leads from that drilled passage over to (and surrounds) the round opening in the carb body for the choke fuel "well" .... the brass suction tube for the choke system drops down into this fuel "well". So whatever is happening in the bowl (pressure-wise) is also happening to that choke well in the bowl (again, the air pressure in the bowl above the level of the fuel.
    e) I still believe (and may possibly be completely wrong, so hey---all you fluid dynamics guys out there speak up!) that all these somewhat significant changes between the HSC32's and the HSC33's had something to do with meeting emissions standards in relation to the pilot fuel circuit: bigger carb throat diameter (more airflow), a 20% reduction in fuel jet physical size (and who knows how much of a reduction if pilot fuel flow volume), the blocking off of the choke airflow passage and bring the air in from a different direction, and "shared" bowl venting happening from the upper side of the carb body rather directly from the rear of the carb throat.
    A riddle wrapped in a mystery inside an enigma, as Winston Churchill would say........
    Miixxa and Fuller56 like this.
  40. Miixxa
    Miixxa Member
    Finland
    Great insight on the soul of the carbs again! Valuable info on all parts and I got excited for a while because I felt my brain edging on the verge of finally putting all of this together, but no dice.
    Either none of the post-mortem data relates to my issue(s) or I need to ponder on it for a moment to finally wake up screaming "Heureka!" at 4am...
  41. Miixxa
    Miixxa Member
    Finland
    This thread has now took a little detour, but since I haven't had the motivation (or time) to do anything practical on the bike here goes:
    Some sources say that on California models those extra breathers are directly connected to an EVAP system of some sort, but those sources also say there would be some sort of vacuum operated extrerior valve system too. I imagine the overflow/bowl pressure breathers would also be connected to such system...
    This part bothers me, as I'm not sure what these un-threaded passages are? In my rack the "overflow" T-fittings just pass through the body into the ceiling of the bowl cavity. I didn't spot any extra passages inside the T-fitting holes. Do you mean the filter side of the carb orifice where the compensator jets are in 32's? Because again on my carbs both of these holes are just blank dead-end holes on every carb...
  42. chacal
    Yep, same here. I'm almost certain that all these changes had to do with stricter emissions standards that were coming along at that time, but I'm not versed enough in the nitty-gritty details of carb theory and operation to suss out the design changes and their impact.
    Mikuni carbs (at least the BS-series as used on various XJ bikes of this era) didn't seem to undergo such changes, and the changes that they did undergo seem to be almost exclusively related to performance-enhancement: adjustable, multi-position main jet needles and the like. The only "questionable" (meaning: I question why the changes were made because I don't understand enough about carb theory, design, and especially air flow effects on the total carb operation "system") is that Mikuni moved the main AIR jet from "up top" (under the vac diaphrgm, as with Hitachi carb) down to the rear of the carb throat. And of course, the strange case of the BS34 (XS1100 carbs) where pilot fuel supply was drawn/supplied thru the main fuel jet (rather than thru a separate opening for the pilot fuel jet) and then switched back to the more traditional "separate main and pilot fuel ports" later on.
    There used to be, in the early 80's, a BBC television series called "The Secret Life of Machines" that broke down the operational mechanics of sundry "everyday" products and appliance: TV's, radios, microwave ovens, fax machines, etc. It was absolutely delightful and was basically a "How-To For Dummies" series and perhaps the best use of television programming before or after.
    Alas, they never got around to doing "The Secret Life of Carburetors"........although, I must admit, I stole the name idea from this series when I wrote the article with the same name for this website.
  43. Miixxa
    Miixxa Member
    Finland
    Well, I decided to save myself the headache of theorizing this through and continue with my trial-and-error empiric way of getting these effing things to work...
    In the picture is my solution to uncap the mysterious breathers - which I again glanced over and still have no freaking idea what it is they actually do. Ignore the color, I wen't with some silicone tubing I had laying around to get the hoses as cleanly as possible to hug the carbs. Basic fuel hose was way too thick.
    Also installed the 48# Dellorto pilots which were visually larger. What I could visually confirm is that Hitachi jets are more just a drilled hole in brass, while Dellorto's have longer hole orifice which is tapered in and out through the hole (as in narrower in the middle).
    We'll see tomorrow what happens. Next I'm gonna dig out the fastest place I can get proper Hitachi jets shipped to me, and move on to getting my 919 fixed to ride while I wait. Ironically the 919 is having same kinda issues with improperly aligned throttle flaps...
  44. chacal
    I've never fondled a Dellorto jet, so just based on your description, a Dellotro jet also has / acts as a venturi, providing both an acceleration of and a pressure drop to the fluid(s) moving thru it.......very interesting.
    BTW, the float bowl on that #1 carb is really for a #3 or #4 carb, as the threaded drain screw port (where the drain screw enters) is supposed to point "outwards"....like on the #2 carb shown in your image. Besides this "left-" vs. "right-handness" feature of the bowls, they are otherwise fully interchangeable, which is why they sometimes get mixed-up positionally. Having the drain screw ports facing "outwards" makes them (much) easier to access when the carbs are on the bike, so you can check fuel levels, drain the bowls for winter storage, etc.
    NOTE to HSC32 owners: while their bowls have what appears to be two drain screw ports----one in each direction, so that the bowls could be used on either side or the rack, actually only one of the ports is threaded and active....so there is still a left vs. right side difference in their bowls, too.
    HSC32 and HSC33 bowls are interchangeable, but the HSC32 series bowl use a larger starter jet orifice (0.40mm) vs. the HSC33 bowls (0.36mm)......and the best idea since pop-top beer was found in the 1980 (only) HSC32 bowls, which had removable starter jets (they had a screw slot in the head of the jet, just like the pilot and main fuel jets) so you could remove them easily and clean them out of the crud and sludge that accumulates down there. Later HSC32 bowls have a pressed-in starter jet that are a real pain-in-the-bowl to clean out, especially if the leftover fuel has crystallized and turned hard as a rock......
  45. Miixxa
    Miixxa Member
    Finland
    Of course, the one time I share a picture and I manage to mix up the bowls, which I have very dilligently put on the right carbs for the past ~30 times during all this...
    Nice info again on the carbs, the starter jets on these 33's really were a pain in the ass to clean until I realized I have access to industrial ultrasonic washer and parts pressure washer!
    As an afterthought, I have to ask second opinion on that channel in the upper bowl cavity which leads to the starter fuel well - all of which you mentioned in your post-mortem report.
    Like I said the wet fuel level is exactly 1mm below the bowl joint surface on the carb body and at the middle (hitachi logo) point. Now that I think about it when the carbs are installed on the bike, they're tilted enough for the wet level to be about 5mm lower at the rear of the bowl and vice versa on the front. I feel like the fuel level at that point is way too close if not at that starter well channel and could cause all sorts of gremlins...?
  46. Dan Gardner
    Minneapolis, MN
    Which side the bowl is on makes no functional difference so don’t worry too much about it. It’s just a matter of being able to access the drain screws while mounted on the bike. If you live somewhere where you need to winterize and drain the fuel it’s a nice feature.
  47. chacal
    Well, Yamaha/Hitachi very explicitly states (service manual) that the fuel levels be checked with the carbs on the bike, and not on the centerstand or side stand.....and to use some type of spacer or jack to adjust the carbs so that they are in "so that the carburetor is positioned vertically" before checking the fuel level......and no mention at all about horizontal vertical orientation. And then a little drawing showing the fuel level tube gauge, with the gauge placed off to the side of the carb being checked, at about the centerline (front-to-rear) of the carb body----rather than at the rear of the carb body (where the drain screw nipple is). In my understanding, the carb set will be tilted forward at about a 10* angle.
    It then goes on to explain that you should check the level on the #1 carb (off to the side, of course) and then check the #4 carb and compare the levels.....and they should be equal, and if not, use a "wooden shim or the like under (one leg) of the centerstand until the #1 and the #4 carb fuel levels match" (no matter what level that they're at....adjusting the level (distance) comes next).
    So nowhere do they give any hint of what horizontal level (or forward/rearward "tilt" should be or whether it is critical. This makes sense, I guess, since the fuel level in the bowl makes no distinction as to where in the bowl the level is at, since no matter whether the fuel has sloshed forward or rearward, the same "level" will be read on the gauge.
    Next comes setting the fuel level to the correct height (the correct "fill" of the bowl), no matter where in the bowl the fuel actually resides at the time of measurement; fluid fill in an external gauge doesn't depend on (within limits) the actual physical location of that fuel in the bowl.
    So then, one at a time, your measure (and adjust) the fuel level in each carb to get it at the specified level......and note that the measurement is the distance "below from the carburetor mixing chamber body edge". Now this rather cryptic "mixing chamber body edge" is nowhere defined precisely anywhere in the Fuel System section of the service manual, but there is a handy little line-drawing showing where this physically is....it's the very bottom of the carb body, where it overlaps and drops down a bit over the outer edge of the bowl (and not at the top edge of the bowl itself), as the bowl fits "up" into the sunken recess of the carb body by a few mm's or so. So you really don't measure the fuel level "below the top face of the bowl" (which you can't see anyway, once the bowl is on the body).
    Pages 26-28 on the vivisectioned carb bodies article (at https://www.xj4ever.com/inside your carbs.pdf ) shows the FUEL flows thru a Mikuni carb starter circuit, but not the air flow....and of course Mikuni carbs didn't have that brass port under consideration. But trust me (and you should verify it for yourself; your smoke generator would be ideal for this task) that air (smoke) blown into that brass nipple (with the choke plunger valve closed) will go directly out of the choke circuit opening in the carb throat......and if you open the choke plunger while performing the test, the only places smoke will go are out of that same opening in the carb throat and back down the little brass suction tube at the bottom of the carb body.
    My thoughts are that perhaps your issues are caused (or compounded) by the use of the Delltoro fuel jets......although they may physically fit the threads in the carb body, there may be enough differences in fuel flow characteristics that is over-supplying fuel (or maybe just fuel velocity thru the circuits.....or both) into the carbs that is causing (or magnifying) other issues. XJ700 airhead carbs have always been somewhat sensitive to tuning issues and jet changes (more so than the hsc32's or Mikuni carbs) and again, I think that these carb sets were designed and set-up at "the edge of perfection" to meet emissions requirements, and even very minor deviations in any parameters (including fuel levels, jet sizing, etc.) results in not only emissions issues, but also performance and operability issues with those HSC33 carbs.
  48. Dan Gardner
    Minneapolis, MN
    And also - if you do need to drain them, get the socket head drain screws from @chacal - you’ll thank me later.
  49. Miixxa
    Miixxa Member
    Finland
    Yup, luckily I have the original XJ900 manual which has been a great help but it being a 900 manual it has no actual help regarding the carbs... And again I'm not sure what the correct wet level for this specific setup should be so I might have gone through issues like too low level and too large jet or vice versa...or the jetting may have been okay at one point and fuel levels off... I have a (bad) habit of switching several things at once and shooting myself in the leg as a result...
    And I know exactly what you mean, I have already had to dig one of the drain screws from under a blob of silicone and force it out. I have since ground new flathead slots on every screw...
  50. Miixxa
    Miixxa Member
    Finland
    Aaand my Yamaha just keeps on giving...issues I mean, with comic relief.
    Managed to get some time and test the current carb setup...only for the starter to crap out. Not surprising as I already knew the brushes were worn and McGyvered in place.
    Less surprisingly these carbon brushes are not that readily available and here comes the comical part: you would not believe where I found direct replacement brushes...in stock...already in my hand. The local "everything shop" had these electric outboard motor replacement brushes just hanging there on the shelf...which are the exact correct size.
    This thing is literally turning more and more into frankenbike at every turn...
    Fuller56 likes this.
