85 XJ700N Partial Restoration
Discussion in 'XJ Technical Chat' started by actioinfamia, Jun 1, 2026.
  1. actioinfamia
    actioinfamia New Member
    Kansas
    Hey guys,
    I think I went from "I'll do a few maintenance items" to basically restoring half the bike lol.
    1985 XJ700N.
    So far I have:
    - Changed engine oil and filter
    - Changed final drive oil
    - Replaced rear brake shoes
    - Removed rear wheel and serviced everything there
    - Replaced the valve cover gasket
    - Repaired the turn signal switch
    - Removed carbs and diagnosed a flooding issue
    - Bought float valves and carb parts
    - Rebuilt one front caliper
    - Bought K&L piston/seal kits for both front calipers
    - Bought a master cylinder rebuild kit and sight glass kit
    - Bought NGK BP8ES plugs
    - Bought new grips and various OEM/NOS parts
    Today I finally got the pistons out of the left caliper. That alone felt like a victory. Cleaned everything, cleaned the seal grooves, installed new seals and got the pistons back in. The pistons had some scratches. One of them I could feel slightly with a fingernail. The brakes didn't leak before, but since I already bought the K&L piston kits I'm leaning toward pulling them back out and installing the new pistons instead.
    A couple things I'm still unsure about:
    1. What torque are you guys actually using on the caliper half bolts? I've searched old threads and found a lot of discussion but no clear Yamaha spec.
    2. What torque are you using on the caliper mounting bolts and banjo bolts?
    3. If you were in my shoes, would you reuse the original pistons if they had a scratch you can barely feel, or just install the new K&L pistons since everything is already apart?
    4. Any common mistakes I should watch for when rebuilding the master cylinder and bleeding the system for the first time?
    Honestly I'm a little nervous about the brake rebuild. I don't mind rebuilding carbs, replacing gaskets, chasing electrical issues, etc. But brakes are one of those things where I really want to get it right.
    At this point I probably have around $600+ in parts sitting in the garage and I'm committed whether that's smart or not.
    Any advice is appreciated.
  2. Rayzerman
    Rayzerman Member
    Ontario Canada
    I'll offer torques for general use on other bikes..... torques are usually assuming dry threads, no lubricant. Caliper halves ~24 ft. lbs., caliper mount bolts ~25 ft. lbs, can use blue loctite. Banjo bolts ~22 ft. lbs., the crush washers (aluminum or copper) will keep those snug. Be sure to use new crush washers.
    One thing I do on an empty brake system is fill the reservoir, open the bleeder and let it sit for a bit... gravity may work, and you'll see fluid dripping out the bleeder if it does. The trick is to get the master cyl. primed so you can pump. Some reverse fill with a syringe at the bleeder until you get fluid into the reservoir. Or you can loosen the banjo at the master cylinder to bleed off air and get the flow started. Vacuum bleeder will work as well to get flow started, but I prefer conventional bleed after that.
    I'm sure othere with experience on these Yammy's will have some other advice or techniques.....
    Fuller56 likes this.
  3. actioinfamia
    Kansas
    Done! It works without proper bleeding I'm a little surprized. I did use the zip tie trick and a few rides around the block.
    Rayzerman and Fuller56 like this.
  4. Fuller56
    Fuller56 Well-Known Member
    @actioinfamia, congrats on the success of so far. Financially, are you having fun? You have a nice bike running and riding that will serve you well for years. Even if you have to put some money into it the cost will be far, far less than buying a new bike. Maybe not the modern amenities of the newest bikes but you have the fun and satisfaction of fixing it yourself.
    As @Rayzerman said about the brake bleeding, sometimes you have to use all those procedures to get the job done, sometimes just the basics and it works. Good Luck, ride safe and Have Fun!
    Rayzerman likes this.
  5. actioinfamia
    Kansas
    Happy! I feel like I might stripped one of the intake manifold bolts or the threads in the engine but no leakage signs so far. I might be unnecessarily anxious too. Everything works like it should. Extremely happy about how it turned out. Spent approximately 1.5 k on parts and supplies and tools but worth it.
    I am sure I'll work on it in the future non stop but take a look at it!
