XJ650 Starting issues
Discussion in 'XJ Technical Chat' started by RideAlong420, Oct 10, 2025.
  1. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    If your petcock leaks on prime, time for a rebuild! I should never leak.
  2. RideAlong420
    RideAlong420 Active Member
    USA
    Yet another thing to buy
    I tried cleaning the alternator off with a crocus cloth, unfortunately, the brush plate, I'm only able to get one of the two screws off. One of them absolutely refuses to come off. I tried the vice trick i used on the carbs, I don't have a good enough angle or grip.
    I hesitate to use a impact Hammer, because of the plastic, though now I suppose I could use like a flathead and a hammer, to do the same thing. If it destroys the screw, I don't care because I have a replacement.
    It seems I can take the stator out, but the cable isn't quite long enough to maneuver it out of the housing.
    It looks to me like the order of operations to replace an alternator gasket is to first remove the starter motor.
    Looking at it though, are you able to remove the starter motor slightly without needing to remove the air box? There is not a lot of clearance
  3. RideAlong420
    USA
    Well I wasn't able to get the other screw off so I just put the new Allen key bolt on the other screw that I could get off.
    I charged the battery back up. The voltmeter is apparently reading it at 13.3v, I go to turn the bike on, and the main fuse blows.
    Is the bolt too long and it touched the alternator? Is the rotor rotated slightly that it touched a case bolt? I don't know.
    The main fuse blew immediately as I turned the key on. I didn't even get the chance to start the bike
  4. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Glurk.
    Well you know it didn't do that before your excursion.
    You have a short somewhere that's for sure.
    Let's not fry the regulator or TCI, that would be bad.
    Pull it all apart and inspect before moving forward.
  5. RideAlong420
    USA
    Yeah I'm not sure. I only touched the alternator and the battery. The only thing I can think of is that the stator got rotated slightly and is touching a case bolt, or maybe the allen bolt on the brush plate is too "tall" and is touching the rotor? Maybe one of the cables that goes to the alternator/rotor got frayed? the edge of the alternator cover does seem a bit sharp and I tried not having the cable rub against it while I was fighting the bolt.
    I really wanted to get the cover off so I could polish it but now ugh.
    I couldn't get the stator off, because the cable isn't long enough and the stator is too "deep", without removing the starter motor, and I was hesitant to touch that, since the clearance to remove the bolts is already quite shallow, I wasn't sure how long the bolts are, and whether you'd need to take the airbox off in order to have enough space, or if you could just unscrew the bolts halfway to lift up the pressure off the cable. Too many unknowns.
    One of the two screws on the brush plate WOULD NOT come off, debated going out and buying one of those like, tools you use to extract broken bolts (it's not broken but some edges are slightly rounded but it's still savable, but I figure those might have extra "grip"). I tried my JIS screwdrivers but these ones are "shallow". I found a Philips that fit it well, but it was feeling like it was practically welded in there. The other one came off, without too much effort, and I couldn't find any loctite in the hole. This one must have something, I assume.
    Anyways, I left it where it was and just replaced the one I could remove with the allen screw so it would be easier in the future to deal with.
    There is a voltmeter/usb-c charger connected to the battery, which has it's own 10A inline vacuum fuse, and there's nothing there touching the battery or other components, and that is working fine.
    Looking at the circuit diagram, main fuse deals with ignition, R/R, AC, and rear light. I really doubt it has something to do with the rear brake lights (keep in mind everything there was working fine before, and are now using considerably less watts and amps). I suppose the R/R could be going bad, or the TCI (unlikely), but checking over the bike I didn't see anything melted or frayed, so I don't know what else it could be. The fact that the main amp is 20a, something had to push 20~ amps when I turned the key on to trip the fuse.
    Could the battery be "overcharged" and that caused it? 13.3 seems a bit high, but I was using my slow charger that is designed for AGM batteries, it's an agm battery, and it was set to AGM. It was 13.4 technically after I blew the fuse, I turned on the voltmeter (it has an on-off switch and was set to off when trying to start the bike) and it said 13.4. I notice when I'm riding the bike that the voltmeter reads around 14.5-14.8 or so when I am going like...idk...40-50mph. So I think the charging system has been working, and I think the voltmeter is accurate.
    Google is (as useful as far as you can throw it) suggesting pulling the R/R and the TCI and putting in a new fuse and trying to turn it on again and see if it still pops. Good idea/bad idea?
  6. cds1984
    Step back.
    It has happened since the generator so.
    Disconnect it completely, check and go from there.
    The fastener thing... Heat make things expand at different rates.
    Especially steel vs alloy.
    Alloy conducts heat faster than steel.
    Applying heat to alloy helps removing stubborn steel bolts and also loosens up any Loctite applied.
    Maps gas torch is handy for these jobs, although melting stuff could be an issue obviously.
  7. RideAlong420
    USA
    Especially since the brush plate is just plastic.
    I plan on towing it to the tech when I get paid Wednesday and have them look at it, but it will probably be a few weeks at least before they get the chance to even look at it.
  8. Rooster53
    North, FL
    ^^^^that is likely and you may have to use the lower profile Phillips head screw in that location.
    You could just disconnect the two pin brush connector and use a DMM to check if one of the wires goes to ground or see if the fuse still blows.
  9. RideAlong420
    USA
    I can certainly try that, replacing the screw which I didn't get rid of, replacing the fuse and then trying once more.
    I assume that the same thing would happen, if that wasn't the issue, that the spare main fuse I have would blow. You know, rather than something would melt or some other catastrophe
  10. Rooster53
    North, FL
    The DMM would be the safest choice, but blowing the fuse again should not hurt anything.
    You could put a 10 amp fuse in the main slot just to test it as the only real current draw when the ignition is switched on is the TCI driving one coil for a few seconds - unless you are engaging one of the brakes so don't do that. The 10 amp fuse will easily handle the TCI and should not blow.
  11. RideAlong420
    USA
    The main is 20 and that blew
  12. Rooster53
    North, FL
    Are you saying after you disconnected the two wire connector to the brushes as part of the troubleshooting process that the 20 amp main blew?
  13. RideAlong420
    USA
    No, I was just clarifying that before it was a whole 20a that blew, is all
  14. RideAlong420
    USA
    Shop finally got back to me. He said one of the aftermarket coils I got from Len was failing
  15. RideAlong420
    USA
    He also fixed the leaks and took another look at the carbs and says it looks good otherwise, was able to get it to run, and wasn't firing on...I think he said 2 & 3 and found one of the ignition coils (new) was bad. OEMs are a bit cost prohibitive at $200+ so I'll bring back the originals I held onto friday, and we'll see if either are still good (they were cracked and I think out of spec, barely) otherwise that's $200+ on top of existing labor :oops:
  16. cds1984
    Hopefully he said 2 and 3.
    Otherwise a single faulty coil isn't it.
    1 coil does 1 and 4 and the other does 2 and 3.
    Bad luck either way.
    Good thing you don't give up though! :thumbs up emoji:
    (Will someone change the database encoding to utf8mb4_uca1400_ai_ci already sheesh, emojis are essential nowadays)
  17. RideAlong420
    USA
    Finally the bike is done! can't pick it up till saturday but here's the synopsis:
    - one of the two new aftermarket coils was a lemon, tech happened to have a known good maxim and tested against a few things and swapped the coils around and the problem travelled with the cylinders
    - I brought the old coils which were cracked in the casing and slightly out of spec (which is why I replaced both to begin with) and tech agreed they are not worth putting back on the bike so he got a new one from reg-rect
    - fixed the oil leak behind the timing plate and the oil gallery plug (the new seal and o-ring provided from len, the left oil gallery plug seems fine so far)
    - re-checked carbs and plugs, they're fine. was having hard start and...
    - he found out the solonoid was failing and replaced it
    - he took it for a test ride and didn't see any further issues
    - confirmed the allen key black oxide screws I got to try and replace the alternator brush plate JIS screws were too tall and caused it to slightly touch the rotor and caused it to be shorted. So I guess that idea for future proofing by getting rid of stupid JIS screws for that spot is out the window unfortunately.
    - did not notice any shifting issues, says it's running fine
    for winter he suggests fully fill up tank with fuel stabilizer and fully drain out the carbs, he was very adamant about that. also remove battery and bring inside or stick it on a battery tender (it will likely be parked at a friend's garage over the winter so either of those are viable. if I don't park it there, and park it at my potential location instead, then it will not be possible to battery tend it)
    i forgot to ask about the petcock and will ask saturday when I pick it up
    cds1984 likes this.
  18. RideAlong420
    USA
    Just thinking of any possible situation to happen:
    is there a way to verify the crankcase breather hose is clear and free of blockage?
    do I just disconnect the crankcase hose from the airbox and engine, use some sort of shopvac on the hole on the engine, and spray compressed air in the airbox connector portion?
    Now that the oil leak is fixed, I'm thinking if the breather hose is clogged, the pressure would increase and have nowhere to go except out of oil seals, especially old ones
