Frame Rust/Split. Weld or Replace?
Discussion in 'XJ Technical Chat' started by jayrodoh, Mar 14, 2015.
  1. jayrodoh
    jayrodoh YimYam
    Cleveland
    Finished stripping the frame down today, found a hole and a split in the left lower frame rail. I took a hammer and punch and beat around the rest of the lower tubes and didn't find anything else. Should I scrap it and get another frame or weld and go?
    Hole:
    Split:
  2. JaiFer
    JaiFer Member
    Northern Ontario
    If that was my frame I'd cut out the cancer and grind it, then weld it. If those two are the only two spots and they seam rather small and not in a critical place.
  3. FtUp
    FtUp Well-Known Member
    pacific northwest
    I would try to weld it up before scrapping it. the split was caused by water getting in the frame and freezing. you should be able to hammer it down and weld it up.
    FU
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    Ah the split theory makes sense, bike sat last five years. Covered but outside in MI and not moved. Will grind her down a bit and see but the punch and hammer failed to find anything else so I don't think I need to section anything.
  5. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    +1. No need to scrap the frame.
    Gary H.
  6. FtUp
    pacific northwest
    no need to cut out the cancer. when you hit it with the welder, you will find out how thin the area really is. alos I would figure out a way to treat the insides of the frame tubes with "rust mort" or something similar...
    http://www.tcpglobal.com/SEM69501.html#.VQSXH6N0zb0
    I would also consider drilling a drain hole in each side at the lowest point so future water accumulation can drain out. or just keep it in the garage and never ride in the rain. not sure why Yamaha didn't do this to begin with.
    FU
  7. hogfiddles
    I've dremel-ed and welded those shut on some bikes as long as its not at a stress point
  8. k-moe
    Welding on a rusty frame will let him see how bad the rust is; it will also contaminate the weld.
    Cut that rust out, cut a patch if needed, and weld it up properly.
  9. hogfiddles
    Yup
  10. jayrodoh
    jayrodoh YimYam
    Cleveland
    Thanks all. My welding skills stop at bolt extraction and farm fixes. Luckily I have a buddy that welds for a living, will let him take a stab at it.
  11. Gulrok
    Gulrok Member
    Washington
    What model bike do you have?
    I have a spare frame for a 82' xj650 w/ clean title.
    It may have some bends you want too. Send me a PM if you're interested.
  12. jayrodoh
    jayrodoh YimYam
    Cleveland
    82 650. If you were local I would consider it. I'll PM ya on other stuff.
  13. jayrodoh
    jayrodoh YimYam
    Cleveland
    Just to clarify, the majority of the frame strength is in the "spine" up top? I'm no expert on frame design/engineering but if the cradle was stressed or extremely important I would be a little more concerned about the damage.
  14. jpacman
    jpacman Member
    East Central Vermont
    I had the same split in the same spot on my XJ750 (stored outside for an extended time by POs; it's always their fault!). I hammered it down, tested the metal around it with a 4" grinder, and MIG welded it back together. Primed and painted and you can't even see the spot.
  15. rocs82650
    Middle Tennessee
    Those are minor repairs for a experienced welder. Your welder bud will know what to do and should make quick work of the necessary repairs. You can watch, help and learn.
    Gary H.
  16. k-moe
    The cradle provides a great deal of the frame's stiffness. A fully cracked frame cradle makes the bike feel very bendy in the middle (because it is in fact bending).
  17. rocs82650
    Middle Tennessee
    Agreed. Basic frame design is engineered specifically to provide structural integrity for the bike i.e. bends, angles, pipe dims and lengths and how they weld together. ANY weak points will jeapordize the frame's structure. Each piece is major to the whole.
    Gary H.
  18. jayrodoh
    jayrodoh YimYam
    Cleveland
    Cool thx. Will get it over to him when I get back in town and see what he finds.
  19. jayrodoh
    jayrodoh YimYam
    Cleveland
    2 days and a six pack, looks much better.
    rocs82650 and k-moe like this.
  20. Polock
    better than two six packs and one day would have !
  21. skiprrdog
    skiprrdog Active Member
    Tucson, AZ
    I know this is an old thread but I was looking for something and stumbled across it. I am a welder and more than a little familiar with NDT, and any time you do a weld there is what they refer to as a 'Heat Affected Zone' that is right where you created the weld. This HAZ can significantly alter the mechanical and corrosion properties of the existing metal, making the area around where you had the corrosion less sound, even though you will not be able to see it. The repair looks good, but at the very least I would keep a *real close* eye on the repair.
  22. rocs82650
    Middle Tennessee
    As you stated a HAZ is created whenever welding is applied and also why welders know removing enough metal to eliminate the possibility of future damage, cleaning the metal and using proper welding techniques (amount of heat) is important. Imo those welds are fine.
    Gary H.
  23. jayrodoh
    jayrodoh YimYam
    Cleveland
    I'm not too concerned either. I know the guy well and I doubt he'd do anything that would be risky, especially when he knows I'll be hurtling down the road at 70 MPH some day on the thing. He did mention cleaning the areas up prior to welding hence the significant paint removal in both areas. Won't hurt to keep an eye on it anyway.
  24. rocs82650
    Middle Tennessee
    If he felt it was going to be a future problem he would have cut it out and sleeved a new piece. Spot welded the sleeves and gap welded the seams. Keep a eye on it tho.
    Gary H.
  25. Jarich
    Jarich Member
    Ontario Canada
    Adding on a decade later. These 750 frames surprised us with some lower left rail rusting. Even the frame that had been indoor for almost 20 years.
    One was an easy cut out and replace without any disassembly required.
    The other required replacing the whole section from a donor frame and adding internal sleeves.
    Spare cases were bolted in during welding
    Drainage holes were added to all of them
  26. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    Interesting, learned something new today as I never gave this a thought on my 81 SECA. Has 51,800 on the clock now and I got it at 36,021... guess I need to check the frame integrity.
    Jarich likes this.
  27. hogfiddles
    Anyone who need patch sections, I have a lot of dead frames that I can cut pieces from.
    Jarich likes this.
  28. Jarich
    Jarich Member
    Ontario Canada
    Did you get a chance to check your frame?
    I'm curious how many models it's occurring on.
    None of the 550/600 frames I have worked with have any sign of an issue
  29. Jarich
    Jarich Member
    Ontario Canada
    Excellent. Do you see alot of the shaft frames with the same issue?
  30. Brhatweed
    Mora MN
    No I have not, where exactly should I be looking?
  31. hogfiddles
    Very seldom. I just have a lot of frames from non-titled bikes that I’ve bought for parts. In hundreds of bikes I have had, or have or stripped, I can recall 3 that rusted a blew open….. and one person that bought a repair section from me….. that’s it.
    Jarich likes this.
  32. Jarich
    Jarich Member
    Ontario Canada
    Right at, behind the side stand and back to were frame turns up.
    Even if it looks all complete tap it with something metal lightly and listen to how solid it sounds
  33. Brhatweed
    Mora MN
    Yeah found the frame compromised right near the side stand, not bad but enough to require a partial sectioning of the frame and welding in of clean metal with some 0.023" wire from the MIG. Took a good ding from a ball-peen hammer to open up and nothing in front or behind seems bad with the hits I gave it.
    Big thing right now is slipping an inner-tube in the rear wheel thanks to the number of nails I've picked up over the summer, tube is easier to patch.
  34. Jarich
    Jarich Member
    Ontario Canada
    That's pretty much identical to the really clean 84 that I did just recently. And the odd thing is we know that that one has been indoors for the better part of two decades before I got it. Everybody who owns one should be out drilling holes. I know Honda had similar problems with the first little interceptors in Canada. We ended up replacing a whole bunch of frames at that time but the solution was just to drill drainage holes. I think they've learned since then because I see them on most stuff now
  35. Brhatweed
    Mora MN
    one of two plans for mine will be to either square the area and insert a plug of metal and weld that in or cut some rigid steel conduit in half and wrap the bottom area like a taco shell to make a skid surface that gets welded in place. Once the repairs are done a drain hole gets drilled and the interior of the frame gets a good shot of some oil to stop any future rust development.
    At 45 years old and with over 51,000 miles and this is the only damage I'd say Yamaha got things right.
