2nd gear rattles and doesn’t catch
Discussion in 'XJ Technical Chat' started by Donglord, Sep 17, 2026.
  1. Donglord
    Donglord Member
    Arkansas
    As the title says I’m having trouble with 2nd gear rattling and either sticking or not catching at all. Is my transmission on its way out?
  2. Fuller56
    Fuller56 Well-Known Member
    My best guess would be to first look at the shifter mechanism under the left side cover and make sure all the bits in there are engaging firmly and completely. Those pieces are much more likely to be out of adjustment or dislodged than the much more rugged transmission pieces. After that I would be thinking about a bent shifter fork in the transmission. The gear sets are very rugged for the size of the engine they service. We don't hear much about transmission damage without severe abuse in the XJ series.
    Jarich likes this.
  3. Donglord
    Donglord Member
    Arkansas
    I’ll check that out. There does seem to be a tick as well. It only happens when I shift to 2nd. It either rattles, catches and sticks, or works just fine. Not sure about how it was treated before I got it about a year and a half ago. But let’s hope for the best.
  4. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    I agree with @Fuller56
    best to inspect under the shifter cover 1st as its easily accessible.
    But it might be the little engaging dogs for 2nd gear are worn
    Common problem but it does require splitting the cases, winter is coming up.
  5. Donglord
    Donglord Member
    Arkansas
    @Simmy Splitting a case seems way outside of my realm of knowledge. I wouldn’t even know where to begin with something like that. So is this the end for my bike if that part are worn? I don’t know anyone willing to help me with it either.
  6. Jarich
    Jarich Member
    Ontario Canada
    Definitely go under the left cover to inspect. There seems to be an issue in some of too little Freeplay/clearance between the shift pawls and the cases. Just a little cut/grind of the support bosses will free the shifter pawls up
  7. Donglord
    Donglord Member
    Arkansas
    Haven’t had a chance to pull the cover off yet, but I did notice the shifter slides in and out slightly. I assume it should be nice and snug with no wiggle room like that
  8. Jarich
    Jarich Member
    Ontario Canada
    Yes the shifter should have just a little play in it but it's the two internal pawls where the problem lies
  9. Donglord
    Donglord Member
    Arkansas
    I’ll be 100%, I’ve never working on a transmission of any kind. Would you happen to have a picture of what I’d be looking for and maybe some kind of instructions? I just don’t wanna messing it up more than it may already be
  10. Jarich
    Jarich Member
    Ontario Canada
    Fortunately what I am discussing is under the left shifter cover.
    The symptoms are the internal shift pawls don't return to their normal position and you find there is no gear to select on your next upshift. After a couple attempts it drops back and lets you shift but by then your rpm range is all wrong and you likely misshift.
    My ,900 is doing it currently and I intend to fix it when I get home. I can post you the process but it will a couple of weeks
  11. Donglord
    Donglord Member
    Arkansas
    If you don’t mind documenting your process I’d appreciate it. I really do like my bike and don’t wanna let it just sit any longer than it has been
    Jarich likes this.
  12. Jarich
    Jarich Member
    Ontario Canada
    No problem at all. I get the frustration when they act like up like this.
  13. Donglord
    Donglord Member
    Arkansas
    found this YouTube video. Do you think it could be as simple as this?
  14. Jarich
    Jarich Member
    Ontario Canada
    What model do you have?
  15. Donglord
    Donglord Member
    Arkansas
    ‘86 XJ700xs Maxim X. The water cooled one
    Jarich likes this.
  16. Jarich
    Jarich Member
    Ontario Canada
    Sorry then. The 900 is a completely different beast I believe. But I may be able to help yet
  17. Jarich
    Jarich Member
    Ontario Canada
    I understand not wanting to split the cases to access transmission but you should be ok just pulling this cover to inspect.
  18. Jarich
    Jarich Member
    Ontario Canada
    I am not really familiar with 700x directly it seems similar to the video you posted.
    I would suggest you get the gasket for the cover ahead of time. Before pulling anything check if the shift shaft has any movement in and out from the engine. There should be a small amount of freeplay/side clearance. Then pull cover and look for broken springs like the video showed. Get a few pics posted before sealing it up and I can point out a few other things to inspect at that time.
  19. Donglord
    Donglord Member
    Arkansas
    I’ll look into it
  20. Donglord
    Donglord Member
    Arkansas
    This is what I’ve got going on. I was seemingly able to recreate the problem, though I’m not noticing anything real loose or broken.
    https://photos.app.goo.gl/LyBDgbvWAp37ft1R7
  21. co.dirtbiker
    co.dirtbiker Active Member
    Colorado, USA
    Are you turning the back wheel while trying to shift? Usually, not all the gears line up quite right when sitting still and they have to be rotated a little to drop in. When the engine is running it takes care of that, but when off, the wheel will suffice.
  22. Donglord
    Donglord Member
    Arkansas
    I am turning the back wheel. Even when I drive the 2nd gear gets stuck like that. All the other ones seem fine though
  23. Jarich
    Jarich Member
    Ontario Canada
    Has the weld let go on the front shifter pawl center shaft?
  24. Jarich
    Jarich Member
    Ontario Canada
    This should all be one welded unit and rotate together. It looks like the shaft is stationary
  25. Donglord
    Donglord Member
    Arkansas
    It looks all like one piece to me. I can see th weld toward the bottom of the piece and it looks solid
  26. Donglord
    Donglord Member
    Arkansas
    Jarich likes this.
  27. Donglord
    Donglord Member
    Arkansas
    Also the oil will go back into that side cover once I do an oil change correct?
  28. Jarich
    Jarich Member
    Ontario Canada
    Yes
  29. Jarich
    Jarich Member
    Ontario Canada
    Parts are definitely one so that is good. Most of the parts look correct but it is hard to see much. Would you be comfortable pulling the two shift pawl out of the case to allow better pics? They just slide in and are quite simple to correctly reinstall.
    Have you drained the oil or filter recently to check for particles?
  30. Donglord
    Donglord Member
    Arkansas
    Yeah I can pull those parts. I did the oil change and noticed no metal shavings/particles. Everything seems fine on the surface but still the issue persists. Ill get as better video of behind the pawls.
