1982 XJ650L Turbo - Carbs Overflowing
Discussion in 'XJ Technical Chat' started by derbybrit1, Nov 2, 2026 at 11:55 AM.
  1. derbybrit1
    derbybrit1 New Member
    Los Angeles
    How much fuel pressure do the carb needles and seats see at idle?
    I understand that the check valve opens about 2.8psig, and have seen references to automotive FPRs having a 6 psig set point. My FPR, with a gauge between the pump and the check valve, tests out at 5.3 psi.
    But I have a horrible overflow problem. Static float height set at 17mm and verified on bench with gravity fuel at 2mm below the gasket surface. I've since found that 21mm is supposedly the magic starting point for adjustment I will go back to that setting and try again.
    I am not sure that the floats in the carb are OEM which could be a problem. Can anybody post photos of the oem float assembly?
    And the tang on the float assembly pivot which limits 'float drop' in the bowl without fuel, to prevent the needle from falling out of position: How far should the float be allowed to drop from the valve just being closed?
  2. RideAlong420
    RideAlong420 Active Member
    USA
    As far as I understand it, you're way better off doing wet measurements, instead of dry measurements. So, yes, you can use the tang as a means of adjustment, but it's not recommended here to do so
  3. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Do you have an OEM FPR?
    Mine measured right at 2.8 psi
    I wouldn't dismiss your higher pressure for the flooding issue
  4. Simmy
    He did
  5. Fuller56
    Fuller56 Well-Known Member
    When I had a similar problem with a Turbo the problem was the "droop" tang on the float and the non-OEM float needles. The droop was just enough to allow the aftermarket float needles to sag just enough to not be square in the bore. I worked for about 3 weeks to get the wet set on the bench done. Sorry, no, I don't have a measurement for the sag or droop. No, I didn't figure it out by myself either, I found it on the internet...... Good Luck, when I got it right it was worth the time it took to get it right.
  6. derbybrit1
    Los Angeles
    Thanks for the reply. Yes, it is an OEM FPR. Non-adjustable. There was a Holley FPR kit for similar design Denso EFI FPR's, but the diameter of the diaphram is larger for low pressure carbureted use. Fuel injection at psi pressure can get away with a smaller diameter and stiffer spring. So that means no kit for this FPR
    The OEM FPR is packaged specifically for this bike. Generic aftermarket FPRs are quite a bit bigger overall, and hose routing becomes a problem.
    I'll try resetting the floats first.
  7. derbybrit1
    Los Angeles
    Thanks for the reply. I'll check it out and advise. Still looking for photos of OEM floats to see if these may not meet spec. There is so much Chinesium out there you just never know unless you have OEM.
  8. derbybrit1
    Los Angeles
    Carbs are fixed and bike runs. No more overflowing! It was a combination of everything mentioned:
    Float height setting 17mm = No Good
    Float height setting 21mm = Good.
    I'll check the fuel levels next with the clear hose/graduated glass tube tool. And adjust if required.
    Float droop tang settings were all over the place. 2 of them let the float needles drop down and get cocked. Adjusted them so float droop is level with pilot jet casting boss.
    Quick story:
    Carbs are sync'd using the YICS blockoff tool.
    I took out both head plugs, cleaned the bore, and inserted the tool from the right side. I was having trouble syncing the number 1 cylinder...it had low vacuum and was unresponsive to adjustments.
    I tried spraying the manifolds, but not leaks there.
    Guess what? It was leaking from the left side plug I had removed. I screwed the plug back in and Voila! All worked as expected.
    Fuel pressure holds at 5 psi steady with no issue. upload_2026-11-4_19-20-20.jpeg
    Fuller56 and co.dirtbiker like this.
  9. Fuller56
    Yay! Good for you. Glad to hear it is working. Such a simple problem yet so frustrating to get right. Patience and tenacity are keys here.
