  1. Jarich
    Jarich Member
    Ontario Canada
    More from Yesterdays riding. On the road in the dark this morning with 100 km in before breakfast. Very glad for the extra driving lights. And hand covers. Electric grips on the to do list.
  2. RideAlong420
    RideAlong420 Active Member
    USA
    I love those rims, wish I had those on my XJ650
    Jarich and Brhatweed like this.
  3. co.dirtbiker
    co.dirtbiker Active Member
    Colorado, USA
    Those are all done. Now on to the fork seals and rotors. Oh, and I need to pull the carbs and change some jets. And fix the fairing. And mount a tire.
  4. Jarich
    Jarich Member
    Ontario Canada
    The handling is amazing when these run on the 17s. Tire availability really helps
  5. Jarich
    Jarich Member
    Ontario Canada
    Nothing but admire its performance
    1800 km in two days without a single hiccup.
    Well except for coming up 10 km short in fuel range and having to get rescued. On the plus side I now know the exact distance I can go on a tank and that I can trust my fuel gauge
    Fuller56 likes this.
  6. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    All the way up to Thunder Bay
    Jarich likes this.
  7. Jarich
    Jarich Member
    Ontario Canada
    And onward another 400 kms to Fort Frances
  8. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    and another 200km south to my front door for a cold one.
    Jarich likes this.
  9. Jarich
    Jarich Member
    Ontario Canada
    Head on up and enjoy some Canadian hospitality.
    Uxbridge Brule likes this.
  10. Brhatweed
    Mora MN
    Put another 175 miles on the bike today but it might be the last for the year, need to pull the carbs off and address a runaway idle issue that creeped up. Overall the bike was feeling somewhat lean so I think it's time to go thru them, two years without any major carb problems is nothing to complain about.
    Time to get Zestfully clean
  11. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Ever since I put the 8 inch headlight on my 650 maxim I've suffered from poor lights - combination of low idle speed, long routed wiring dropping volts, and worst of all a continental left hand (right side of the road) drive headlight, so that on dip it flicks up on the wrong side. I sort of decided to go led headlight, but you can only go to 7 inch, which would need a curved stainless bezel to take up the annular space, a right faff.
    So I had a look around the workshop, and found two units dipping on the other side, albeit they were poor - one was dirty the other looked like the reflector was rough. Well I decided to open up the dirty one, to see if I could swap the lense into my existing light. Well, after some heat was applied, it came apart lovely, it then cleaned up nice as well. So well I decided to use it. So it was fitted in place of the old one, and crikey, massive improvement. So this leaves me wondering if I need to bother with a relayed feed, but I think I will add a pair of LED lights to give some background light close in. Anyone else tried this?
  12. ScottFree
    ScottFree Active Member
    Northern Ill-Annoy
    I started the week off with a couple 100-mile rides. No particular destination, just out for some fun, giving the bike some exercise after canceling my plans to ride it to the Slimey Crud run and then around the Driftless, in order to exorcise the demons of last fall's misadventure by riding the Himalayan to Arkansas. In the process I pushed the odometer past 14,000 miles, which is not much for a 46-year-old bike, but keep in mind it slept in my friend's garage for over 20--maybe 30--of those years.
    And I noticed it was time for a cam chain adjustment and valve check. Today was rainy and chilly, so a perfect day to do such a thing. My, this bike is easy to work on... gas tank comes off with one bolt and one easy-to-reach hose; yeah there are 22 bolts holding the cam cover on, but they are all pretty easy to reach; there's plenty of room to get feelers in to measure valve clearances; if it does need re-shimming they're conveniently on top of the buckets (and, unlike the one Kawasaki sold for my Z-1, the shim-removal tool actually works). It was a pleasant hour or so checking things.
    The good news: seven of the valves were dead-on, unchanged from 8300 miles. The eighth (#3 exhaust) is just a tiny bit loose, most likely because of a decision I made when I re-shimmed at 8300 miles. The valve was very tight then, and according to the chart in the manual going down one shim size (#255 to #250) would leave it barely at minimum clearance, while going down two sizes (to #245) should leave it right at the upper limit. So I went with the thinner shim, thinking I'd never have to adjust this valve again, and now it appears to have settled in just slightly above the upper limit. I wish I had bought both sizes of shim last time, and tried them both. Sigh... this is what happens when the width of the in-spec range and the increment between shim sizes are both 0.05mm...
    I also noticed something on five of the cam lobes:
    Is this considered normal wear at 14K miles? Is the hardened surface coming off the cam? This is #1 exhaust, but the other four lobes look the same. And three of the lobes are shiny and like new.
    Edit: a search turned up similar photos on somebody's XJ550 from earlier this year. Dragging a fingernail across the cams confirms that I am looking at pits, not ridges. I suspect it's corrosion pitting, the result of the bike sitting for twenty years without being turned over. I pulled one of the shims and saw no signs of scuffing or wear on it. This would be consistent with the lobes being pitted and the shims sliding on the hardened surface between the pits. I am kinda surprised I did not notice the pitting when I checked the valves at 8300 miles, but I do miss things (and in my defense, I had better lighting today, and I still didn't really notice the pitting until I wiped the oil off the cam lobes). I think that for the time being I am just going to run the bike, maybe inspect the cams again after a couple thousand more miles, and compare photos to see if the pitting has spread (indicating that the hard surface on the cams is failing).
  13. Simmy
    Yea I agree with your approach
    Check it again in a few miles next year and see if it gets worse. A replacement cam shaft is pretty easy to find, if it does get worse
  14. Brhatweed
    Mora MN
    Personally I'd replace it anyway and stick with high zinc oils or the STP oil treatment in the little blue jug, I mix that 1/3 to a crankcase each oil change. This is the type of damage caused by the modern oils be it synthetic or blends. Zinc was cut way down to appease the new emissions regs and prevent cat converter damage.
    chacal likes this.
  15. co.dirtbiker
    Colorado, USA
    Finally finished up most of the overdue maintenance on the 750 Seca.
    Oil change
    Air filter
    New fork seals
    New fork bushings
    New front tire
    New front rotors
    Fatter pilot jets
    Install rebuilt calipers with new pads
    Install rebuilt master cylinder
    Spent 3+ hours bleeding the !#@! brakes
    Crappy job of fixing the fairing
    Fix broken clip on side cover
    Brakes seem to work much better but still takes a lot of lever movement compared to the 900. They have plenty of stopping power, so I think it's just a side effect of the goofy hybrid cable/hydraulic setup as I am pretty sure I finally got them bled fully.
    Still need to resync the carbs, and I should probably check valve clearance, but those will have to wait.
    Pretty sure I spent more on parts than I originally did on the bike. Should be good for a while now though. Hopefully I'll get a chance for one last ride this week before the weather turns.
    Fuller56 and chacal like this.
  16. Fuller56
    Fuller56 Well-Known Member
    What was the deal with the fairing? How did you fix it? When I had one like your avatar I did not like the way the fairing attached to the mounting bracket between the headlight and the instruments, it seemed less robust that I liked. I fitted a flat piece of aluminum sheet in there and glued it to the fiberglass for the bolts to go through. No, I didn't take any pictures of what I did but the fairing was solid to the frame after that.
  17. co.dirtbiker
    Colorado, USA
    The mounting points where the lower section bolts to the engine bracket was broken. I tried the super glue and baking soda trick, but the glue I had was the thicker stuff and didn't mix well so it looks awful. Fortunately, you can't see it from the outside.
  18. co.dirtbiker
    Colorado, USA
    Oh yeah, rebuilt the anti-dives too.
  19. Fuller56
    @co.dirtbiker, ahhhh. I agree that the gel works with the baking soda but not well. The plastex (sp?) kits come with "low viscosity" super glue and work really well. I have had excellent results with the cheap, runny super glue from the dollar store and baking soda. I have also read that very finely ground charcoal is even stronger but haven't tried that yet. I did a bunch of plastic repairs on the XJ750 Seca and Turbo that I had for awhile. Again, not pretty but really solid.
  20. ScottFree
    Northern Ill-Annoy
    I may have a line on replacement cams. Maybe.
    I also keep thinking that if these are corrosion pits, they had to be there when I re-shimmed at 8300 miles. I don't have any notes about cam lobe pits, but I think my full attention was on the shims and the light wasn't so great. But assuming they were there at 8300 and they haven't changed since then, the pits are probably not an immediate issue.
    I have been thinking about what to do with this bike. In another discussion with a bunch of Road King owners, about what we're going to do when we're too old and feeble to muscle around an 800-pound Harley (I will be 73 in a couple months, so this has become more than just something to talk about over beers), I said that if I had an empty garage and full bank account I might be looking for a modern "standard" bike like the Royal Enfield Shotgun, something I could equip with some luggage, belt drive and a small fairing, and pretty much use for anything from long solo tours to day trips with the wife. Then I noted I already might have such a bike in the garage, in the form of the XJ... which leads to another thought: this bike plopped into my garage for "free." I have put a fair amount of work and money into it and have it running reasonably well, but it retains the fundamental problems of a Maxim: it's a cruiser, which means low seat, small tank, ridiculous handlebars (the last of which I replaced early on). Plus, of course, the brakes--after fitting Galfer lines, EBC semi-metallic pads and an aftermarket drilled/floating rotor, the front brake rises to mediocrity by today's standards. So I have a bike that's got a good underlying platform but would require a lot of work to seat, tank, brakes, etc., to really fit the way I ride. Perhaps, having inherited this thing and been bitten by the XJ bug, it would make the most sense to put it back to "stock Maxim" with the preposterous handlebars, stash the fairing in the garage, sell it for less than I've put into it, and go shopping for the 650 or 750 Seca that would probably fit my use profile a whole lot better. There seem to be plenty of them on CL and FB Marketplace. The question is whether I could find one in decent enough condition to actually use as a daily rider, and at what cost...
  21. co.dirtbiker
    Colorado, USA
    Today I took the day off work and took the Seca 750 for a nice long ride with a couple of friends to break in all the new parts. :) I did around 220-ish miles at elevations between 5200ft and 11,600ft. All the recent maintenance performed as it should. Brakes are much better, though still not as tight as the 900. Suspension worked well. Exhaust is a bit quieter than it used to be with the new packing.
    The only disappointment is that I'm still having issues with the way it runs pulling out from a stop. No power until it gets to around 3000rpm. I tried bumping up the pilot jets to 42, and while I think it improved a little, it's still not right. This issue has plagued me since I got the bike. Frustrating.
    Anyway, it was an awesome day. The bike runs great once it's up to speed, and while the power is down a bit when you're over 10,000ft, it still held its own against the modern fuel injected 1200+cc BMWs I was riding with. Couldn't have asked for better weather...especially this time of year it's a bit of a crap shoot.
    Gotta say, I really like the comfort of the 750 touring compared to the 900, but the motor on the 900 runs circles around the 750. Wish I could combine the two. :)
    Brhatweed, Dan Gardner and Simmy like this.
  22. Brhatweed
    Mora MN
    Try them with a set of stainless brake hoses, far less pull of the handle to engage the master and get some grab on the calipers but if you've ever driven a car with drum front brakes the actions are quite similar. Light apply, you feel it. A little more... more...GRAB & STOP but it's predictable and controllable. Go hit Chacal up for a set of lines, worth every penny.
  23. co.dirtbiker
    Colorado, USA
    I put SS braided lines on it years ago. The brakes are good, just a different feel than the 900, which also has SS lines and rebuilt everything. I took a little more slack out of the cable adjuster which helped. Don't want to go too far though and end up dragging. I wish it wasn't such a pain to get to the MC so I could see how much slack is truly on the piston lever. You have to remove the whole fairing to get to it.
  24. RideAlong420
    USA
    I put braided lines on my 650 and new organic/metallic brake pads and upgraded from a 13mm MC to a 16mm MC and it stops very well. Still need to replace the rotor with something lighter, and I'd love it if I could just replace the caliper with something better, like brembo.
    I considered doing a 750 swap so I'd get two rotors in the front but I'm not entirely sure it's actually necessary, but my only other frame of reference is a 2008 Rebel 250
  25. co.dirtbiker
    Colorado, USA
    I didn't take a lot of pictures this time, but this was at the summit on Guanella Pass. 11,669ft (3557m). Gorgeous views
  26. RideAlong420
    USA
    man those hard cases and passenger seatrest and fairings are so cool
  27. Brhatweed
    Mora MN
  28. ScottFree
    Northern Ill-Annoy
    On Wednesday, I stumbled across a posting on this site saying that if shock bolts are too tight (beyond the specified 30Nm) the bike's handling can slow down. So I loosened the fasteners and re-torqued them to see if that would change anything. Then, as winter approaches, I decided to put a bunch of miles on the bike, over 500 in the last three days. Wednesday I went out with a friend for ice cream and to get coolant for my Himalayan; this trip (which should have been no more than 60 miles) turned into about 90. Yesterday I rode down to Starved Rock State Park, hiked to a couple waterfalls, stopped for a picnic lunch along the Illinois River:
    183 miles in all. Today I decided to ride out to a brewery in Elizabeth (NW Illinois) via some small roads.
    This one's called "Slick Road," though it wasn't slippery at all. Maybe it's named after the famous cartoon racer Tom Slick.
    Made a scenic stop at Apple River Canyon State Park:
    Finished this day with 260 miles. Funny. I've only put 2250 miles on the bike this year (not much by my standards), but 500 of them have been in the last three days. Gotta say I am really getting to like it. Right size, decent ergos (especially after ditching the stock bars and putting the booster cushion on the seat), and the Rifle fairing really seems to have completed things. I've been thinking about what I'd like to do before taking this bike on some longer trips next year. fix the idling problem, of course, but after that a few things to improve comfort and convenience: install a really good touring seat and a bigger gas tank (stopping every 110 miles or so for fuel gets old after a while)... Next year is the 50th anniversary of my first really big motorcycle tour, when I lost my job, gained a Z-1, and rode it to both coasts before getting my new job. I could take a commemorative tour on my Harley or my Himalayan, but taking a trip on a Japanese four would be more nostalgic...
  29. Fuller56
    @ScottFree, great report, especially about how the more you ride the Maxim the more you like it. You do remember that a 750 Maxim is a direct, drop on fit and give an additional 1 gallon of capacity?
  30. ScottFree
    Northern Ill-Annoy
    Yeah… and I have been looking for one, so far without success. I saw what looked like a nice one on eBay, until the “shipping” charge (from a vendor supposedly in the USA, so no tariffs) raised the price to around $400. This seems to be the new game on eBay: list a low price for the item, then add “shipping” that more than doubles it.
    I may not need a 750 Maxim tank as such, as I am fiddling with the idea of completely ditching the stock seat and installing a Harley cop-bike seat like the ones on my Road King and my Himalayan (you read that right: I have an ADV bike with a Harley cop seat; MacGyver-Sanford Moto Labs can make anything fit anything). In that case I suspect other tanks would fit, though I think a Seca tank would look a bit silly as it's meant to join to other bodywork. I used to have a Harley Low Rider tank that would have worked just fine on this bike, but alas I don't have it anymore.
    What's disturbing is that I spent most of the summer wondering if I could use my Himalayan as a street touring bike now that I'm pretty much done riding further off road than gravel (I took serious off-road adventures to Moab when I was 27 and again when I was 67; kinda suspect I won't be taking a third when I'm 107). I put a couple thousand miles on it in September and October and concluded that the bike would work, with restrictions (mostly around its limited cargo capacity and more limited cool weather protection). I am also not thrilled about the bike's height and general awkwardness (it is not an easy bike to get on and off, it's clumsy to push around and feels much heavier than it is, and the center stand is an absolute disaster), or the chain drive, but figured I could live with these things. Then I took a couple rides that approximate days from an actual touring trip on the XJ, which raised the whole new question of which bike should be my lightweight touring machine...
    I looked at the odometer today and realized that I am now only 350 miles from needing an oil change. And it's supposed to be dry, mostly sunny, and 60s-70s pretty much all this week. That's a convenient excuse, I think...
  31. ScottFree
    Northern Ill-Annoy
    Sunday featured a minor fiasco involving the rear brake light switch. I noticed that since my last adjustment to the brake linkage, the switch no longer turns on. So, I figured I'd tighten it up a bit, which did not go according to plan... and then I figured well, I bought a replacement several months ago, this was the time to install it. The usual fun followed, with the spring being too long, and then too short after I cut it, and again too long after I stretched it a bit... and once I got it installed, I discovered the switch I had purchased was normally closed, not normally open, so the light was on until I pushed on the pedal! WTF? Why does a normally closed switch in this style even exist!? At that point I decided the front switch was enough on a 70-degree afternoon, and went out for a ride.
    I ordered another replacement switch that explicitly says "normally open." I think this is one I ordered, received and returned a while back because it didn't come with a spring (even though the pictures in the listing showed the spring). I now have a spring, from the normally closed switch, so fine. It should arrive tomorrow, along with the oil filter. Just in time for the oil change. The bike is now one nice day's ride away from needing its 15K mile oil change, and tomorrow is supposed to be sunny and 73.
    Brhatweed likes this.
  32. ScottFree
    Northern Ill-Annoy
    Today... another 175-mile ride, to look for fall colors (didn't see much), return the incorrect coolant I had bought for the Himalayan (there is much to be said for air cooling), and mark another minor milestone:
    I was out in the cornfields near Oregon, IL, watching one incredibly erratic driver in a little hatchback, who kept driving off the road into the ditch, then back onto the road, then into the ditch... really, drinking that much at 1pm?
    Corn and nukes:
    Also about as good as the leaf colors got today. The leaves seem to be falling seconds after they turn this year.
    OK, maybe these leaf colors were a little better: a herd of motorcycles at Lowden State Park, home of the big Black Hawk statue overlooking the Rock River.
    When I got home, I found my new K&N oil filter in an envelope on the porch (along with a new rear brake light switch). Perfect timing! Did I mention the Yamaha is about the easiest oil change since my old Ironhead Sportster back in the 1980s? Two bolts, no spraying oil, everything easily accessible... except for maybe that middle gear drain bolt. I know a lot of people say "don't bother," and I typically don't, but I got curious about just how much oil was behind the thing. So I emptied my drain pan, pulled the middle gear drain, and found... maybe 20cc at most. I assume Yamaha's reason for putting a drain bolt there was to avoid contaminating the new oil with used oil, but... 20cc? Hardly seems worth it...
    I also noticed this little leak, under the alternator cover:
    I think it's most likely the gasket. Gonna have to see what it takes to replace it over the winter. One more project...
    I warmed it up by riding it around the neighborhood, and then parked it in the car side of the garage, as I'm going to ride the other two bikes the next two (last two?) nice days (the Harley and the Himalayan have been a bit neglected the past couple weeks), before rain arrives this weekend and I want to stage the annual "intervention" in the motorcycle garage on Saturday, cleaning up all the junk, throwing away the stuff I should have thrown away sooner, putting away the stuff I should have put away when I was done with it... When the rain stops sometime late next week, the forecast says it will be a lot cooler. Almost seasonal for early November...
  33. ScottFree
    Northern Ill-Annoy
    Hmm... about that possible oil leak at the alternator... a little searching indicates that there appears to be a weep hole in the alternator cover, the alternator itself runs dry (should have expected that), and if there's oil it's probably leaking around the shaft seal. Fixing this appears to require pulling the stator and rotor. None of which looks particularly difficult, no worse than when I installed the "doohicky" in my KLR. Just one more thing for the "to do" list.
    I spent a lot of time yesterday watching the bike's idling behavior, hoping to get a lead on where to look for a problem rather than just blindly digging into re-rebuilding the carbs in the hope of accidentally fixing what's wrong. What I noticed: I pull up to a stop after a mile or more at 45-60 mph. The tach drops to 2000 immediately, and then to 1500 in under a second. Then it drops more slowly (count of two or three) to 1000. It will sit there, very slowly dropping for about five seconds to the point where it'll stall if I don't blip the throttle. I can hold the idle at 1500 by holding the throttle, but it is a very, very, very tiny amount of turn. What's been my perennial problem is that if I use the idle speed knob to get to a steady 1000-1100 rpm, the bike will not return to idle after it's been running at a higher speed; if I put up with having to blip the throttle when waiting for a stoplight, it otherwise runs rather well: runs smoothly, pulls to redline without missing or stumbling, delivers 45-50 mpg when kept within sight of the speed limit, plugs look like I would expect from an engine of this vintage running properly. I have been unable to find any signs of a vacuum leak, so I am looking at possible restrictions in one of the idle circuits, or a slide dragging, as possible causes. I am planning to go through the carbs again this winter, mostly to replace the float valves with good quality ones from Len (I currently have two original and two aftermarket of dubious source, and I don't trust any of them), and will also check the slide bores and idle circuits again.
  34. Fuller56
    As today was predicted to be the nicest, warmest day for a while(likely May 2027) and I have not taken a "Goof Off" day in months I rolled the Faithful Seca 650 out. After running some errands, I did the Northern Pa. Viaduct Picture Tour. Starruca, Nicholson and Martin's Creek Viaducts. Faithful Seca never missed a beat and acted as though it was happy to be out playing. Starruca Viaduct 1.jpg
    Rooster53, co.dirtbiker and Brhatweed like this.
  35. RideAlong420
    USA
    My bike met her big sister today and it made my whole day!
    My favorite color, the rims are painting like how I'm wanting to do mine (except in pink). The tank is so much larger than mine, I think I'm gonna have to get different handlebars to clear how tall the tank is.
    Seriously made my whole day, this made me so so happy :D
    Dan Gardner, Fuller56 and Brhatweed like this.
  36. Borinc
    Borinc New Member
    Arkansas USA
    She’s getting a freshly cleaned head, new gasket, and fresh valve adjustment
  37. Brhatweed
    Mora MN
    Always thought that 5-valve design was brilliant.
  38. ScottFree
    Northern Ill-Annoy
    So did I. "Wobbly Phil," the English YouTuber, does not agree:
    (It should start at the part about 5-valve heads; if not, zip ahead to about 5 minutes into the video).
    I thought it interesting that YouTube just plopped that video into my "recommended for you" feed about three days ago. I will say I don't fully agree with him. The 5-valve system was perhaps too complex and expensive for the benefits it delivered, but it did flow better than any other head design of its day.
    He was also pretty negative on all the Japanese anti-dive systems, including the one Yamaha put on some of the XJs. On this I will agree; those things never seemed to work very well. The only anti-dive systems that worked in my experience were the BMW Telelever (particularly on the R1100s; for some reason the engineers seem to have intentionally put some dive back in on the 1200s) and Harley's "inflatable handlebar" systems that changed the air reservoir size when you got on the brakes (I had four bikes with that setup, and it worked really well--especially on a heavy touring bike with a big fairing).
    Back to what I'm doing to my Yamaha... mocking up what could be (quoting the Simpsons) the perfect blend of comfort and... eeeevil:
    It's an abomination to the eye, but beauty to the behind.
    I have a sprung police seat on my Road King, and an unsprung one on my Himalayan, and in terms of comfort these things are the absolute bomb. I have a third seat in the garage, initially intended to replace the one on the Himalayan (that seat's been on three different bikes over the last twenty years, racking up well over 100K miles, and it's starting to show some wear), but with the Himalayan kind on on the bubble (having pretty much finished the "off road adventure riding" part of my life, it's hard to justify a bike that dirt oriented), I'm going to try it on the Maxim. I have the pivoting base, need to procure springs, and after that it's a matter of fabricating the necessary brackets. Haven't decided yet whether I will retain a passenger seat or mount a storage box for tools, etc., on the back fender. Might even move my Givi trunk (I have two--32L for day rides, 45L for trips) back there rather than cantilevering it off a luggage rack. I already have the Rifle Sport fairing on the front of the bike, and with this seat upgrade and proper luggage the XJ should be ready to travel next summer. It's the 50th anniversary of my first major cross-country trip, taken on a 1976 Z-1, and I kinda want to mark the occasion with a properly "vintage" UJM. I think the XJ will do the job.
  39. Brhatweed
    Mora MN
    Starting to get my parts together for a re-ring of my SECA but need to confirm if the Maxim 750 cylinder head & base gaskets are the same. I know there's a few small differences between them like the tach drive but just want to make sure.
  40. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
  41. Brhatweed
    Mora MN
    Awesome parts catalog, looks like everything is a go to use Maxim gaskets as everything crosses over between them. Now I gotta get the motor out of the frame and the head over to Seleen Engineering for a valve job. 91 year-old tool & die maker with a full machine shop who used to make race cars and engines for fun.
  42. FJ111200
    Yes it's a very good site. CMSNL are the European importers of Japanese bikes and parts. The UK dealers go through CMS too and there isn't much difference between the Euro bikes and US bikes apart from the parts for the emissions in the California market.
    The old lad sounds like he knows his stuff but can't you do the job yourself?
  43. Brhatweed
    Mora MN
    I could but he has the tools, equipment and some 70+ years of experience doing 3-angle valve jobs, known him all my life and trust him far more than myself. The man designed his own hemispherical DOHC cylinder head to make a race engine out of a Chevy 261 truck engine back in the 1950s then designed the sand molds and cast the head himself in his mid-20's. The thing is a work of art.
  44. Brhatweed
    Mora MN
    System wouldn't let me add another so here's the actual engine on the test stand. Fuel is a Hillborne injection system.
    Dave in Ireland, Fuller56 and chacal like this.
  45. Dan Gardner
    Minneapolis, MN
    @Brhatweed - is this somebody doing a favor for you or would he actually accept work from other other people? I haven't had much luck finding a machine shop that would touch on XJ engine.
  46. Brhatweed
    Mora MN
    more of a favor really, he might be inclined to take in some outside work. Will ask when I talk to him.
  47. ScottFree
    Northern Ill-Annoy
    What did I do...
    Let the Unspeakable Perversions begin:
    As threatened, I mounted a Harley police seat on the Maxim. For now, it's on rigid struts:
    but my plan is to support it on springs, like the one on my Road King. I used rigid struts when I put one of these on my Himalayan, but that's a dirt bike with a mile of suspension. The XJ is more like the Road King, with the limits of a cruiser suspension, and the extra inch or so of bump handling ability will be welcome, especially on our Illinois roads.
    I took the bike for a 90-mile ride this afternoon, and was pleased with how it sits and the overall comfort of the seat.
    The seat is part of a bigger project to make the bike into a middleweight solo touring bike in time for next summer. Thinking I will install a toolbox in place of the passenger seat, at the right height to support the mounting plate for my Givi Monolock trunks. Might install hard side cases (as I did on my Himalayan; might even re-use those) or just go with my trusty Ortlieb Dry Bag toss-overs.
    The idea is to mark 50 years since my first big cross country trip. In 1977 I rode my Z-1 to the East and West Coasts (Delaware, Florida and California); on the 50th anniversary I would like to ride the XJ to the North and South Coasts (Keweenaw Peninsula in Lake Superior and the Gulf Coast in Mississippi or Texas).
    To make that trip with fewer gas stops, yesterday I ordered an XJ750 gas tank on eBay. It’s imperfect—crummy rattle can paint I’ll have to remove (and replace with less crummy rattle can paint of my own), and a small ding I’ll have to fill (or decide to ignore). But the price was right (under $100 including tax and shipping) and the guy says it has almost no rust. We’ll see when it shows up.
  48. Fuller56
    Good job! It is a little funny looking to my eye but I am more in favor of comfort than appearance anyway. And it is just a rough draft as you prove the concept. That Rifle fairing really fits though.
  49. ScottFree
    Northern Ill-Annoy
    It will look better when it's finished. After I work out the spring mounting, I intend to fabricate a tonneau cover that will snap to the top of the side covers, to keep rain and dust out of the fuses, etc. (and also clean up the look). And I plan to put some kind of tool/compressor/papers box where the passenger seat goes, which is sort of necessary since the under-seat part of the back fender is seriously ugly.
    The Rifle fairing really works well--I did that 90-mile ride with temperatures in the high 50s, and was quite comfortable wearing only a couple layers of t-shirt and a thin fleece under my Aerostich jacket. The wind and chill protection that thing provides is incredible, especially considering how small it is.
