  1. Fuller56
    Fuller56 Well-Known Member
    Are there any paintless dent repair guys in your area? Those guys do some amazing work pretty quickly too. They should be able to work that dent out pretty easy, at least to my inexperienced eye. One in the Cary, NC area un-hail damaged my GMC Canyon pick up in a day.
    As far as the rust, WalMart has 30% vinegar in the auto/RV parts area. Grocery store vinegar is, I think, 3%. I have had excellent luck with electrolysis as well. Good Luck!
  2. Rayzerman
    Rayzerman Member
    Ontario Canada
    I use Evaporust to clean tanks with light/medium rust. Water soluable, can reuse if not black (filter it).
    I pulled 3 baseball sized dents out of a tank using a cheap Chinese dent pulling system where you glue on buttons with hot melt then use the provided tool to work them out (start at the edges and work your way in, pull in slow movements). Eventually, you'll have to sand, use filler, prime and paint/clearcoat.
  3. ScottFree
    ScottFree Active Member
    Northern Ill-Annoy
    The problem with going to the painless dentist is that just getting an estimate would probably cost as much as I have spent on this tank! But, as it turned out, the dent is immediately above the slot where the petcock fits. And I had a nice German tire iron with a spoon-shaped end. With a bit of careful feeling and taps on the other end of the tire iron, I was able to push on the dent from inside the tank. That took me from this:
    (dent about 1/4" deep)
    to this:
    (two smaller dents about 1/16" deep)
    At this point the dings are well within the realm of what I can fill with a bit of spot filler, something I've done before (though not in a few decades).
    On to the interior... friend brought over his bore scope, so I was able to do a reasonably full inspection. There is surface rust and some stale gas inside. I didn't see any significant scale rust. I think it will need a vinegar soak, but I don't think I need anything stronger or more costly.
    Then there was this thing:
    When I poked the bore scope into the petcock hole, I found a sheet of paper towel in the tank. Well, that could have made a big mess if I hadn't found it; probably would have wrapped around the petcock and kept it from flowing any gas to the engine. It was a pain to fish the thing out with a coat hanger wire, but I got it. Took it to the sidewalk and set it on fire. It burned... slowly. The gas in the tank is really stale, or perhaps somebody tried to rinse the tank with kerosene or something.
    On to other parts of the project: I made a trip to Harbor Freight and picked up a 2800-series case. I think it looks pretty good in place of the passenger seat:
    Right now it's just sitting on top of the flat cross-member at the joint between the plastic front half of the fender and the chrome back half. I think mounting it should be easy--a couple bolts into the cross-member, and a couple plates going to a pair of convenient threaded brackets on the frame behind the shock mounts. Just a bit of fabrication.
    Looking at this, I got an idea, and sorta mocked up the larger HF boxes I'm using as side cases on the Himalayan:
    Hmm... I think this just might work... Supporting the side cases should be pretty easy, requiring no more than a few feet of angle stock, some of which I already have in the garage.
    I suppose at this point i also ought to remove the passenger pegs!
  4. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    I won't tell anyone if you don't.
  5. ScottFree
    Northern Ill-Annoy
    Busy day today.
    In the morning, I started cleaning the tank. First I made a blanking plate for the petcock, then I sloshed the tank with a couple gallons of hot hot water and dish detergent (Dawn--if it's good enough to get crude oil off birds, it's good enough to remove the last of the stale gas that was in the tank). With that done, I moved on to the "throw in some random hardware and slosh it around" stage. In the interest of domestic tranquility, I did not throw the tank into the dryer to tumble the hardware as many on YouTube suggest :) . I quickly figured out that I could slosh things around pretty well by resting it on my knee and see-sawing it rather than trying to hold it and shake it. So... upright, left side, right side, upside down, repeat, about ten minutes in each position for an hour and a half or so. A whole lot of rust came out; it took about four rinses to get it all. Then I had the problem of getting the hardware out, as you can't just dump it because of the tube in the filler. So I fished them out with a magnet... which worked well for nuts, bolts and screws, but not so well for washers--when they were laying flat in the bottom of the tank, the magnet preferred to stick to the tank wall rather than the washer. I used the shop-vac (with a piece of pipe taped to the nozzle) to remove the last of the water that wouldn't empty out, removed the blanking plate, stuck the shop-vac into the filler (where it fit perfectly), and went inside to have lunch. Half-hour later the inside of the tank was bone dry... and already starting to show some flash rust. I looked around with the borescope and wondered if I really needed to do the vinegar soak.
    But, I decided I might as well at this point, so off to Walmart* for some Serious Vinegar. Not my favorite store, too damn big, hard to find stuff, and if I let the wife know I'm going there's always "a few" other items to pick up. Came back with four gallons of vinegar and a box of cereal. After re-installing the blanking plate (with a Gorilla tape "gasket") and pouring the vinegar (and a bit of water to fill it to the top) into the tank, I found a proper-sized cork in my brewing supplies, corked the tank up and set the tank aside on the bench. Weather forecast says the temperature will be above freezing (and as high as 63º) through Sunday afternoon, which should be enough time for the vinegar to do its thing.
    On to the fun stuff... mounting the "tool box" in place of the passenger seat. The Maxim's frame has a couple threaded tabs welded to the frame, just behind the shock mounts and not used for anything by Yamaha. Which meant they were free for me to use. Only problem was that to reach the tabs, I had to remove the big aluminum grab bar, along with the luggage rack and turn signals.
    I began by getting out the CAD tools to design a bracket that would attach the tool box to the frame bracket:
    "CAD" = Cardboard Aided Design
    After some quality time with the Sawzall, grinder and drill, the cardboard design became steel from my stock of scrap:
    The white squares in the cross member are a lucky find: plastic Chrysler license plate nuts from the local hardware store. They just snap into the rectangular holes in the cross member. Couldn't be easier!
    I initially intended to mount the box directly to the license plate nuts and the steel brackets, but they didn't quite line up with the ovals on the bottom of the box that Harbor Freight obviously intended to be use for bolt holes, so I decided to put a plastic plate in between. I learned a long time ago that a polypropylene cutting board is just perfect for this:
    Yeah, I had to shim things a little. Were these washers fished out of the gas tank? Maybe...
    The four silver dots are where the bolts attaching the box will go... when I make a run to the hardware store for the necessary screws and tee nuts to fasten it down. And put the grab rail, luggage rack, and turn signals back on.
    Worst thing is, I will have to take it all apart next spring to paint the brackets.
    With any luck, I'll have the afternoon free to take it for a ride and see how those springs soak up bumps.
