Turbo parts bike
Discussion in 'XJ Technical Chat' started by Simmy, Aug 17, 2026.
  1. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    I picked up another Turbo parts bike. It is complete but unfortunately no ownership.
    Just 30,000 kms.
  2. Simmy
    This thing is perfect for someone who allways dreamed about turbocharging their XJ.
    I read onetime a guy was turbocharging a CB750 with all the Yamaha stuff
  3. Timbox
    Very nice find. I don't know if I would ever want a turbo vintage bike? I love the looks, Yam bikes in general, but for the twist the throttle and fun factor I would have to go with a new bike. I do hope you enjoy it or pass it on to a worth project person. Looks to be in good shape for the age.
  4. Simmy
    I have a buddy who drag races old gold wings because he gets them free.
    Racing him would be fun.
    Project Rat Racer
    Seriously what really caught my interest was it was listed as an 83 which would make a rare bike. It's date of mfg is 01|82 so not an 83.
    I'd like to get rid of the wbeels suspension and body work and just keep the unique turbo mechanicals. I could find a corner for that
  5. Simmy
    As the seller handed me a box of stuff he said the owner started to convert it to normally aspirated.
    Luckily he didn't get further than removing the fuel pump and plugging the fuel return line to the tank and at the fuel check valve.
    The guy I bought it from said this was a one owner bike, a relative of his wife.
    Apparently there were brothers and they both painted them this ugly blood red.
    It came with a 2nd set of shocks for some reason.
    And 2 LJ owner manuals
    Timbox likes this.
  6. Fuller56
    Fuller56 Well-Known Member
    I bet they would have been really disappointed in the performance if they had completed removing the turbo and its plumbing. At least it has found its proper home now.
  7. Simmy
    Picked up an 84 XV750 for cheap.
    I've always wanted to lace some 17" wheels for an XJ.
    If I can sell a few parts, maybe gas tank, carbs, exhaust and scrap the rest it will pay for these wheels.
    I think I read the rear rim is off centre when mounted on an XJ, I'll verify and post that when I get a chance this winter.
    Front wheel I believe is direct fit.
    If I can find some used supermotard rims, then order custom spokes....it'll still cost a fortune, oh well at least I can dream.
    I'm uncertain what is actually wrong with this bike
  8. Timbox
    Hope that works out for you. Looks like a good donor bike.
  9. Simmy
    I removed what I wanted from the Virago and thought, might as well drain it's oil and get it ready for scrap. As a 750 motor it probably has no value.
    The bloody motor was filled to the brim with some nasty solvent, turpentine I think, nasty surprise.
  10. Simmy
    I googled turpentine in motor for storage and there is a lot of reasons why this is not a good idea LOL
    I suspect the motor is probably seized and someone filled it hoping to free it up
    I'm keeping the entire swing arm and drive shaft so I can compare it to the XJ stuff. The final drive unit looks the same and the brake plate is the same as the Seca, I looked that up.
    Once I get the Virago out of the garage I'll park this latest Turbo by the bench for the winter
    I'm giving the idea of going drag racing more thought, I've never actually done it.
    This bike would be perfect.
    They have Friday night practice runs here, not expensive
    Timbox likes this.
  11. Simmy
    RideAlong420 and Fuller56 like this.
  12. Fuller56
    @Simmy, your next project? I would have thought it would have been a bit faster overall. But then again, I am not a racer in any way. Still pretty cool.
  13. Simmy
    At 65 I don't intend to be good at drag racing but thrashing an old UJM down the strip sounds like a lot fun.
    My buddy who drag races was explaining how the bracket system works.
    I don't really care I just want to make runs during Friday night tuning sessions.
    Using a Seca Turbo makes sense for me as I have so many spares already.
    I can add updates to this thread here as I have a look into this bike.
    We'll see how much it may take to run. Could still be scrapped don't know yet.
    This bike has been stored indoors so who knows, I haven't had time to look at it closely.
    I've already been through a shiny Turbo restoration so this would be my challenge to do on the cheap.
    Even though its painted red It needs to keep all the Seca Turbo body work so everyone can see what it is.
    You still need lights to run at night.
    Fuller56 likes this.
  14. Simmy
    I stripped everything off the Virago and took the motor, frame and forks to the recycler.
    240 lbs of mixed tin = $33 CDN
    $0.1375/lb if anyone is curious
  15. chacal
    Ryobi 40V LED flashlight welded to the front fairing saves some load on the engine.......... :)
    Simmy likes this.
  16. Simmy
    I compared the Virago swing arm to an XJ.
    Virago is silver, black parts are Seca Turbo
    brake stays
  17. Simmy
    Maybe I could use a Virago driveshaft in an extended (modified) XJ swing arm.
    Almost 2" longer, good for launching at the strip!
  18. Simmy
    soaked wet it looks pretty good!
    The instrument cluster is smashed in, someone must have tried to get it going and failed.
    Fuller56, Timbox and chacal like this.
  19. Simmy
    spent some more idle time comparing the Virago wire wheel set up.
    You'll notice the Virago rear axle is longer than the XJ.
    This is because the Virago wire spoke hub is wider than than the XJ hub.
    This is what it looks like with the XJ axle installed, it's not long enough to thread the castle nut on.
    This is the Virago axle installed. Now there is lots of room for the nut
    Mounted on the XJ this is where that extra length in the axle ends up, could be enough to foul with the exhaust.
    Would be easy enough to shorten with a grinder I suppose but it is nicely chromed
    It does all fit together on the bench anyway. I loosened the 4 studs holding the final drive unit and this was enough to wiggle the 140/90-15
    through the gap. There is lots of clearance on both sides of the tire, almost equal clearance which is not the case with the red Turbo in the garage,
    a 120/90-18 allows my pinky finger between the drive side but lots of space on the brake side.
    The wire spoke hub will be off centre without much room to change it.
    You could probably gain some by loosening spokes one side and tightening other side but about 1/4" is all that's there.
  20. Simmy
    The front wheel fit into Turbo forks but the brake discs are wider spaced.
    Outside edge to outside edge of the discs on the Virago are 130mm but just 122 on the XJ.
    This makes mounting calipers more difficult.
  21. Simmy
    Nope, Virago u-joint takes a bigger spline, about 22 mm diameter versus 19 for XJ
  22. Simmy
    With everything I've learned considered, I will not be doing any wire spoke XJ conversion.
    The cheapest I found 36-hole rims online 17 x 3.5 and 17 x 4.25 was Amazon, almost $600 CDN
    Custom spoke set ??? probably $600 maybe I'm low...
    Last time I paid to lace a wheel it was $75 (well spent BTW) so today at least $200
    Machine some caliper mounts - $200
    Rim strips, tubes and tires, then dynamic balance,
    lets just say we're easily over $2000.
    I paid just $200 for the Virago and have already got that back, plus I have these wheels Virago guys desire, won't be a problem selling them.
    Now returning to my regularly scheduled XJ channel....
    Timbox and Fuller56 like this.
  23. Simmy
    I built a new elevated table and put the red Turbo on it.
    Pulled the spark plug and sprayed WD40 in each cylinder.
    Put a wrench on the crank and the motor is not seized, moves easily.
    Next check was to see if the turbo unit still spins.
    I began removing the waste-gate pipe, I knew it was rusty but it was rusted so bad it broke off in my hand.
    Then I tried removing what was left of it and that ripped off at the wastegate exit elbow.
    It was full of solid debris as you can see in the pic.
    I dug the debris out to the curve in the pipe and it's still plugged.
    I pulled the compressor outlet hose off in the pic below and the compressor still spins, awesome!
    I tried removing the LH pipe but it seems someone tried removing the turbo unit before me.
    All the fasteners to and from the turbo unit are all rounded off.
    I checked my Green turbo to make sure I had the right size Allan wrenches, yep, someone buggered them all.
    Even the 12 mm hex nuts at the turbine inlet are rounded off.
    There are 2 8 mm Allan nuts holding the turbo unit to the frame I can see he hadn't touched those.
    If I can get those out I can drop the hole exhaust including the turbo. I'll hit it with heat next time out.
    Compressor still looked good and had oil there.
    So the 2 main items, motor and turbo both move free, promising so far.
    Fuller56 and chacal like this.
  24. Simmy
    Removing this turbo unit has been a challenge but I'll get there eventually.
    I'm sure the reason the previous owner gave up trying to convert it to normally aspirated started with his difficulty removing the turbo.
    Rounded all the fasteners and gave up.
    The left side exhaust pipe is held on by 2 studs with nuts and the 3rd corner is a bolt. All take Allan keys so they are easy to mangle.
    I was able to get a nut splitter on 2 of them and the 3rd one with the bolt I drilled it's head off.
    So I have the fasteners essentially removed but the muffler won't budge.
    The exterior finish is still really good so I'm being gentle, the metal near the flange is pretty rusty.
    I think a previous owner gooped this up with some super adhesive.
    The bolts holding it to the frame are not budging so I'll need to drill their heads off to.
    Doing any of this without removing the swing arm would be difficult
    Fuller56 and Timbox like this.
  25. Simmy
    you have to love working on these things to punish yourself in this way!
    the 2 studs at the top are what hold the turbo unit to the frame.
    I had no other option but drill them flush, they will need to be replaced.
    The other one drilled in the pic was a bolt so it still needs to be extracted from the turbo body also.
    I still haven't dislodged the left exhaust but I have everything from it to the collector loose now.
    I only need to disconnect the oil lines now.
    The one on top of the turbo I have loose but the one on the bottom is hidden by a little skid plate I expect to be
    drilling out the fasteners to get at it.
    Once I can drop the whole unit down a few inches I'll have better access to the nuts holding the collector.
    I believe someone reinstalled the turbo unit at some point and torqued every one of these fasteners to 100 ft-lbs
    above are the fasteners Yamaha used. They're in a tight spot and work great but the DPO was a gorilla
    Luckily drilling these out is accessible and the Allen heads keep your drill bit centred
    I should have known the exhaust would be full of oil but it still got me.
  26. Fuller56
    Good on you for having the patience and good sense (and of humor of course) to take it apart as it should be done, even it is about the hardest way possible. The XJ gods will smile on you someday for being good to an poor misused XJ. And you are keeping us entertained and educated besides, and inspired.
  27. Simmy
    Victory!
    This bike was just too complete to part out but removing that turbo unit was a nasty job, still not complete.
    I'm going to keep disassembling the turbo unit, without that functioning this bike is back to being an organ donor
    I've started the process to acquire the registration for it, we'll see,
  28. chacal
    Pulling a turbo off one of these bikes is one of the most difficult tasks imaginable........not only are they always covered with multiple layers of crud and sludge, it's always rusted/seized completely and in an uncomfortable and ultra-crowded spot. I did it once and swore to myself "never again". I even feel badly asking my employees to go snatch one off, and keep a good supply of bandages, betadine, and a big basket full of extra curse words at-the-ready when they do.
  29. Simmy
    Thanks for the moral support @chacal
    Good to know I'm not alone.
    My green Turbo everything came loose as it should, got lucky
  30. Timbox
    I wonder how one of those induction head guns would work. The ones that have a round coil at the end of the gun to put around a bolt to help crack the rust. That looks just nasty and to get at it, way to go. Love the hobby so much that you can work through anything.
    Rooster53 and co.dirtbiker like this.
  31. Simmy
    they look pretty slick, especially if you have plastic and rubber nearby which might be melted by a flame.
  32. Simmy
    The turbo is finally separated but I still need to remove the skid plate.
    You can see an Allen head bolt hidden between the oil line and the rusty waste gate elbow.
    I got great engagement with my tool but I stopped as I was already applying too much
    I'll try an impact wrench next before I eventually drill it out.
    This is another one still to remove, it's the Allen head in the middle of the pic.
    It's long and just threads into the skid plate, it no longer holds a tool.
    So if I drill the heads off these 2, this will still only allow the skid plate to slide out as far as the oil line.
    I'll be able to fit a hacksaw in to cut the bolt then.
    There are 7 fasteners you need to remove to extract the turbo.
    I have at least an hour of labour into every freakin one.
    Every one, ok conventional hand tools aren't going to work anymore, drills, grinders and chisels from here.
    I'm quite proud of these 2 I was able to salvage, easily an hour on each widdling away the nuts without damaging the studs
    The Seca Turbo's have an inherent problem with oil pooling in the turbo, this is probably why most of them were parked.
    The fortunate thing is it floods the turbo's internals of oil, great for long term storage.
    External check valves are the fix.
    I still think someone inexperienced assembled this stuff and over tightened everything.
    My green Turbo had never been messed with and every fastener came out without any issue.
    This one does have some rust, the green one didn't.
    co.dirtbiker likes this.
  33. Simmy
    I drilled off the bolt heads for the skid plate, moved the skid plate enough to get a hacksaw in there.
    finally on the bench after a quick clean.
    the worst is behind me now.
    Most of the fasteners now I think will be good.
    There's 1 or 2 still holding the waste gate elbow I'll likely have to drill.
