82 seca xj750 right brake caliper will not mount
Discussion in 'XJ Technical Chat' started by mason79, Nov 24, 2026 at 8:42 PM.
  1. mason79
    mason79 New Member
    los angeles
    rebuilt some ebay forks, delete plate anti dives, new bushes and washers from Len, back together, stock springs, 20 wt 140mm from the top, air supply deleted..................but......
    the right caliper is 1mm interference between the right rotor and the mounting bosses, anyone ever have this prob?
    speedo drive on the other side is spinning the cable, i loosened everything and tried to shake and loosen it up
    the part numbers on the fork sliders are the same as the one off my bike
    i twisted the chrome tubes 180 to see if it flared the other way, so not bent forks
    looking at it the wheel is 1-1.5mm towards the right, how flush does the speedo drive need to nest in the left wheel?
    tmr i am going to take it apart again to stare at it, meanwhile any input would be welcomed and thanks
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    are you trying to mount the calliper with the brake pads in?
    if so, have you tried to push the calliper pistons back in, to give you the clearance
    mason79 and chacal like this.
  3. mason79
    mason79 New Member
    los angeles
    i found out it was bent fork tubes
