BRK Warning
Discussion in 'XJ Technical Chat' started by SecaNick750, Mar 23, 2008.
  1. SecaNick750
    SecaNick750 New Member
    Albany, NY
    I have an '82 Seca 750. Just had the brakes flushed. The brake rotor was rebuilt because it was sticky. The BRK warning has come on. I checked the fluid and it is full. How do I reset this?
  2. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Maybe the little switch is stuck? Or maybe it is making poor contact or a grounding issue? Just a thought.
  3. SecaNick750
    Albany, NY
    what little switch are you referring to?
  4. PainterD
    There should be a little switch that makes the light come on, right? I think there is one inside the brake resevoir that tells you when the brake fluid is low, that's the one I'm referring to. On mine (750 Seca) the brake resevoir is down on the lower triple tree and is a bitch to get at. There are wires running to it, so I assume there is a switch that says when it's low on fluid. PD
  5. SecaNick750
    Albany, NY
    The guy at the shop never reconnected the power line to the sensor that is coupled inside the headlight casing. Thank you for your help. Much appreciated.
  6. PainterD
    That's good you found the problem. You may want to check all those plastic connectors as long as you have it apart and make sure they are all clean and make good contact. Those are trouble spots on these bikes and have a history of leaving some people stranded, scratching their heads. PD
