Got some work done today.
Discussion in 'XJ Modifications' started by maximuschop, Mar 30, 2008.
  1. maximuschop
    maximuschop Member
    Indy
    Lowered 3-1/2 inches rear with hardtail struts, 1-5/8 front, shortened kickstand, made a custom rear frame section, modified dirt bike bars, took off mufflers and centerstand. Still have to make my seat pan/fender, forward controls, await my clip-ons(ordered the wrong size), paint, install pods, re-wire for no guages, signals, or safety switches, install new fork seals, and get her tuned. What do think so far?
    I'm open to opinions and suggestions.
    http://i229.photobucket.com/albums/ee30 ... C-001F.jpg
    http://i229.photobucket.com/albums/ee30 ... C-002F.jpg
    http://i229.photobucket.com/albums/ee30 ... C-003F.jpg
    http://i229.photobucket.com/albums/ee30 ... C-004F.jpg
  2. kevineleven
    kevineleven Member
    Columbus, Ohio
    Looking pretty good. The clip-ons will be rad. Good work!
  3. Ltdave
    Ltdave Member
    are you going to use the front fender?
  4. maximuschop
    maximuschop Member
    Indy
    nope, no fender.
  5. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    It's looking good! You'll be pleasingly surprized the first time you ride it. You will turn some heads too!! PD
  6. maximuschop
    maximuschop Member
    Indy
    Thanks for the comments guys. I hope I can get some more work done tonight, I'll take pics and post up if I do. I just want a low-buck custom to play with. I can't afford, nor can I justify spending 10-15k to have a custom bike, when I can build it myself and get that satisfactory feeling, and be able to say I built it.
  7. PainterD
    Yup, I heard that!
    And where do you see those $15,000-$20,000 custom bikes? Parked in front of the local bars and resteraunts to be shown off, not being rode. Lot of good that is.
  8. maximuschop
    maximuschop Member
    Indy
    Well, I had her fired.... for about half a second. A combination of bad gas, fouled plugs, and carbs that need cleaned didn't help either. But I'm well on my way. I changed the oil and added a little seafoam, tomorrow i'm going to go get some premium, new plugs, and add some seafoam to the gas and see if I can't get her running. I made my template for my rear cowling/seat pan, I should have it cut out and mocked up tomorrow as well. I also got some more work done on my forwards. Pics to come soon.
  9. maximuschop
    maximuschop Member
    Indy
    Well guys, no dice. What is the plug gap supposed to be? Also It didn't seem like it was getting fuel so I pulled off the tank and squirted fuel into the main line, hit the start button and no fuel left the line. It just sat there. I'm so bummed, I wanted to get this thing fired up today. Can anyone help?
  10. trans1973
    trans1973 New Member
    Michigan
    Looks great! Do you mind me asking the length on your hardtail struts. Your bike looks like it has about the stance I want for mine.
  11. maximuschop
    maximuschop Member
    Indy
    I can get measurements today when I get off work.
  12. philbrewer
    philbrewer Member
    Livonia, MI
    Love the look. Nice weld on the sissy bar too! Good luck with the carbs. I pulled mine off last week and found that all enrichment circuits in the float bowls were completely clogged. Ill be putting it back together this weekend! *fingers crossed*
  13. turbobike
    turbobike Member
    Grand Island, Nebraska
    a 'custom' bike isn't 'custom' unless you do the 'custom' work yourself.
    otherwise it's someone elses repeated work.
    like orange country choppers, sure, they are all "custom" but, they all use the same frame, engines, tires, etc.. just paint is different.
    and IMHO, buying a 'custom' bike for 20 grand, is stupid. You're not a real biker, you're a rich prep looking for some flashy toys.
    The kid / guy who does his own work, on his own bike, is a true biker.
  14. maximuschop
    maximuschop Member
    Indy
    I got her fired up again and she runs awesome, played with the choke for about one min. adjusted the idle to around 950-1000, no surging, no missing, doesn't load up and will sit and idle till it runs out of gas. I can't believe it! I'm so excited! I will have a video up soon. My camera is broken. :( The measurement for the struts to lower it are 8-3/4 hole to hole. Pics tonight hopefully!!
  15. philbrewer
    philbrewer Member
    Livonia, MI
    Did you take the carbs off and clean them?
  16. maximuschop
    maximuschop Member
    Indy
    I have not thoroughly cleaned them yet. I plan on doing that next after my tail section is finished up. Then I'm gonna adjust the valves and put a new gasket on. I'm sure the carbs need cleaned, and as I want this bike reliable I will do it right.
    Sorry for the crappy pic, it's from my cell phone,
    tail mock-up
    http://i229.photobucket.com/albums/ee30 ... 267355.jpg
  17. maximuschop
    maximuschop Member
    Indy
  18. maximuschop
    maximuschop Member
    Indy
    Also, anyone know where I can get a custom digital tach that I can "hide"? I don't want to over rev this thing!
  19. Stinky
    Stinky Member
    Flagstaff, Arizona
    Looks good. Sounds good. Avoid potholes.
  20. kevineleven
    kevineleven Member
    Columbus, Ohio
    Looking real good. Great work.
  21. maximuschop
    maximuschop Member
    Indy
    Thanks guys, I hope to get more done this week.
  22. yamabobber
    yamabobber Member
    hey max, i had a digi speedo and could never see it in the day unless i put my hand over it to shade it. my two bits
  23. maximuschop
    maximuschop Member
    Indy
    I'll have to see what I can find, I need to have something there to judge my speed off of.
  24. 07spacker
    07spacker Member
    Utah
    i bought a ten dollar schwinn bicycle computer at wal-mart, hooked it up dialed it in and it works like a charm up to 99 miles an hour... the thing is dope cause its no bigger than a silver dollar... no backlight though...
  25. maximuschop
    maximuschop Member
    Indy
    I should try that, it's cheap enough to experiment with, and I could light it with an led. Awesome! Thanks for the info!
  26. earz_cd
    earz_cd Member
    Jefferson city, MO
  27. dead_cafe
    dead_cafe New Member
    omaha,ne
    Looking good man.
  28. maximuschop
    maximuschop Member
    Indy
    Thanks guys. I'll have more updates soon. The carbs are off getting cleaned, and hopefully back on in week or two. Gotta get some filters too.
