bike issue
Discussion in 'XJ Technical Chat' started by leadboots, Apr 9, 2008.
  1. leadboots
    leadboots Member
    aylmer ontario canada
    Hey guys I have a 82 yamaha seca 750. Earlier today it was running fine but now i went to go out and as soon as I put it in gear it stalls everytime i try it.....Wat is going on?
  2. MaximumX
    MaximumX Member
    Ottawa, Canada
    Sidestand safety cut-off switch thingie?
  3. XJ600S
    XJ600S Member
    Boulder, CO
    Not sure if your bike has a kickstand switch, but if it does, it could be bad. If so, your bike would kill the engine because it thinks the kickstand is down when it really isn't.
    If thats the case, the fix would be to replace the switch, or bypass the switch altogether by removing it from the circuit and splicing the wires together.
    My 1994 seca2 will stall if I put it in gear with the kickstand down.
