oil change
Discussion in 'XJ Technical Chat' started by fun550, Apr 28, 2008.
  1. fun550
    fun550 New Member
    cincinnati
    I just have a pretty basic question for you guys, I have a 1981 maxin xj550, Was going to do an oil change and was wondering if anyone can tell me the size sockets need for oil plug and oil filter housing? thanks so much, AWSOME site!!!
  2. Anthony14
    Anthony14 Member
    Mississauga, Ontario
    Just open your tool box and see what fits lol.
  3. blazemechanix
    blazemechanix New Member
    Bloomington, IN
    I believe I used a 17 or 19mm for the filter plug and for some odd reason I can't remember the size for the drain plug but it is in the same general area
  4. MiCarl
    I believe the oil drain is 19mm.
    The stock filter bolt is really small, like 12mm. If you have an after market replacement bolt it may be 17mm.
    These bolts are almost always over torqued. Correct torque for the oil drain is 31 ft-lb. Oil filter bolt is 11 ft-lb which isn't much more than snug.
    If you over torque the filter bolt you risk damaging the 0-ring and creating a situation where it is very difficult to remove the bolt later.
  5. Ltdave
    Ltdave Member
    here here...
    im STILL fighting the bolt on my seca....
  6. MaximXJ
    MaximXJ Member
    West central Wisconsin
    Anyone know the factory specs to torque down the bolts?
  7. Anthony14
    Anthony14 Member
    For the oil drain plug and pan it's 31 ft.lb for a xj550, 600 & fj600 81-92
  8. Polock
    one of these should fit
  9. MACDBF
    MACDBF Member
    Halifax, NS. Canada
    The sizes may vary due to stock or after market, but one thing is for sure.....Don't strip the oil filter bolt. It took me hours and hours of pain staking attempts to remove. I ended up having to weld on another bolt head just to get some torque onto it. So take your time and make sure you have the exact fit. That will save you alot of headaches with that bolt head! Have fun with it, and keep us posted!
    Cheers Mac
  10. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    When using sockets to remove stubborn fasteners always use 6 pint sockets.
  11. dustball
    dustball Member
    Oak Harbor, WA
    previous owner shaved off my filter bolt... i took an angle grinder and cut a square around it and knocked the rest of the filter off with a hammer... I had already bought a spare.. so it was all good... probably the darkest oil I ever seen... it was in there for years
  12. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    Lather up and go sit in the sun :)
    Gonna be a tan greek soon 8)
  13. TIMEtoRIDE
    My PO welded a socket to the filter bolt! Now I don't have to look for that socket. All bolts should have 3/8 square drive heads.
  14. pvtschultz
    pvtschultz Member
    Milwaukee, WI Area
    :lol: ROTFL! :lol:
  15. jeepsteve92xj
    jeepsteve92xj Member
    Milwaukee, WI USA
    lol
    6 pints and no riding! Youll be way over any sort of safe limit.
    but yes, 6 point sockets are the way to go!
